Question about Aiwa PX-E860 Turntable
Can't remove platter after removing lock washer
I've removed the lock washer for the turntable, but I can't remove the platter. I need to replace the belt, and I assume I need to take the platter off. Does the platter just lift off or do I need to unscrew the middle thingy?
  • 42 Answers
It should just lift off, but might be a little stiff.
Posted on Jan 25, 2009
How to remove Platter on JVC L-A120 Turntable
Hi Jeff...
The platter on the JVC LA-10 does not come off as most turntable platters do. It is attached to the spindle with a Philips head screw.
Here are the steps:
Remove dust cover from turntable. Unscrew hinges and lift.
00.jpg" alt="Remove dustcover at hinges.">Remove dustcover at hinges.
  • Secure tonearm to prevent stylus damage.
    00.jpg" alt="Secure the tonearm.">Secure the tonearm.
  • Remove slipmat from platter.
    00.jpg" alt="Remove slipmat.">Remove slipmat.
  • Turn the turntable on its side and remove screws that hold the top to its base. Remove platter by unscrewing the bottom plate from the turntable. The spindle bearing is held in place with a Philips head screw. Loosen it and the platter will separate easily from the spindle.
    00.jpg" alt="Separate the spindle from the platter by loosening with a Philips head screwdriver.">Separate the spindle from the platter by loosening with a Philips head screwdriver.
  • Loop replacement band around the pulley cylinder in the motor. Replace platter and bottom plate. Tighten spindle screw. Test the new belt by turning the platter clockwise two or three rotations. Belt should fit snugly and turn with little resistance.
    00.jpg" alt="Test the replacement belt by turning the platter clockwise.">Test the replacement belt by turning the platter clockwise.
  • Feb 05, 2016 | JVC Audio Players & Recorders
    How do you remove the turntable?
    It depends on the turntable you have. For example Dual turntables with idler wheel drive have a spring round the platter's axle which has to be remove. Some Dual belt drive turntables have a bajonett lock, other a lever to be moved and some have only weight fixed platters. Most platters of direct drive turntalbles are just fixed by their weight and are removed with a strong pull. Greetings from northern gemany
    Nov 08, 2015 | Audio Players & Recorders
    I HAVE A PIONEER PL-30 TURNTABLE AND I NEED TO REMOVE THE 'PLATTER' IN ORDER TO REPLACE THE BELT. THERE IS NO CLIP TO REMOVE. HOW DO I GET THE 'PLATTER' OFF. AGAIN THERE IS NO CLIP FOR REMOVAL.
    Pull up on the platter with one hand after you remove the rubber mat. Then hit the center post with a rubber mallet while pulling up on the platter with on hand just hard enough to release the platter from the post. The platter should come off.
    Aug 06, 2013 | Pioneer Audio Players & Recorders
    Need to replace the belt, but I can get the Platter off. How do I get the Platter off on my Pioneer PL-30 turntable
    Take the bottom off and there may be a round cylinder that should be filled with oil and a cap that screws off. Remove the cap and I think there is a clip that needs to be removed.
    Aug 05, 2013 | Pioneer Audio Players & Recorders
    Need Instructions to replace belt on panasonic SL-5N Turntable
    To replace a turntable drive belt.
    1, Remove the rubber platter mat to expose the platter.
    2. Put your thumb and forefinger through the two round holes and lift the platter off. You may need to give the center spindle a light tap (whilst applying upward pressure) with a screwdriver handle or some similar tool that will not leave any marks or damage.
    3. Remove the old belt and wipe the platter pulley and motor pulley with an alcohol swab to remove any old belt residue.
    4. Place the new belt around the platter pulley making sure t is sitting flat without any twists.
    5. Flip platter over the right way up. There are1or 2 larger rectangle shaped cut outs in the platter.
    6. Through the cut out pinch up the belt and slip a finger or belt hook between the platter pulley and the belt gripping the belt ready to fit over the motor pulley.
    7. Align the center hole of the platter with the spindle and place platter back into position keeping a grip on the belt.
    8. Slip belt over motor pulley and give the platter a light clockwise rotation to ensure the belt is riding correctly.
    9. Replace the rubber mat and then run the turntable to ensure correct operation.
    Job done.
    Apr 11, 2013 | Audio Players & Recorders
    Need to replace the belt on my JVC AL-A95 turntable
    To replacea turntable drive belt.Copyright.. Styluscity.com, JohnHarrison. Nov 2011Before starting any work on yourturntable disconnect it from the mains power supply.Remove the stylus or completeheadshell to prevent any accidental stylus damage.1. Remove the rubber platter mat toexpose the platter.
    2. Put your thumb and forefinger through the two round holes either side of thecentre spindle and lift the platter off. You may need to give the centrespindle a light tap (whilst applying upward pressure) with a screwdriver handleor some similar tool that will not leave any marks or damage.
    3. Remove the old belt and wipe the platter and motor pulleys with an alcoholswab to remove any old belt residue.
    4. Place the new belt around the platter pulley making sure it is sitting flatwithout any twists.
    5. Flip platter over the right way up. Acorrect fitting belt will stay put and an over belt will fall off.
    6. You will see 1 or 2 largerectangle or square shaped cut outs in the platter near to the outer edge. Throughone pinch up the belt and slip a finger or belt hook between the platter pulleyand the belt gripping the belt ready to fit over the motor pulley.
    7. Align the centre hole of the platter with the spindle and place platter backinto position keeping a grip on the belt.
    8. Slip belt over motor pulley and give the platter a light clockwise rotationto ensure the belt is riding correctly.
    9. Replace the rubber mat and then run the turntable to ensure correctoperation.
    MUSIC IS LIFE, LIVE IT LOUD.Styluscity.com cansupply replacement drive belts for all turntables
    Oct 08, 2011 | JVC AL A158BK Turntable
    Instlling the turntable belt
    What is the make and the model number of the turntable? I do know that the record platter is held on by gravity and lifts off most truntables I've replaced belts on, then it is just a matter of threading the belt over the motor pulley, most time you can do this from up top once the platter is removed, at worst you remove the bottom to thread the new belt onto the motor pulley.
    Jun 07, 2011 | Audio Players & Recorders
    How to remove the platter in Gemini PT-2400 Turntable
    hi,
    firs of all remove from the mains. pull out the rubber bed over the platter. check whether there is any lock washer in the center shaft. if have remove it. if not its ok. now pull the platter towards upside by putting the fingers in to the holes provided on the platter. remember pull using ur two hands in opposite direction.
    ok
    Dec 30, 2010 | Gemini PT-2400 Turntable
    Belt replacement
    http://www.archive.org/details/Turntable_Belt_Installation
    above is a generic video that applies to almost all turntables including yours that will show how to install the belt an a few other things.
    Nov 08, 2008 | Aiwa PX-E860 Turntable
    How to remove platter on Optimus Lab-1100 Turntable
    on the shaft in the center where the hole of the record goes there is a locking washer on it . you can carefully remove this with a thin knife of something similar . you may need to use a little force , it is on there pretty tight however it can be removed .good luck
    Jul 21, 2008 | Audio Players & Recorders
    Aiwa PX-E860 Turntable Logo
    962 people viewed this question
    Top Aiwa Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
