Question about Billy Goat NEW LAWN VACUUM HONDA GSV190 MOTOR PUSH VACUUM
Honda gsv 190 hard start
Will not start cold must use starting fluid
1997 Honda XR 250 R hard to start cold
if it runs then the plug is not the problem
what is the problem is the carby
check that the choke is operational;, the float level is at the right level, and the ignition timing is correct
Jun 23, 2017 | 1997 Honda XR 250 R
New honda hrr auto choke hard to start
sounds like it may need the carb clening out, but it could be the auto choke not closing when cold. there was an issue with some of the early auto chokes on the gcv135/160 engines so check to see if the choke flap is in the closed position when starting from cold, run the engine for approx 10-15 minutes and see if the choke flap has opened fully.leave it to go cold and see if the choke flap has returned to the closed position
Apr 12, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
Hard starting after sitting
adjust your idle screw in carburetor clockwise one or two full turns. When Honda's are cold, they need higher idle to start properly.
Feb 06, 2010 | Honda Jenny K5HGA-30P 5.5 30 Gallon GX...
2005 crf100f extremely hard to start when cold. A
If the bike has been in storage for any length of time, more than a year or so, the carburetor is plugged up and needs to disassembled and cleaned. If that's not the case do a compression check. You need to see at least 140 psi of compression for it to start reliably. If the compression is low, adjust the valve tappet clearances (tight valves will cause low compression).
Other than that, make sure the choke is functioning properly and that there are no air leaks between the carburetor and the engine.
Dec 04, 2009 | 2005 Honda CRF 100 F
92 Honda is hard to start when cold...sometimes it will start fast, but most times it takes over 5 mins to start
very common change the temp sensor for the computer. it thinks it is warm when it is cold and doesn't inrich fuel like a choke would. causing to have a hard start. good luck
Oct 24, 2009 | 1992 Honda Accord
Steering Wheel noise on cold start
this is either a loose belt, or low power steering fluid. Remember that Honda uses a diffrent power steering fluid from everyone else. Make sure it is a Honda compatable fluid, or you will get leaks.
Jan 12, 2009 | 2000 Honda Accord
Hard to start very hard when cold
I had a 97 900rr that did the same thing, give it a tune up and make sure your choke cable is functioning correctly and it'll start with little problems when it's cold.
Jan 03, 2009 | 1996 Honda XR 600 R
Billy Goat NEW LAWN VACUUM HONDA GSV190 MOTOR PUSH VACUUM Logo
138 people viewed this question
Top Billy Goat Heavy Machinery Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Billy Goat Heavy Machinery Expert? Answer questions, earn points and help others
