Question about Amana ASD2626HE Stainless Steel Side by Side Refrigerator
Relay on compressor clicks, but does not run
The fridge is cycling about every 3-5 minutes, the relay on the compressor clicks but the compressor does not run, the click lasts about 5-10 seconds and then shuts off. the compressor never comes on. ECM motor is running and it appears in side fans lights water disp etc is working fine.
  • w_hoots Jan 07, 2009
    hey, thanks for the tip. looks like a shot compressor though. changed out the ol relay/cap and still same symptoms
  • 163 Answers
Hi!!! change the current relay in your compressor easy fix..its located inside the case where the wires go connect to the compressor..good luck..
Posted on Jan 04, 2009
My Whirlpool ET18NG will not get cold. When Plugged in both fridge and freezer get very hot. Had it plugged in for 3 days without any cooling
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Aug 25, 2010 | Kitchen Ranges
Maytag Fridge MTB2156GEW Won't cool. Change thermostat today and ran it for four hours. Frige was warm after. There is a clicking noise every 2 to 5 minutes from the back of the fridge. I think it is
Yes you have a bad relay on your compressor.Remove the rear panel and take off the relay on the compressor shake it.If it sounds fried then you need to order new on .Just give your model# to your local parts depot and ask them to order you a new compressor relay hope i fixya:)
May 20, 2009 | Maytag MTB2156GES Top Freezer Refrigerator
Clicking noise coming from refrigerator
If the "clicking" noise is from a relay on the board or compressor, it's likely th compressor would be cycling on and off.
It could be a fan blade (evaporator or condenser) hitting something. Both fans only run when the compressor is on. This should be addressed ASAP as it could be a wire it's rubbing on.
Finally, the noise could be caused by the refrigerant within the sealed refrigeration system. This noise is more of a nuisance rather than a mechanical failure.
Apr 27, 2009 | Refrigerators
Whirlpool side by side not cooling
wihtthe modle number you can look up a part, try replacing the overload/relay( starting device) for compressor, may be bad compressor( in which ase youll need a professional) but the overload relay you can do yourself for about 60-75 bucks
Mar 28, 2009 | Refrigerators
I have a Kenmorre model 61161 series,that does not freeze or cool
The cycling sound may be a bad compressor relay or a bad compressor.
Do you hear a click about every 2 minutes?
If so, replace the compressor start relay.
Feb 21, 2009 | Kenmore Refrigerators
Problem has returned to Maytag fridge
I note this is a very old post. The compressor is not starting and what you were hearing was the PTC relay energizing followed by the KilXon thermal overload kicking off the compressor start sequence. What happens is that the PTC relays sometimes get a heated contact. Due to the weakened state of the contact it can cause a buzz. Even with a goo PTC relay you would hear the compressor buzz if it was not starting. In that case the run capacitor may have failed or the compresor rotor is internally locked at which point the start cycle will repeat every 3 to 4 minutes as the thermal overload cycles and the compressor will not start.
Thanks for choosing FixYa
Kelly
Jun 18, 2008 | Refrigerators
Fridge not cooling compressor works intermitently
If the compressor starts and runs for a few seconds it could be the relay. Or it could be the compressor itself has failed. When a compressor starts and runs for a short period it is possible that the relay contacts are arced together which would have both the start and run winding in the motor engaged at the same time for more than 3 seconds. This would result in the compressor tripping out on the thermal overload. It depends on what type of relay your compressor has. If it is a thermal relay, unplugging the refrigerator for about 15 minutes would allow the relay to cool off and reset.
May 10, 2008 | Refrigerators
Every 2 mins the compressor tries to go on and after 15 seconds stops.
If the compressor tries to go on every two minutes, then the relay is functioning.
1. If the compressor has failed, it might be getting hot and tripping the thermal overload to shut itself down. It will cycle like you say and will be unable to cool the fridge.
2.It's also possible that you have lost refrigerant from the system. When the compressor goes on, the pressure drops below a threshold value. The system sees that there is not enough pressure, and shuts down. Once the pressure rebuilds, it tries again.
3. If the fins in the rear of the fridge are clogged with dust/debris, the system will not be efficient enough to cool. I doubt this is the case as the compressor would generally just stay on for a long time... longer than 2 minutes.
Try turning the thermostat to the coldest setting possible for both the fridge and the freezer. If the unit still cycles off after 2 minutes, consider repair.
Mar 14, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Compressor cycles
Yeh The klixon relay is not at fualt its the compressor im sorry to say that in my opinion that the compressor has failed.
the clicking sound is the compressor trying to start but inside its all burnt out and jammed.. If you need any more help or adivice then dont hesitate to ask
Jan 03, 2008 | Refrigerators
Amana ASD2626HE Stainless Steel Side by Side Refrigerator Logo
245 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
