Dyna Glo propane heater RMC-50 igniter wont stop igniting
Fan speed also stays on what I believe to be high
  • 3 Answers
SOURCE: Dyna Glo Pro RMC-KFA70TDGP 70,000 BTU Torpedo heater not igniting
The main circuit board supplies ac power to the ignitor ( black transformer looking device) and the transformer increases the voltage that is supplied to the sparking device. Make sure the wires are connected to the sparking device and the ends of this device are approximately 3mm apart and that it is in the general position near the end of the nozzle. If you do not hear a "clicking" sound it could be the main board, wires or sparking device.
Posted on Dec 17, 2008
SOURCE: Century Dyna-Glo Propane Construction Heater, fan stays on?
The heater is designed to continueously run the igniter , so as if there is a flame-out ,it will reignite the burner,and not dispurse unburned gas into your enviroment.
Posted on Jan 17, 2009
  • 4 Answers
SOURCE: dyna-glo kerosene heater (rmc-55-r7 )
wicks won't light for usually one of 2 reasons. water in the kerosene, which means a new wick and new fuel. or build-up on the wick. check to see if the wick is hard. your wick should be soft. burning out the heater until all fuel is used either by running down all the fuel in the unit or removing the fuel can and lighting to burn off all fuel in the bottom will prevent the wick from getting hard.
Posted on Jan 19, 2009
  • 3315 Answers
SOURCE: Dyna-glo parts
thermocouples you can buy from any heating spares oulet or national energy a hone well is most common for useing as a replacement
Posted on Feb 07, 2009
  • 77 Answers
SOURCE: dyna glo tag along propane heater pilot stays on but when turning
sounds like either a bad thermocouple or more likely a pressure regulator problem. should have unit checked by someone familiar with propane systems.
Posted on Jan 22, 2010
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Need a control knob for: dyna-glo pro propane heater. model: # rmc-tt30dgp-01, # rmc-tt30dg, # rmc-tt30gd. this is the off/low/med/hi temp. control knob.
I AM TRYING TO FIND A PROPANE REGULATOR FOR A DYNA-GLO PRO. THE MODEL # IS RMC-TT30DGP. THERE IS A NUMBER ON THE OLD REGULATOR. THAT # IS S2NTT0002-2.THANK YOU.
Dec 17, 2010 | Heating & Cooling
My Dyna glo Heater RMC-KFA210WH-03 will not fully ignite
I just bought one. The fuel line was cracked. Replaced it 2$ fix
Jan 27, 2010 | Dyna-Glo (PPH16-LP) Utility Heater
I have a Dyna Glo-pro multi fuel heater. When I turn it on the ingitor starts working and than the fan comes on for a few seconds. Then the system shuts down because it willnot ignite. The tank is full and...
Since it does not ignite, Please check the ignition transformer. This have a secondary voltage of about 20,000 to 25,000 volts, enough to make your igniter
spark, thus, causing the atomized fuel to ignite and burn the fuel. So, please include igniter high voltage cable for ground leak. Ground leak is visible as line sparks when your heater is switched on. If your ignition transformer does not produce sparks at the
igniter, it means it needs to be replaced.
Have it done to make it work. Hope this will help you.
Jan 10, 2010 | Dyna-Glo RMC-8001SS Heater
Dyna-Glo model RMC-8000PGH will not stay lit
Your pilot safety is full of dust. Flush it out with shop air or rust buster. Retry
BONUS INFO
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 17, 2009 | Dyna-Glo RMC-8001SS Heater
The heat wont stay lit
clean or replace your regulater when you take it a part you will see oil and some metal shaviengs it come from the propane tank,I hope this helps you and you have a merry x mas
Can not location a source for igniter plugs for my Dyna-Glo RMC 95 kerosene heater
Below is a link to eBay where you can purchase an igniter for you heater:
http://cgi.ebay.com/Kerosene-Heater-Replacement-Wick-Igniter-1183017-NEW_W0QQitemZ390095252633QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5ad37d2c99
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Dyna-Glo Heating & Cooling
Jan 11, 2009 | Century Tool 2320I Heater
Filters for dyna-glo pro
You can make your own filters out of felt and I have also found that with some minor modifications most of the parts from Mr. Heater will work with Dyna Glo. I have a 170btu kerosene heater and just installed an ignition, a high limit control and a flame sensor from Mr. Heater and it works like new.
Nov 03, 2008 | Desa International ALL-PRO® SPC-85 Utility...
Heating & Cooling Logo
156 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
