Question about Kodak EasyShare DX7590 Digital Camera
Our 7 year old Kodak digital camera works as good as new. But the flash door will not open. We have a new battery and that has not helped. Can we open the door with out damage to the camera?
I press the flash button for the door to open and the door does not open. The camera picture taking is still very good, except for this problem.
    Genius:
  • Kodak Master
  • 1,019 Answers
Hello Martha, Sounds like the spring mechanism that operates the flash lid has a spring problem, you can manually open the flash but it will not stay in the raised position without the spring unit working,it has nothing to do with the battery,it is an internal mechanical problem.
Best Regards, Russell
Posted on Jan 24, 2013
5 Suggested Answers
silly girl
  • 513 Answers
SOURCE: Kodak DX6440 won't power up using batteries
There's a chance that the drop is irrelevant to your problem. You could try using a small eraser to clean the battery contacts down in the chamber (make sure to dump out any eraser particles) and try a new CRV-3 battery, which because of it's slightly longer body produces a little more pressure on the contacts. If that doesn't work to improve things then your cam might need a repair, your call there. Good luck
Posted on May 04, 2006
praky16
  • 744 Answers
SOURCE: button does not work
hi
Some of those buttons work in combination with the two dials (i.e., setting ISO and white balance, etc.). Hold a buttin down and user the knobs simoultaneously.
If this is not the issue, please describe specifically which buttons are not workin...
thank u rate me!!
Posted on May 24, 2009
SOURCE: KODAY DC3400 BATTERY DOOR BROKE
Easy Fix-
I had the same problem. Place the camera upside down with the battery door to your right. There is a plastic plate with the eject switch to the left. It has three philips screws. Get a jewlers screwdriver (Any hobby store, Harbour Freight, etc.) Take out the three small screws. Don't lose them. Get a razor blade and pry up the plate in the line just to the right of the top right screw. Only pry up about an 1/8 of an inch and only that corner not the whole plate. Then you can slant the new battery door so that the top part goes to the left under the plate and then straigten it out so that the tabs seat in the grooves. Repace the screws. Voila.
Good Luck,
-Joe
Posted on Jun 24, 2009
leepania
  • 1099 Answers
SOURCE: I have a Kodak Easyshare C180 digital camera. I
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Nov 16, 2009
I have a kodak easyshare c533 camera and it won't turn on. I tried new batteries but all it does is flash the green light. Any ways to fix this?
Green light flashed, turned red, lens would not open. Put in new rechargeable batteries, still nothing. Someone here suggested to try regular AA cheapie batteries. IT WORKED!
Nov 09, 2010 | Kodak EasyShare C533 Digital Camera
My Kodak Easy Share DX6490 will not turn on. When I place it on the charging dock, the lights flash like it is transferring photos to my computer and the flashing won't stop even if I remove the camera...
Hello, sounds like you have a faulty battery,if the battery is several years old it will lose the capacity to boot the camera and the dock is trying to charge a defective battery,if you get a new battery, charge it for at least 6 hours or more.Hope this solves your problem.
Regards,Russell
Aug 16, 2010 | Kodak EasyShare DX6490 Digital Camera
As soon as I turn it on, it shuts back off
Kodak offered no help with this problem and for my camera more than five years old no repair option was available. However, after thinking about this problem a solution was found. Perfectly charged old batteries and new batteries fully charged did not correct the problem. Here is what worked for me: With fully charged battery installed, place closed camera on EasyShare-One camera dock. With the the green light flashing, simultaneously depress both the power on/off button and the shutter button. With both these buttons held down, toggle the capture view switch from an intial down position to up, and then down position.Now release both the power on/off button and the shutter button simultaneously. This whole process takes about 20 seconds. Let the camera remain on the dock until the green light stops flashing. Remove the camera from the dock, open the camera back as usual and the screen will present you with date/time setup. Enter the date and time as required, hit the 'done' icon with the camera pen and the camera will now function normally. Why this works is speculative. However, the idea behind this method is to force a 'reboot' to factory settings by maximising conflicting electronic input signals.
Dr Barry T Rubin
Aug 13, 2010 | Kodak EasyShare One Digital Camera
Camera wont turn on
go www.kodak.com/go/stepbystep
after following the troubleshooting steps
process repair thru the website
just follow the procedure
after submitting the repair process
it will generate email for you on how to send camera for repair > check your email
Sep 23, 2009 | Kodak EasyShare C913 Digital Camera
Kodak easy share digital camera m863
I have a Easy Share M863 and have had it less than a year. It was working great and then last week I tried turning it on and it would not open. I thought it might be the battery needed charging so I did that. It still will not open. I contacted Kodak and they told me they would give me 15% on a new digital camera. That is not what I wanted. My camera is not even a year old. It should have lasted longer I think.
Jun 08, 2009 | Kodak EasyShare M863 Digital Camera
Put brand new batteries in camera took three pic then they die
Hi, you will only solve this by buying the official KODAK battery (KLIC-8000) - NZD52.00 retail here in New Zealand. Even the generic CR3V rechargeable batteries dont work, so dont waste your $$ on them.
Even now, with the 'official' battery, when taking flash photos or zooming a lot, I find that it is only taking around 150 - 200 shots, when Kodak boast over 400.
But I must say the capabilities of the camera (esp the quality video) outstrip any annoyance battery wise.
Hope this helps, regards Wayne
Mar 28, 2009 | Kodak Easyshare Z812-IS Digital Zoom...
Kodak DX3900 camera can't get power from battery
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Mar 13, 2009 | Kodak EasyShare DX3900 Zoom Digital Camera
Lens locked in open position after batteries fell out
mine sometimes does that. 1.get a new cheaper camera. 2. use duck tape 2 secure the door.
Jan 26, 2009 | Kodak EasyShare CX4230 Digital Camera
Kodak Easyshare
Remove the batterty andclean the internal battery contact with an
eraser on the end of a pencil- take a flash light to look inside the compartment to enfure they are bright and clean.
Make sure the battery door and contact srip are a good tight fit
Hold the door down with a finger whilst switching on
Other than that there is little moreyou can do
Jun 28, 2008 | Kodak EasyShare Z740 Digital Camera
No flash after 2 years
Sounds like you might need a new bulb. I just looked up on kodak.com They have all kinds of parts but the labor to fix it can be expencive says it about $138.00 to fix the flash.
May 27, 2008 | Kodak EasyShare Z740 Digital Camera
Kodak EasyShare DX7590 Digital Camera Logo
203 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
