Question about Bosch 24 in. SHY66C02 / SHY66C06 Built-in Dishwasher
Spray arms not spraying and pump noise for Bosch SHY66C
Water not spraying and pump making whining noise. I see parts for a motor and also for for a circulation pump repair kit. Would either of these apply? Where could I find a schematic?
  • Bosch Master
  • 5,568 Answers
Unless the motor and pump are an assembly permanently fastened as a unit, you probably need only replace the pump. Motors can be made really poor but will outlive the pump.
Since Bosch is a German brand, it may not be found on the Sears parts pages but it is worth a try. Just go to Sears.com and click onward for parts.
Posted on Jan 04, 2009
Spray arm hits plastic water supply as it spins, making a banging noise
Sadly without seeing it we could not begin to guess. have you thought about a spacer of some kind ., of course it could be a weak pump , we do not know the AGE of your machine
Jan 15, 2018 | Bosch Dishwashers
My mother-in-law called and her dishwasher is making a loud noise when the motor runs. sounds like a bad bearing somewhere? the noise stops when it drains (motor not running?). does that sound like the...
There is only one motor -- it runs a water pump for recirculating the water when it's washing and runs a water pump when it's draining.
It sounds like the spray arm is making the noise -- this is the part thru which the motor / pump forces the water during the wash cycle -- the pumped water causes the arm to rotate -- a warn or loose spray arm or mount is likely the problem.
Or, it could be just some utensil stuck in the bottom of the dishwasher which the spray arm is rubbing.
More info, let me know.
Charlie
Jul 16, 2011 | Kenmore Dishwashers
I have a Bosch dishwasher SGV43A03 and the bottom spray arm doesnt spin. It is free to move by hand, is clean inside and has clean nozzles. The water pump is operating the top jet and top spray arm...
Hello this means the circulation pump would need to be replaced. You can purchase the part from the link below. Also there are several articles that explain how to work on Bosch dishwashers.
Appliance & Refrigerator Repair
Mar 23, 2011 | Dishwashers
Hi, my hotpoint aquarius df61 makes all the noises of washing, i hear the water going in, motor is running, however i dont believe the spray arms are revolving, so the dishes are not getting clean. i have...
how old is your machine? it is posible to have something in the watwr pump, you hear the water and the motor, but the fan of the pump (washing pump) is blocket. also the pipes hat make connection to the water pump and the arms. at someoane i found glass in the pump and in the arms, many lime, or ather's things. it is recomandet to make a preclean of dish befor you put this in the machine and for beter results an economy of detergents is recomandet also to put a magnetic (or whit renewable resins, It is recommended for drinking water) softner, you wil save some money.
Feb 18, 2010 | Dishwashers
Bosch dishwasher - top row of dishes do not get clean
There is a screen that you can remove from the sump of the dishwasher to clean. Just twist it to the left and pull it out. I have some tips that you might want to check out if this does not resolve your problem.
<a href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
Feb 25, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
The rotating arms don't work
problem may be the spray arms blocked and this is not always apparant. they only rotate with water coming out of angled jets at the end. worthwhile taking the spray arms off, run water into the centre hole and see if anything comes into view
pump is an induction motor so normally would run at constant speed.
Sep 04, 2008 | Bosch Dishwashers
Water notcoming out of spray arms
water circulating pump is not working or spray arms blocked.listen and determine if you can hear motor running
Jun 25, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwasher
If you coud describe where you hear the noise that would be helpfull. the noise could be somethig hilling one of the spray arms or something stuck in the pump impeller. if you only wear it when it is only in a wash cycle I would say it may be someting in the wash pump. But also make sure the spray arms are moving freely
Jul 19, 2007 | Bosch 24 in. SHV66A03 Built-in Dishwasher
Open Questions:
Bosch 24 in. SHY66C02 / SHY66C06 Built-in Dishwasher Logo
381 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
