Question about LG RUMOR Cellular Phone
Micro sd 4gb micro card.
I just bought a micro sd card with that adapter thing and took it home excited to finally get music on my phone. and tried to open the removable disk. it comes up on my computer a removable disk D:\
it would show the hour glass thing kinda freeze then an error notice would come up saying
"D:\ is not accesible
the request could not be performed because of an i/o devise error."
when i right click on the icon for the removable disk and find properties it shows that it can read how much space is on there. so it can read it.
so what does that mean?
bad card? bad port?
the port reads other memory cards....the 2gb card for the digital camera works fine in it.
what to do? i have the same exact problem
and i jus bought the micro Sd card
the brand is duracell
my Lg rumor phone recongnises it .. but my computer doesnt
when i insert th card a green light goes on the indicates that the computer knows the card is there.. buh when it comes to opening it .. it says that its not accessable
iv cheked the device manager
everything is fine
when i use the usb port for the micro sd card it says insert a disk into drive K
please help
  • 3 more comments
  • Joseph Zajdler
    Joseph Zajdler Jan 05, 2009
    I also bought the Duracell 4GB MicroSD with the SD & MiniSD adapters and a USB adapter, the MicoSD works in my phone, when I use the SD adpater, it works in my camera, but it will not work in my PC when I use the USB adapter. The adapter appears as a Removeable Disk (FAT 32) without the MicroSD card in the adapter, and when I put in the MicroSD, nothing changes, If I use my 64MB MicroSD, the USB adapter works, but when I use the 4GB MicroSD, "Forget About It".
    Oh and BTW, I purchased two, same problem.
    Maybe I should stick to buying Alkaline batteries from Duracell and get my memory cards from SanDisk.
  • Anonymous Jan 23, 2009
    Laptop: Alienware less then a year old and it can read sandisk micro, but not the 4gb duracell. Think it may be formatting of the card?
  • empower2drm Jan 23, 2009
    Laptop: Alienware less then a year old and it can read sandisk micro, but not the 4gb duracell. Think it may be formatting of the card? Thought maybe it was the adapter inside the adapter requirement as I know some computers dont read inside of things inside of things. Tried old 512 sandisk in duracell adapters and it works, so then tried another computer same issue, so it is the actual disk. The microsd duracell disk looks exactly like the sandisk mirco, so that looks good. Thinking the simple issue could be formatting, but the worse issue could be bad board inside the sandisk??
  • lake_monster Feb 21, 2009
    So my 4 GB duracell mini sd doesn't fit into my SD/MMC slot on my pc. I have the card inserted into both adapters & it just doesn't fit. It comes close to fitting, but it doesn't "click" into place. My computer is a fairly new Dell XPS. What am I doing wrong?
  • upyrice May 11, 2010
    Solution link . . . http://www.LG-RUMOR.com
Guaranteed solution!
This is from Duracell Support
Unfortunately, we have found an incompatibility with a new revision of our microSD and the USB adapter that accompanied the card you purchased. We are in the process of solving the compatibility issue. We are truly sorry for the inconvenience and would like to send a new card that is compatible with your USB adapter. Your original card should be functional in other adapters, phones, and cameras. The microSD card's compatibility problem should only exist with that USB Adapter. For your inconvenience, there will be no need to ship the original microSD card back to us so feel free to keep and use them both. We would also like to send you two free music downloads from Duracell Flash Memory.
If you would like to take advantage of this offer, please let us know your full name, address, the size of the microSD, and the name and location of the store from which you purchased your microSD. When we receive your information we will ship your replacements parts and music downloads immediately.
Best Regards,
Duracell Flash Support Team
Here is how to reach them:
http://support.duracellflash.com/ics/support/default.asp?deptID=5612&ticketID=7688933
Posted on Jan 29, 2009
Go to BestBuy and buy a USB SD reader that says, "SDHC". Test the 4GB card on the new reader.
