Question about Lindhaus HEPA 14 HealthCare Pro Bagged Upright Vacuum
The red light stays on and there is a high pitched noise from the motor
Dyson high pitch noise
Dear Tasha ,
I suggest that you clean out the tubes and see if any paper has been rolled into the bottom. P.S. Do you know how tall 170 cm is in feet.
Feb 25, 2014 | Vacuums
My vax vacuum has started making a high-pitched whining/whisting noise
Ususally this is caused by a forein object has gotten hung in the suction impeller attached to the motor. the noise flucuates due to the housing flexes with the movement of the handle and rod. the housings are usually made of plastic and something very small can easily get stuck in it and stay for a very long time. The vacuum needs disassembled and the forien object removed from the fan housing...
Hope this helps
Sincerely
Roger
Feb 07, 2012 | Vacuums
Vacuum making high pitched noise and smells like motor is burning
try repair first for quote and if too expensive then replace. 5 years is about the average life span.
Jul 01, 2009 | Dyson DC14 All floors Bagless Upright...
High pitched noise when vacuuming carpet
might be the motor burning out. or it needs a new fan.
Jun 29, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson motor making high pitched noise. Is this
Most likely, there's something in the dirt tube. Ic could be something like a piece of paper or cellophane, vibrating from the air going over it. without hearing it, a high pitch noise could be different things.
Jun 13, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Noise
The high pitched noise could be because the vacuum is loosing airflow. does the red light come on on the top? if it does ot emptythe vacuum, replace the cone filter, the secondary filter, and the batting in the top of the machine. also hook the hose to the top of the vacuum to make sure there are no clogs in the hose.
Aug 23, 2008 | Filter Queen Majestic Canister Vacuum
High pitched screeching/broken handle release
For the handle problem, detent lever part #2030052 and costs $4 to $5. A bearing in the motor is what is making it sound bad, part #2032211 and will cost around $60. You could try bissell.com or call them. They can at least let you know who has Bissell parts near you.
Mar 25, 2008 | Bissell CleanView 3596 Bagless Upright...
High pitched noise
It sounds like you may have a bearing problem. The motor bearing eventually gets damaged by the water vapor that is drawn in by the fan. This will cause a high pitch squeel from the motor. It is possible to replace the bearing, but it should be addressed by a professional techician.
Jan 27, 2008 | Hoover F5886-900 Steam Vacuum
High pitch
Sounds like you have a clog. Make sure the filters are clean, replace if it has been more then a year, check the inlet down by the brush roll, your clog maybe there.
Dec 24, 2007 | Hoover Fusion Plus Cyclonic Upright Vacuum...
High pitch noise
Most likely it is coming from the motor bearings, you will have to replace the motor.
May 23, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Lindhaus HEPA 14 HealthCare Pro Bagged Upright Vacuum Logo
Top Lindhaus Vacuums Experts
JoeVacs
Are you a Lindhaus Vacuum Expert? Answer questions, earn points and help others
