Xerox Workcentre 3210 automatic document feeder jams when there is only 1 page
Automatic document feeder jams when there is only 1 page or on the last page of multiple pages.
5 Suggested Answers
SOURCE: Dell 1815dn jam in automatic document feeder on last page.
Message saying document Jam but can't find any paper stuck anywhere. Do you have any suggestions?
Posted on May 03, 2010
Arius
  • 446 Answers
SOURCE: Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Posted on Jul 28, 2009
bbaditz
  • 75 Answers
SOURCE: Using automatic feeder to scan a multiple page doc into 1 PDF
Yes you can scan up to 30 files in one pdf , and you have to put documents in auto feeder (face up) and from the pc, scan menu, scan to files, select destination and extension.
That's all
Posted on Mar 04, 2010
CreativeTECH
  • 1719 Answers
SOURCE: The document feeder of my
Paper jam usually happens due to dirty or in some cases worn out paper pick up roller. I think, cleaning the pickup roller would fix the issue. Remove the paper input tray. Open the top cover (ADF) by pulling it from the back.
Inspect for any tron peices of paper dirt etc. Locate the rollers and clean them with a soft, damp, lint-free cloth. Also, you may clean the Sheet-fed scanner (Mirror and white platten) for better copy/ scan results with a dry cloth. DONT USE PAPER, CHEMICALS OR ANY ABRASIVE CLOTH as it may damage the parts.
Moreover, make sure that the paper you are using is atleast 80gm.
Hope it helps! Good Luck!
CreativeTECH
Posted on Apr 09, 2011
I have Xerox M 20i .When ever I feed papers from ADf. Print is not coming normal.Some time it shrink the text,I checked the roller are fine.
The Xerox is a business machine and has a setting to reduce the size of scans by percentage.
Read the instruction manual to turn it off or play with the buttons.
WorkCentre M20/M20i Documentation - Xerox Support and Drivers
www.support.xerox.com/support/workcentre-m20-m20i/documentation/enus.html
  1. Cached
  2. Similar
Product documentation for WorkCentre M20/M20i. ... WorkCentre M20/M20i Firmware Installation Instructions. Setup and Installation Guides. Description.
[PDF]WorkCentre M20i System Administration Guide - Xerox Support and ...
www.support.xerox.com/support/workcentre-m20i/file-redirect/enus.html?...en... Xerox WorkCentre M20i System Administration Guide. Page i. Table of Contents. 1 Welcome ................................................................................. 1-1. Introduction .
Xerox 20i Google Search
Nov 19, 2016 | Xerox Office Equipment & Supplies
Xerox WorkCentre 7120 error code
Chain Description 001 Cover and Door Interlocks 002 Touch Screen / Control Panel 003, 041, 045, 123 Machine Communications 004 Drives 005 Duplex Automatic Document Feeder (DADF) 061, 062 Scanner, DADF and ROS 007 Paper Supply 008 Paper Feed 009, 089 Xerographics 010, 011 Fuser, Copy Exit 012, 013, 047, 112 Finisher 016, 124, 127 Configuration, Software, Memory, Hard Drives, Color Server, DFE 018 Network Communications 020 Fax, Software 021, 121 Foreign Interface 022 Job Timers 024, 026, 027, 033 Job Parameters 034, 035, 036, 133, 134 Fax Communication 042 Motor, Fan, Sensor 071 Tray 1 Misfeed 072 Tray 2 Misfeed 073 Tray 3 Misfeed 074 Tray 4 Misfeed 075 Tray 5 Misfeed (Bypass Tray) 077 Paper Path Jam 078 High Capacity Feeder 083, 084 Fax Jobs 091 Drum Cartridge 092, 093 ATC, ADC, Toner 094 IBT, BTR 102 Job Queue 103, 116 Software
Aug 23, 2014 | Xerox Office Equipment & Supplies
My M15i Xerox Workcentre is printing with a vertical line down the page
Solutions for : Vertical Black Lines on Copies When the Automatic Document Feeder and Document Glass are Used Solution : Clean the Drum
  1. Make sure there is paper loaded in the paper tray.
  2. Press the [Menu / Exit] button on the Control Panel.
  3. Press the [Up] or [Down] arrow button until 'Maintenance' is displayed on the Display Screen.
  4. Press the [Enter] button. 'Clean Drum' will be displayed.
  5. Press the [Enter] button. 'Cleaning Drum Please Wait' will be displayed and a sheet of paper will be printed. Toner (Dry Ink) particles on the Drum will be affixed to the paper.
  6. Repeat steps 1 - 5 until the page prints without any Toner particles.
Aug 13, 2011 | Xerox WorkCentre M15i Laser Printer
System error 09,005.40:143310 Xerox workcentre c2424
You either have jammed ink sticks or a bad Ink Loader 200-4711-80
It is fairly easy to replace, if you can get the covers and Document feeder off.
Whit
Item, Inc.
May 06, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
Feb 06, 2010 | Dell 1815dn All-In-One Laser Printer
Document feeder
Most likely there is something in the path.
That feeder is easy to service. But first of all I would take a manila folder adn try and push it through the feeder paper path to clear it of any blockage.
Oct 01, 2009 | Xerox WorkCentre M20 Black and White...
Jul 28, 2009 | Xerox WorkCentre 4150/X Laser Printer
Scanner is jammed
There is usually a scanner lock button on these units, either located under the Auto feeder on the left side, or on the left side of the machine
Jul 17, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
Broken Black Arm on Scanner Attachment (Detects insertion of documents)
Unfortunately, you can't buy the sensor finger by itself. You need the DADF Assy.
Duplex Automatic Document Feeder Assembly
Part Number: 004K07270
Jun 04, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
111 people viewed this question
jasbo
jasbo
