Question about Singer Sewing Machines
Need owners manual for singer sewing machine 20-13
Not sewing properly.....bubbin thread doesn't loop with the top thread
  • Singer Master
  • 1,564 Answers
User Manual: http://www.parts.singerco.com/IPinstManuals/20U.pdf
Parts list: http://www.parts.singerco.com/IPpartCharts/20U11_13.pdf
Service Manual: http://parts.singerco.com/IPsvcManuals/20U.pdf
You are probably out of time. But check to make sure you have the right needle and it's fully inserted first.
Good luck
Posted on Nov 04, 2012
SOURCE: Looking for a free download of Singer Sewing Machine 6235
if you still haven't found one, reply to this thread. I have one as a PDF that I just bought for $5 that I'd be willing to share (this goes for anyone who finds this post, too)
Posted on Feb 26, 2010
  • 139 Answers
SOURCE: how to thread & what needles for singer 660 A2 sewing machine
You can download a manual here:
Posted on Apr 07, 2010
  • 1116 Answers
SOURCE: 8280 Mechanical Sewing Machine: i need free manual for singer sewing machine model...
Free download here - http://www.singerco.com/accessories/manuals.html
Posted on May 07, 2010
RichSew
  • 184 Answers
SOURCE: Singer sewing machine 6215c trouble
The problem is actually with the upper thread not having enough tension on it. Check your upper tension setting,,,it should be set about mid range of its adjustment (4,5 or 6). To see if the tension is functioning correctly thread the machine and raise the presser foot to its up position and pull thread thru the needle. It should pull easily, lower the presser foot down to the fabric and now the thread should become harder to pull. If there is no change in the pull,then either the thread is not in the tension correctly ot the tension is not working,
Doug
Posted on Aug 07, 2010
hunter19_46m
  • 7482 Answers
SOURCE: I need a manual for
Hi sherri36911...
Go to the following webpage and download your free user manual for your Singer 3116 sewing machine.
Please take time to rate me
http://safemanuals.com/user-guide-instructions-owner-manual/SINGER/3116-_M
Posted on Aug 17, 2011
I am having trouble getting the bobbin to function properly during sewing.
It could be the top thread is the problem. Might try removing all the thread. Consult the owner's manual for threading instructions. RAISE the presser foot BEFORE threading the upper thread so the thread will seat properly in the tension disk. Re-thread from the beginning carefully following the instructions--do not miss any spots or thread guides.
If top thread is still creating a mess of loops under the fabric, try tightening the upper tension. The tension is ideal when both upper and bobbin threads meet in the middle of the fabric.
Dec 10, 2015 | Singer 5160 Mechanical Sewing Machine
Tip
Sewing answers
manuals can be found at,
ManualsLib Makes it easy to find manuals online
singer manuals and support,
Customer Support
tips and hints,
Sewing Resources
how to videos,
SingerSewingCompany
presser feet tutorials,
SingerSewingCompany
singer replacement parts,
Replacement Part Availability
parts for ANY machine,
http://www.sewingpartsonline.com/
household machines,
Sewing Machines
industrial machines,
Industrial Sewing Machines
babylock,
http://www.babylock.com/support/faq
singer manuals.
Instruction Manuals
Troubleshooting/Frequently Asked Questions
Please click on any question below to display the corresponding answer.
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
on May 24, 2015 | Sewing Machines
Singer 2517c. When sewing, the bottom stitch is using to much thread, excessive amounts & the stitch isn't tight. I've tried all settings & have used a new bobbin. I'm at a loss......
Your description isn't very clear. When you say the "bottom stitch is using too much thread" Do you mean you see lots of loopy threads on top of the seam? Or do you mean you see loops on the bottom under the fabric? If your loops on the bottom, that means the top tension is too loose, you've not remembered to put the presser foot down, you have not threaded the top thread properly... Start by rethreading carefully with the presser foot UP. Then do a test stitch, remembering to put the presser foot down. If you still get loops underneath... tighten the tension.
If your loops are on the top of the fabric. loosen the top tension... then do a test seam... and if you still have loops loosen again and repeat. If you start to see loops on the bottom... tighten the tension a bit.
