Question about Dell Computers & Internet
When i start computer the screen stays black and it beeps
  • Dell Master
  • 27,725 Answers
Perhaps you've built a computer and are turning it on for the first time, or you've owned this computer for awhile.
Either way, you may encounter an issue where the monitor shows a black screen and the computer is beeping.
There are several causes and solutions for this problem.
Refer to your motherboard manual, since the motherboard is the beeping device.
These beeps are like Morse code, and each "beep code" is explained in the manual.
Common beep codes include not having a monitor or keyboard properly connected; not having a CPU fan connected, or not attaching internal power cables to the video card.
This black-screen-and-beeping issue is most common with newly-assembled computers.
Check external cables to make sure they're properly connected.
The most important external connections to check are the monitor's signal cable and the keyboard.
If your monitor cable looks damaged or kinked, try replacing it with a spare. If your keyboard's cable looks frayed, try a spare keyboard.
Also, a PS/2 keyboard plug (round, with holes in it, about the diameter of a finger) is often color-coded purple.
If you have plugged it into the green port in the back of the computer (for PS/2 mice) switch it to the other one.
If there is no color coding, the proper port should have a small, embossed icon of a keyboard on the back of the computer.
If it does not, refer to your motherboard manual for the correct port.
If all else fails, try a spare keyboard, preferably USB (Universal Serial Bus), which can be plugged into any USB port on the back of the computer.
Check for additional motherboard power connections.
Yours may require multiple cables attached from the power supply.
There is the standard wide plug, which you know is connected properly because your motherboard is beeping.
However, there may also be an additional, four-pin cable that connects elsewhere on the motherboard. Check the board's manual to make sure it has all the power connections it needs.
Check your internal cables.
Make sure that the CPU fan is plugged into the motherboard header nearby.
Without that, the CPU fan will not spin, and the motherboard may detect this lack of connection and produce a beep code.
Your video card also may have one or two internal power plugs that need to be attached to the power supply's cables.
These cables have unique ends on them, similar in shape to a USB plug.
Refer to the case or video card documentation if need be.
If those cables are not attached, your motherboard may refuse to boot the system.
Your video card may be faulty.
If this is a new card, it may have arrived to you broken, in which case you will probably need to request an RMA (Return to Manufacturer Authorization) to receive a replacement.
If this card was previously working for you in this system, you can contact its manufacturer yourself to receive a replacement, if the device is still under warranty.
Hope this helps
Posted on Nov 03, 2012
Toshiba will not boot
It needs those things to start up. If you reinstalled them in the machine and it won't start up you need to check some things:
Does the screen flicker when you power it on or does it stay completely black? If it stays completely black, then the connection from the screen to the computer itself is lost. Normally it is caused by a broken cable.
If the screen flickers and then goes black, then check the following:
Does it beep at you? If it does, then the amount of beeps is important. It will state in the users manual what that numbers mean.
If it doesn't beep, then my best guess would be that there is something wrong with the power distribution in the machine.
Sep 07, 2014 | Computers & Internet
Installing graphics card
try reseating card (remove and reinstall)
Mar 07, 2014 | Alienware Nvidia GEFORCE DDR5 GTX 460M...
3 beeps mean
The ram is either the wrong kind, bad, or not pushed in properly.
Dec 22, 2013 | Apple MacBook Pro Laptop Computer with...
My HP DV4000 beeps when I press the power button and the screen will stay black.
This POST error code maybe -
one long, two short beeps
  • System board failure
  • Video adapter problem
  • LCD assembly failure
Dec 04, 2012 | HP Pavilion dv4000 Notebook
I updated the bios on the dell vostro 1000 and it wouldn't start. The power light stays on and you can hear the fan. This is followed by a long beep and 2 short beeps while the screen stays black.
Hi alkeith...
Turn on the computer while tapping F8, this will take you into the Safe Mode.
While your in the Safe Mode you can do a system restore.
Restore your computer back to an earlier time when it was working before you installed the bios change.
Left click on Start>All Programs>Accessories>System Tools>System Restore.
This should solve your problem.
Please take time to rate me
Aug 05, 2011 | Dell Vostro 1000 Laptop Computer (AMD...
Dell Inspiron 1545 Booting Problem [Black Screen].
Insert the original Windows CD-ROM into the DVD-drive, and see if the computer will "boot" from that disk. If so, then it could be your 'C:' drive which is having the problem, and thus not "booting" your computer from it.
Jun 15, 2010 | Dell Inspiron 1545 Notebook
Computers & Internet Logo
56 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
