Question about Crown Tachometer Jeep Cj7 86 85 84 83 82 81 80 79 78 77 76 J5459418
Tachometer Jeep Cj7 is not working
My tac on my cj7 is not working im tring to chase the wires but cant. anything you can do?
Looking for auto shop in california who specialize in cj7 jeeps
I dont know what part of calif you live in im in so calif and my hobby is working on cjs im a mechanic by trade for 30 some years i work on cjs in my home shop if interested im my services my email is SYLVENT@VERIZION.NET
my name is marty
Aug 28, 2010 | 1985 Jeep CJ7
How to remove starter on jeep cj7
always disconnect the negative battery cable before you work on any electrical. there are two bolts hold the starter and two wires go to it.
Feb 25, 2010 | 1986 Jeep CJ7
Engine compartment wiring diagram for a 88 cj7 jeep v8
The last Cj-7 was built in 1986. And they didn't come factory with a V-8 so you have a conversion of some type. Most factory wiring diagrams aren't going to help much. Sorry
Dec 08, 2009 | 1986 Jeep CJ7
1985 cj7 6cyl starts up just fine and then it wont
Sound like either fuel or ignition. Have you replaced any fuel filters? I would check the condition of the distributor cap and wires as well. Moisture could be a factor.
Oct 08, 2009 | 1985 Jeep CJ7
1979 cj7 dsh lights wont work
If all the fuses are good, try turning the dimmer and see if the lights come on dim. If the lights still do not work, it could be a bad switch.
I would check the headlamp switch with a test light.
Dec 28, 2008 | 1983 Jeep CJ7
83 cj7 wiring
CAN DO THIS BUT IN PRINT IT WOULD BE A BOOK, ALL DATA, YOU CAN SUSCRIBE FOR FACTORYWIRING SCHEMATICS. TH E OLD VEHICLES, LIKE YOURS ARE VERY BASIC, I APPLAUD YOU WANTING TO LEARN. IF FURTHER ASSIS. IS NEEDED, PLS CONTACT
Oct 08, 2008 | 1983 Jeep CJ7
I can get running lights but then my brake lights dont work then i can get brake lights then no running lights i have three wires orange,brown and white its on an 1983 jeep cj7
I think I found the problem, part of the high beam switch was burned, resulting in a loose connection. When I connected the loose wires, the lights worked. My guess is, the wire burned is the relay wire to go from low to high. I am going to replace the switch, hopefully this will solve the problem, I think it will.
85 CJ7 driving light problem.
Nick.
Aug 01, 2008 | 1985 Jeep CJ7
Crown Tachometer Jeep Cj7 86 85 84 83 82 81 80 79 78 77 76 J5459418 Logo
69 people viewed this question
Top Crown Car Audio & Video Experts
Dennis Key
Dennis Key
Lawrence Oravetz
John
John
Are you a Crown Car Audio and Video Expert? Answer questions, earn points and help others
