Question about GE 31GT660 TV
GE tv modle 31gt660
GE 31gt660 tv have sound but no picture
    Genius:
  • 1,074 Answers
Have tech repair your tv the video circuit or related circuit is defected.good luck.
Posted on Jun 04, 2007
SOURCE:
My tv has half a picture the other half is white
You hereby reports that the one side of the screen do not display picture, and the other side have. Is it seen vertically or horizontally. Will you please provide a detailed description of the fault you see on screen? google.com/+GopakumarGopalan
Nov 24, 2013 | GE 31GT660 TV
How can I change the picture from envelope to full screen?
change the aspect ratio in the picture settings.
Oct 15, 2012 | GE 31GT660 TV
Remote code for GE TV M#31gt660
It depends on which universal you are trying to program. There is not a set code for all remotes. Every universal manufacturer has there own set of codes. Thanks for using fixya.
Nov 15, 2009 | GE 31GT660 TV
31gt660 TV will not turn on. Makes high pitched sound.
This set has a shorted horizontal output transistor and possibly a bad high voltage transformer. If you repair the set, also solder the horizontal drive for the transistor listed above. Try www.encompassparts.com for parts. the h-ouput transistor is p/n: 223942 and the transformer is 223952 .Thanks and good luck.
Nov 07, 2009 | GE 31GT660 TV
Ge 31gt660 tv
I had the same issue, turns out all I had to do was change the channel to 00, then my games or whatever I hooked up to the component inputs in the back worked like a champ.
Hope that helps.
Jan 25, 2009 | GE 31GT660 TV
GE 60GW948
chech for a shorted horizontal output transistor
Jan 08, 2009 | GE 31GT660 TV
Help
use tv/video or input button to switch to av input
May 07, 2008 | GE 31GT660 TV
GE model 31GT660
Is the brightness in the middle of adjust range? Is the picture
or contrast adjust at 3/4 ? Next,adjust the screen voltage on
lower rear of cabinet = one control is focus and one is screen..
how is the picture now ?..........................T.
Feb 11, 2008 | GE 31GT660 TV
Vertical size adjustment on my GE 31GT660 set
I had the same problem. I found the solution in this link.
http://www.techlore.com/forum/thread/13480/?page=1
The only thing that wasn't clear was how to get into the service menu. With the TV on, press and hold the MENU button on the front panel of the TV and press POWER then press VOL+.
Dec 01, 2007 | GE 31GT660 TV
GE 31GT660 picture is intensly WHITE
The GE (actually RCA) 31GT660 uses the CTC187 series chassis. This chassis is notorious for bad solder joints on the shields around the tuner and microprocessor. When the solder joints on the shields crack, the microprocessor and EPROM lose their ground and the EPROM's data becomes corrupt. The solder joints on the shields will all have to be resoldered and the EPROM reprogrammed or replaced by a qualified tech familiar with the 187 series chassis.
Aug 22, 2007 | GE 31GT660 TV
GE 31GT660 TV Logo
115 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
