Question about Singer Sewing Machines
My feather wt has frozen up , it just stopped on me one day after lots of sewing at a retreat and I cant get the needle up or down .
I pulled out the bobbin and cleaned that area , please help I miss my dear little machine!
  • 6 more comments
  • sylviaivie Nov 06, 2012
    What model featherweight?  Do you know?
  • hhatfield923
    hhatfield923 Nov 06, 2012
    221-1. I tryed again to figure out what is going on and it seems to have something to do with the feed dogs and the
  • hhatfield923
    plate. The needle hits the plate instead of going thru, yes I ckecked the needle placement
  • sylviaivie Nov 07, 2012
    First change your needle. It's bent or dulled now anyway. Here is a manual for your machine. http://www.ismacs.net/singer_sewing_mach... The service manual is harder to come by. But I found one for about $10 plus shipping. here. http://www.april1930s.com/html/featherwe... Hope you get her fixed.
  • hhatfield923
    hhatfield923 Nov 07, 2012
    Thank you< I was fortunate enough to have a manual. I changed the needle
  • hhatfield923
    hhatfield923 Nov 10, 2012
    I had a friend who also has a feather weight bring hers to quilt group.
  • hhatfield923
    we figured out there is something not right with the feeddog / bobbincase .
  • hhatfield923
    hhatfield923 Nov 30, 2012
    I still need to get it to repair shop , we dont have anyone in town.
  • Singer Master
  • 7,365 Answers
The sewing machine may need to be checked for a timing
problem.
Posted on Nov 07, 2012
The bobbin bucket in my machine stopped spinning and the needle broke each time, it seem to be hitting the metal part below the bobbin bucket. Please help
Posted on Nov 28, 2012
  • sylviaivie Nov 28, 2012
    Sounds like something below is broken. Can you take the bottom off to see the lower workings?
  • Charlene Herbert Nov 28, 2012
    I am trying to do that at the moment
3 Suggested Answers
sew dutch
  • 25 Answers
SOURCE: Top thread won't pick up the bobbin thread
re insert the needle, maybe you did not put the needle up as far as it is to go. Make sure the flat side of the needle is to the back of the machine. Without any thread in the machine hand turn the wheel and look to see if the hook of your bobbin would/could catch the thread (to see if timing is right)
then thread the machine and hand turn the wheel and see what it is doing.
Your timing might be off, but I do not think that is likely. Though it is possible that when the needle fell out, it hit something hard, broke, and pushed the machine out of timing. then you need to bring it in.
Posted on May 26, 2009
Mongo32
  • 111 Answers
SOURCE: Singer 8280 bobbin thread not taken up by needle
needle in backwards?
Posted on Jul 08, 2009
I recently acquired a Bernina 530-2 record with a frozen decorative stitch change lever and needle positon mechanism. I've tried oil and heat, but its still frozen. Is there anything else I can try?
I've worked on several 530-2 machine--recommend liquid Tri-Flow Synthetic Lube alternating with heat. Note: It has taken me sometimes nearly a week to get frozen mechanisms released. Just a lot of patience, persistence, and elbow grease... Focus on those particular areas that are still resistant.
Wheel on right side that controls the needle up and down is very tight...
Jan 30, 2018 | Bernina Sewing Machines
I received a 221 singer feather light as a gift.... Love using old machines. It will not pick up the bobbin thread. When it cycles the top thread hangs up and breaks.
Lucky you!
First thing to always try is a brand new needle. A lot of sewing machine problems are due to an old, dull, bent needle.
Most likely the machine has been knocked out of time--the needle and hook are out of sync. Search for sewing machine timing or take it or service.
https://singer-featherweight.com/blogs/schoolhouse/how-to-thread-a-singer-featherweight
Dec 12, 2017 | Singer Sewing Machines
Stitch selector knob on bernina 600, not Deco, is stuck and cannot select needle position, However the width of stitch part of the knob is working.This knob has 2 parts, needle position and width control
Your machine (Bernina 600 Record) has most likely frozen (seized) due to lack of regular maintenance. Don't panic. It can be fixed with a lot of elbow grease, good quality oil and a hairdryer. The following method has resurrected several Berninas I've picked up as "nonworking."
How can fix stuck needle bar on my Bernina 730
It was working now it seems to be frozen the needle part wont move
Nov 01, 2016 | Bernina Sewing Machines
My needle keeps hitting the presser foot. I cannot see any adjustments to make. I have taken everything off and re tightened.
make sure that you have the right for installed for the sewing pattern involved
the straight sew foot will have a hole that the needle works through but if you have it on button hole , zigzag or any other pattern that moves the needle sideways then the fot will be slotted
check for bent needle or thread tension excessive and pulling the needle sideways on the down stroke
Sep 19, 2016 | Sewing Machines
My machine keeps coming unthreaded
yes, I would suggest checking the needle
make thread tail of 3 to 6 inches for the top thread & bobbin & make
sure they are pulled behind the needle before you start to sew
Jul 29, 2012 | Kenmore Sewing Machines
Old Pfaff 130 machine partially frozen
check carefully around the bobbin holder area as fluff and threads around here are known to jam the shaft
Jan 18, 2018 | Sewing Machines
WHAT NUMBER IS THE NEEDLE FOR THE FEATHER WEIGHT II 117
needle size depends on the fabric you are sewing. #11 is a fine needle, for lightweight fabrics and is basic. Heavier weight fabrics, like denim, require heavier needles#14
May 30, 2010 | Singer Featherweight II 117
Need manual to know how to set tension. Singer Sewing machine Mod.#5932 Serial#N319411147
Singer Machines are probably the easiest to set..
first thing you need to do is remove the thread..
Set you tension knob/wheel to the middle number.
When you rethread the machine, stop when you get to needle. Put the presser foot down and pull the thread. If it pulls hard then so far so good. If it pulls easily, the thread is not thru the tension wheel right. Thread the needle and stitch about 10 inches on a medium wt fabric.
The stitching should feel even on both sides. If the top still is tight, loosen it up just 1/2 number.
So, if your middle number is 4.5, turn it to 4. If it seems loose, turn it to 5.
Kelley
Apr 30, 2009 | Singer Sewing Machines
Skipping stithes
Try practicing on a test piece before moving on to the quilt. Batik fabric is beautiful! I would check the thread size and needle. I tried quilting with invisible thread and had the same problem. The minute I changed to 50 wt.thread and a new needle the problem disappeared. I've found that 40 or 50 wt. thread works best on my Janome.
Oct 19, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Sewing Machines Logo
105 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