None of you mentioned "microSDHC". All 4GB "microSD" cards are actually NOT microSD, they are microSDHC. Older readers that were compatible with microSD (probably with a sleeve to make it fit in an SD slot), are often NOT compatible with microSDHC. If your 4GB Duracell card (or any other 4GB) is your only 4GB card and all your other "working" microSD cards are 2GB or less, there is a good chance that the problem is actually due to your reader being obsolete. There is no firmware update or driver that you can download to make such readers compatible with the new technology and there are no microSD cards larger than 2GB. I know the Duracell cards are not actually made by Duracell and are just as high quality as any other brand you'll find out there.
Posted on Feb 10, 2009
I had the same problem with my duracell 4gb sd card for my rumor. I used it on my laptop and it didn't recognize it, so i tried my mom's and it also didn't recognize it. finally i tried my brother's computer and it read the card. I think it might be that the card can only be read from newer models of computers.
So its all great for me until ii try to drag and drop music onto the card and it comes up with a "Error while copying to "disk"." message. it won't let me put any type of file on it.
Posted on Jan 09, 2009
3 Suggested Answers
pleaseandtha
SOURCE: micro sd 4gb micro card.
It is happening on my phone as well
a card thats aleways worked all of a sudden Shuts my phone of when I go to music.
this voyager..may be worse than my chocolate. sad to say.
Posted on Aug 03, 2009
adhiwahyudy
  • 64 Answers
Follow this link to solve it, http://www.fixya.com/support/r4391734-usb_flashdisk_pen_drive_write_protect , and dont forget to report to me ... good luck
Posted on Mar 22, 2010
I have a PYN 4gb micro sd problem
Try to reboot with the card inside the comptuer. If that doesn't work then try another computer and use your last resort as attempting to replace the card adapter. If you can access data from your phone then the card is not bad.
Jul 04, 2009 | SanDisk 4GB microSD High Capacity Memory...
Having problems playing music frommy sandisk 4gb micro memory card on my motorola ve240 cell phone
I have a similar problem, the issue for me was windows media player was creating a folder called music on my sd card and uploading the music there during sync function. However, the phone only looks in the \my_music folder on the SD card. Sync your phone, then rename the newly created music folder to my_music and the player will work. Still looking for a permanent solution to this problem.
Apr 27, 2009 | Motorola Mobility MOTORAZR VE20 Cell Phone
I HAVE BOUGHT A SANDISK 4GB MICRO SD HC CARD
What phone? Check user manual of phone to see if the music has to be in a certain folder on the card. Try reformating the card.
Apr 25, 2009 | SanDisk 4GB microSDHC Memory Card
My computer nor samsung alias wont read my 4gb pny microsd chard
I doubt that your phone accepts the 4GB version of the micro sd card, try the 2GB
Feb 22, 2009 | PNY 4GB microSD High Capacity Mobile Media...
Something is wrong with the card. Maybe it's corrupted.
But what your computer means by I/O Error is Input/Output Device Error, which means the card has issues.
Hope this helps!
Jan 27, 2009 | LG VOYAGER VX10000 Cellular Phone
Jan 12, 2009 | Samsung Rugby SGH-a837 Cell Phone
Cant instal micro sd card to samsung E250
Hey! samsung SGH-E250 doesn't support 4GB memory card. Try a 2GB or 1GB memory card.
Jan 04, 2009 | O2 Samsung SGH-E250 Cellular Phone
PNY sayes you need a drive installed from their site. The problem is you can't get to this driver through their site, so I have emailed them at this time to fix the link.
Try them in a couple weeks maybe they will have fixed it by then.
GW
Aug 18, 2008 | Computers & Internet
Pc sd card slot does not read sd card adapter with micro sd
heya have a 4gb micro sd for my mobile phone i can put music and stuff on it but the phone wont read the card my friends say i have to activate it first how do i do this thanks>>>
Jun 19, 2008 | Cameras
LG RUMOR Cellular Phone Logo
2,138 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
