Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca d52w20v 52 in proj tv
Mine is also turning on and off. I have found all kind of capasitators but none with the numbers you give like cp150 any other suggestions?
  • nbettyrn May 11, 2010
    is one of them larger than the other 2?
  • RCA Master
  • 5,138 Answers
The capacitor you are looking for is on the Deflection Board on bottom is 2 boards on left is Deflection board on right side is SSB board it has the turners on it.cp150,cp114,cp120 these are the 3 capacitors to replace if cp150 is puffed up on top.
Posted on Jan 08, 2009
  • ladywinn
    ladywinn Jan 08, 2009
    cp150 2200uf 16v - cp114&120 are 220uf 35v they are green with gold writing on them. all 3 are on Deflection board.
Tv turns of and on 3 times but does'nt start up
The number 1 cause of that is failed capacitors CP150, CP120 and CP114. You can get that repair kit from www.tvrepairworld.com which also contains instructions.
Mar 03, 2010 | RCA D52W19 52" Rear Projection Television
I have an RCA 52" screen TV and I was watching tv and all of a sudden the picture went blank and then the TV shut off. When I try to turn the tv on all i get is a scratching noise and then it turn off. can...
Hello again you need to Rate my solution other wise they are not going to pay me! since i did give you correct answer to fixing your TV ThanK You Replace 3 capacitors cp150 2200uf use 25v and cp114 cp120 220uf 35v.
Dec 19, 2009 | RCA HD52W58 52" TV
Tv will come on for a few minutes then lose power. every time you press power button it will do this. ive checked for loose connections and have found none. please point me in right direction
Deflection Board Bottom left board cp150 2200uf 16v use 25v and cp114 cp120 220uf 35v replace all 3 and resolder all pinns on FBT flyback transfomer
Dec 14, 2009 | RCA HD52W56 52" Rear Projection HDTV
RCA Proj TV (model D52W14) Power light flashes 3 times
Replace CP150, CP120 and CP114. You can get the repair kit for your RCA at the following link. www.tvrepairworld.com the kit contains the capacitors and the CD with detailed instructions.
Sep 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 RCA REAR PROJ. TV WONT TURN ON.
The problem will be the deflection board (left hand side board when looking from back of unit.Part number is 258762 is no longer avaible thru rca but you can contact tristate module or pts electronics-you can even google the part number
Sep 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv wont turn on r52wm24yx51 cant see the next number
Replace CP150, CP120 and CP114 on the deflection board. You can get the repaor kit at the following link listed under RCA repair kits www.tvrepairworld.com
Aug 29, 2009 | RCA D52W19 52" Rear Projection Television
Problem with 52 inch RCA projector t.v
It sounds like the CP150 and or the CP114/120 capacitors need to be replaced, they cost around 3 dollars each and can be found at Radio shack or you can order them from http://servicemanuals.vstore.ca/ and they will send instructions with them.
Jun 29, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Model d52w19 rca projection tv,will not turn on.the green power light blinks three times,but nothing happens.
Thats the eroor for the flyback and CP150 needing replacement you can get the flyback # 259296 and the CP150 at the following link and they give free step by step instructions on how to do the repair.
Mar 06, 2009 | RCA D52W19 52" Rear Projection Television
My 52" RCA rear projection TV will not turn on. Why?
Check cp150 on the Deflection board its the first board to left on bottom. If cp150 is puffed up on top then it is bad so repalce cp114 and cp120 also cp150 2200uf 16v other 2 caps 220uf 35v.
Dec 30, 2008 | RCA D52W19 52" Rear Projection Television
Rca 52 inch projection
I found that CP150 was bad. When looking at it, it is located on the left side board, on the right side of that board in the middle of a C shaped heat sink. When looking at the capacitor it was easy to tell that something was wrong because the top was puffed up. I replaced it with a new one (16 Volt, 2200uF) and it was working again. The part cost less than 5 bucks an took about 10 minutes to replace
Jul 01, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
161 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