Good luck
Dec 30, 2012 | Sewing Machines
Thread doesn't loop, it will not sew
try changing the needle
try rethreading the machine top & bobbin
make sure the bobbin is not over full
make sure the bobbin is turned the right way in the bobbin case
if these suggestions don't help then the sewing machine timing
needs to be checked at a sewing machine shop
Oct 03, 2012 | Brother CE5000 Computerized Sewing Machine
New Home ss2015 machine. I am having trouble with the thread tension. I have loops on the bottom. I have cleaned the bobbin case, changed the needle, re-threaded and moved the upper tension all the way up....
try adjusting the top tension to 3 & if it doesn't stop the looping, try 4 but I wouldn't go any higher than 5,, if changing the top tension doesn't help then I suggest taking the machine in to have it serviced. the bottom tension is more difficult to do,, it's also very possible that the top tension dial is messed up & needs replacing. only a sewing machine shop can tell for sure.
Mar 02, 2012 | Sewing Machines
I have a singer 7258 that I can not get the tension to loosen up on. The top stitch is straight across and adjusting dial doesn't help.
Hello
Adjust the tension
Load your sewing machine with one color on top, threaded through the needle. Load the second color thread into the bobbin and thread.
Fold the scrap fabric in half, and sew a straight stitch at least 2 inches long. Look closely at the seam. If you see loops of the bottom color thread on top of the fabric, proceed to Step 3. If you see loops of the top color thread on the bottom of the fabric, proceed to step 4.
Loosen the top tension. Since the top tension is so tight, it is pulling the bottom thread up through the fabric. Loosen the top tension by turning the numbered knob on the front of the sewing machine counterclockwise by one number.
Tighten the top tension. Since the top tension is too loose, the bottom thread is pulling the top thread down through the fabric. Tighten the top tension by turning the numbered knob on the front of the sewing machine clockwise by one number.
Sew a straight stitch 3 inches in length. Check the stitching. It is perfect if the threads meet in the middle, and you can only see the top thread on top and the bottom thread on bottom. If it still needs adjusting, go back to step 2 to repeat the needed steps.
Using two different colored threads makes it easier for you to see which thread is being pulled.
Always use proper precautions when working with electrical machines.
Aug 01, 2011 | Singer Sewing Machines
My singer model 237 makes a stitch that doesn't look right. The bottom thread is just goes through the top thread loops under the material
Hi, if stitches are off, there is a problem with balance between the upper and lower stitch adjustments. You have to tweak these. Also, make sure there is no lint in the bobbin case area or under the feeddogs. Here is an excellent blog for 237 Fashion Mate owners. You are lucky to have one of these from the 1960's. http://blog.sew-classic.com/2010/02/02/singer-237-fashion-mate-sewing-machine-reveiw.aspx
Happy Sewing!
Jul 17, 2011 | Singer Sewing Machines
I purchased an older Singer Stylist zigzag model 457 sewing machine at a garage sale. It doesn't have the owners manual and the bottom thread gets all knotted up. It also is hard to feed the material...
I can definitely help you with the owners manual. Go to http://parts.singerco.com/IPinstManuals/457A_105_125_135_143A.pdf and you can download it direct from singer, no viruses, nothing. Just save it in Adobe format.
The bobbin thread problem is called a birds' nest and can be from a number of problems. First thing to do is to change your needle, especially if it was the one you bought the machine with. It may look perfectly straight to the naked eye. But it only needs to be a little bent to cause a problem. If this doesn't clear the problem up, make sure you're using a new bobbin, freshly wound. If the bobbin isn't wound properly or is an old bobbin that's slightly bent or not quite round, it'll cause problems, too. Finally, the machine may need a new bobbin casing. Do a google search for Singer sewing machine parts and search for a bobbin casing for a model 457. You'll remove the plate from the top of the machine CAREFULLY (the screws are small, so be careful not to lose them!). Take pictures if you need to with your cell phone so you can see what to do when you need to put the new casing in. Bobbin casings are usually $25-30. This is the last thing, and I would only do this if you see that thread is catching on something in the bobbin area when you're moving the wheel by hand.
I've tried to be clear on the last bit, but I realize it can be a little awkward. If you need any other help with that, please leave me a comment back. It goes straight to my email, so I'll see it quick and will get back to you right away. The manual doesn't help a lot with your bobbin problem, so I'll do whatever I can to help you through it and get you sewing. Good for you for finding a great garage sale find!
Jun 08, 2011 | Singer Sewing Machines
Sewing Machines Logo
172 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
