Question about Sharp R-1480 Microwave Oven
Unable to get the touch bottom to work
Sharp model R-190H I am unable to clear the 88:88 when you touch stop/clear pad nothing happen. I am unable to set the clock or do anything
  • Sharp Master
  • 9,098 Answers
Quite often on the compact models, the solution is to pull the control panel assembly off, remove the circuit board and clean the surfaces shown in the photo with high-grade alcohol.
That would include the back of the LCD glass and both sides of the rubber strip.
Posted on Jan 04, 2009
Sharp microwave oven flashes 88:88 touch pad does not respond , model R-9H20
You have a failed membrane keypad.
Replacement keypads are no longer available for any Sharp R-9H-series microwave ovens.
The oven will have to be replaced.
Nov 19, 2016 | Sharp Microwave Ovens
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    Sharp Microwave on "Lock" and
    The Child Lock prevents unwanted oven operation such as by small children. The oven can be set so that the control panel is deactivated or locked. To set, touch CLOCK, the number 1 pad and then touch the START pad and hold for 3 seconds. Should a pad be touched, will appear in the display. To cancel, touch CLOCK, the number 1 and STOP/CLEAR pads
    Mar 08, 2011 | Microwave Ovens
    No numbered touch pad for use setting clock
    I think on this one you press the CLOCK/TIMER pad, then enter the desired time using the 10 MINUTES, 1 MINUTE, AND 15 SECONDS pads then press CLOCK/TIMER again.
    If that doesn;t work, press STOP / CLEAR then try the above again.
    Let us know if it does not work.
    Mar 05, 2009 | Sharp Microwave Ovens
    Unlocking child lock on the sharp microwave model R316FSC
    The Sharp Microwave/Convection oven I have says to touch the Custom Help button, the number "1", then touch the Start Button. To turn off the child lock, press the Stop button.
    Or just unplug it, wait 1 minute, and plug in.
    Jan 06, 2009 | Sharp R-308J Microwave Oven
    My microwave sharp 220hw 8oowatt
    After snubbing the darned thing overnight, plug it back it to see if it has recovered. These things do have primitive computers and we all know how reliable those things are- It may just have 'crashed,' just like seemingly all others.
    Nov 05, 2008 | Sharp R-220HW Microwave Oven
    Problem with the display
    I've checked, and cannot seem to find online service data on this model. Perhaps it's too new.
    But it sounds like you have one which has the glass LCD and keypad connected to the circuit board via a zebra strip type "rubber connector". This is what you referred to as the "black and white small foam like pad". It is called the rubber connector.
    It's similar to the model shown in the attached exploded view and it shows you what to clean.
    If cleaning doesn't work, you need to order the LCD glass and the rubber connector.
    You will probably have to call Tritronics with your model number to get these parts. They are toll-free at 866-779-5835.
    Oct 30, 2008 | Microwave Ovens
    Sharp Carousel Convection Oven. Model R-9H54.touch pad
    It depends on what you mean by "a problem with the touch pad assembly".
    If some or all keys do not respond, you would probably need a new keypad, but the key units for all Sharp R-9H-series models have been unavailable for a few years now.
    These units did indeed last a long time.
    Sorry I can't bring better news.
    Dec 06, 2007 | Sharp R-370E 1000 Watts Microwave Oven
    Sharp R-1480 Microwave Oven Logo
    170 people viewed this question
    Top Sharp Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
