Question about HP Mini 1000 Netbook
How do i snap the bottom back on my hp mini?
I dropped it on the floor twice. The first time I dropped it the bottom was partly of so i snapped it on but the second time I dropped it, It completely came of and I cannot put it back on. How do I fix it?
    Top Expert:
  • HP Master
  • 14,553 Answers
Without seeing it and if unit still works a shop might be able to fix this---me, I would get a tube of GE Silcone I or II and glue it at the places where it will hold without the Silcone getting on any of the circuit boards===enough to hold in place but not so much it cannot be pulled off.
Posted on Nov 03, 2012
3 Suggested Answers
  • 111 Answers
SOURCE: i've had my hp mini for one day and the plastic
If you've only had it one day, why don't you return it?
Posted on Mar 05, 2011
technolust
  • 340 Answers
SOURCE: I have an hp mini and the power switch on the side
Hi There,
It sounds like you've broken the post that acts as a snap action switch to turn on your laptop. With that post broken, you will still physically be able to move the switch back and forth, however the snap action will not work and your laptop will remain off.
You can fix it yourself, it's not terribly ******* a netbook but for someone without experience it can be confusing, here is a link to a disassembly video: http://www.google.ca/url?sa=t&rct=j&q=hp%20mini%20disassembly&source=web&cd=2&sqi=2&ved=0CFsQtwIwAQ&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3Dq2xQUT9NbIg&ei=B6XPT47GG7Ky0QH0pumkCA&usg=AFQjCNFdTsIR3hOFdu_OfA_b3sAHpYbXxQ
A repair shop should be able to fix this issue for you in under ten minutes and under $40.
Posted on Jun 06, 2012
Can't get hose back on model 2E200
Fit rounded side into the top red part first. The flat side is toward the bottom black part. Then push the bottom on until it snaps in place on each side.
Feb 21, 2014 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
How do I rebuild my dyson
without more information id say pull U shaped pipe off bottom and then re-install new hose at bottom then slide handle down into it snapping it in at top. if this doesn't help please feel free to respond with more info and maybe a pic
Jan 08, 2013 | Dyson DC07 All Floors Bagless Upright...
I have an hp mini and the power switch on the side is broken. Normally if you slide, it will snap back and the laptop will turn on but now it just slides back and forth and the laptop won't turn on?...
Hi There,
Jun 06, 2012 | HP Computers & Internet
I unhooked my computer system to put laminate floor down. Then rehooked everything. Now the printer HP photosmart c5580, after a few minutes the power button and the print photo button and the close up...
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
Good Luck!!!!!
Sep 13, 2011 | HP Photosmart C5580 All-In-One InkJet...
My gs6shexmb00 Whirlpool ice dispenser mechanism is loose and does not close the ice shoot 'door'. I also have a loose part, kind of like a piston (round with a stem that swivals). Trying to find out how...
I just repaired mine. There is a metal pin that acts as a hinge that slips into a hole on one side and snaps in place on the other side. All I had to do was snap it back into place. For someone that is mechanically apt, it's pretty simple to figure out once you remove the cover. To remove the cover work from the bottom with a flat head screw driver. Do not insert it too far or you'll be prying on the dispenser itself.
There's no way to know for sure that yours is exactly the same as mine. There are certainly parts that could break and cause the same problem. When I first snapped it back into place I had the black closing delay mechanism misaligned. It's a very simple piston whose cylinder needs to be perpendicular. Keep an eye on it, or you'll have to remove the cover twice like I did.
May 15, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
HP Mini 1033CL intermittent or no sound
Probably something was touching the speaker cone and you snapped the speaker back so it no longer touches.
Oct 22, 2009 | HP Mini 1033CL Netbook
Remove door panel off passenger side window will not got up
there are snaps or plugs that attatch to your door panel and penetrate your door. They look like a T. They will line the bottom and sides of your door. Make sure to have replacements because I can about guarantee that some will break when removing the panel. take a flat screwdriver and insert it in between the door panel and your door. Pry up, attempting to get as close as possable to the snaps themselves. You can lift with your fingers and tell which parts are more sterdy than others. Pry near the sterdy parts because that is where the snaps are going to be. I also like to start at the outside corner of the door panel. there should be roughly 6-10 snaps on the entire door panel. after you get that part done, simply lift on the door panel and the top should slide out of it's holding place. Installation is opposite of removal: drop the panel into the notch at the top, and pound on the door panel where new snaps are, make sure they are alligned with the holes where they need to penetrate.
Oct 03, 2009 | 1992 Oldsmobile Cutlass Ciera
HP Mini 1000 Netbook Logo
44 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
