Question about Maytag MGR6775A Gas Kitchen Range
Natural gas orifice diagram
Diagram
2 Suggested Answers
krb55
  • 604 Answers
SOURCE: Trying to change Maytag Gemini
take the covers off the burners and look, the jets are near the burners, small wrench to turn them out and replace with the other jets. the oven is a different story, and depending on you model may not even have jets that can be replaced, rather you adjust the one jet that's in there by turning it with a wrench (you should have gotten a book that helps with this)
Posted on Mar 19, 2011
Convert lp natural gas
To convert a lincoln LP gas oven to a natural gas, you actually first of all need to buy from the supplier an orifice ment for natural gas and change. The difference in the orifices could be in the size of orifice aperture.
The orifice i'm talking about is located in the burner assembly. you got to dis assemble the burner so as to get to it.
After that you need to adjust the main gas manifold when the oven is on. The adjustment must be done such that the pilot flame is not yellowish
Jan 28, 2014 | Lincoln Ovens
How do I convert from liquid propane to natural gas
You need parts from the manufacturer. The gas orifices are different sizes between natural gas and LP gas. If you try natural gas with an LP gas orifice, you will not get much flame. If you use LP gas with a natural gas orifice, you will burn off your eyebrows and possibly other things.
Dec 19, 2013 | Capital Cooking Titanium X CCE26XRBI (NG)...
Model# BWH30NLTB
Unit goes under sure heat name also.
My unit emitted unburnt gas smell the minute pilot started,
and was annoying during burner operation.
I discovered they built unit with primary pilot that had 2 ports.
They used LP and sealed off natural gas,instead turning lp/nat
knob on back activates second pilot for natural gas use.
This means natural gas goes thru LP pilot orifice and burns
slightly off during normal natural gas use(by design).
The unused natural gas orifice has 1 air mix hole and the LP orifice
has 2 air mix holes.
I carefully plugged 1 of the holes in the LP orifice and suddenly
pilot gas flame seated correctly on orifice port.Gone was the
unburnt odor of natural gas.
The typical flame in a flame appearance now was exhibited by
the small pilot,secondary pilot remained consistent with manual
picture.
Of course, to use with LP I would have to open blocked air mix
hole in addition to the other changes per manual.
Hope this helps someone with similar condition.
Dec 31, 2012 | Reddy Heating & Cooling
Instuctions on how to change a pitco fryer from nat gas to propane
Hi there!
You need to order a gas valve conversion kit (from nat to propane), propane pilot orifice and propane burner orifice,
Gas valve conversion kit consists of a replacement spring thicker than of natural gas valve spring, gas valve cap and a sticker.
Pilot orifice for propane has smaller bore than of natural.
Burner orifice for propane has also smaller bore than of natural burner orifice (one for each burner).
You will be able to find these parts on the list of Pitco Distributor when you visit http://www.pitco.com
Regards.
Jul 08, 2012 | Pitco Frialator E24 Deep Fryer
I have a small counter top fryer set up for lp gas how do i change to nat
check the supplier for the conversion kit.the kit contains burner orifice, pilot orifice and gas valve spring which are commonly needed for conversion from propane to natural gas or from natural gas to propane.
****natural gas orifice has larger bore than propane, gas valve spring for propane is thicker than for natural gas.
Mar 29, 2011 | Cecilware FMS-40 Deep Fryer
I converted my 40'' Figidaire range to LP a few years back when I did not have access to natural gas. Now I need to convert it back. I do not still have the old parts and there seems to be no ''Natural gas...
I am having almost the same problem. Frigidaire told me to replace all 5 mixing tubes, ~$385, yeah right. They don't have the orifices itemized as an individual part, so no-one carries them, just the LP conversion kit. Another repair/parts guy advised me to drill out the orifices. Some other threads/blogs give the diameter to drill. Basically, since natural gas is 0.5 psi, you need a larger hole than your current propane orifices provide. Please speak up if you find out anything, I will try to do the same. Good luck.
Sep 25, 2009 | Frigidaire PLCF489AC Dual Fuel (Electric...
Setting the regulater from propane to natural gas
check your manual or check inside regulator valve you see lpg and ng turn it to ng
Mar 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
Converting a GE Profile Gas Range from LP to natural gas
GE ships gas ranges set for natural gas, with the LP orifices included, usually on a metal tab held with one screw right near the regulator (where the gas connects to the range). If the range was converted to LP, the person who did the conversion was suppose to put the natural gas orifices back in that holder. If they are missing, comment back on the exact model number and I can look up the part number(s) for you.
Jan 06, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Converting a range from LP to Natural gas
Yes, it is possible.
You have to get the right orifice's for Natural gas. LP gas orifice has twice the size hole as compared to Natural Gas. Using it without the right orifice will put out way too much gas, and you will burn everything, as well as it will be a fire hazard.
Your local gas company or propane company should be able to get you the right orifice
Please rate this solution.
Jul 31, 2008 | Jenn-Air ® 48" Professional Over The...
Maytag MGR6775A Gas Kitchen Range Logo
27 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal De GO PATS
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
