Question about Kwikset 909 909-L03 Lifetime Polished Brass Smart Code SmartCode Signature
Kwikset 6wal installation and assembly
The handle set came off the door. need to reassemble and reaffix
4 Suggested Answers
efs_perpends
  • 1996 Answers
SOURCE: I recently purchased a kwikset jda-9760718-002
You can download them from kwikset here. Just choose your version of the lever, select Installation & Troubleshooting instructions from the search list, and scroll down to the .pdf document file listed in the next window.
But that lever is pretty standard, and there are also some kwikset installation directions here
You can use some pretty generic instructions if you just google "install lockset"., that may have some useful pointers.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 30, 2009
  • 963 Answers
SOURCE: re-assemble a kwikset front door lever and knob type latch
Since the exterior side of the lock only has a keypad and no lever, I'm not sure what you mean by the "outside lever". Here is a clear, easy to follow video of the installation. Please carefully review each aspect of your installation against it to see if you can spot an installation mistake:
http://www.kwikset.com/Videos/Vitro/smartcode.aspx
Posted on Sep 06, 2012
  • 101 Answers
SOURCE: How do I reassemble the latch mechanism of a kwikset 510 handle set?
http://s7d5.scene7.com/is/content/BDHHI/5048328
This might be helpful
Posted on Aug 07, 2014
How do i attach the door lever?
http://s7d5.scene7.com/is/content/BDHHI/24910-04
Kwikset lever handles are held on with hex set screws. A wrench is included in the package. It's either a 3/32" or 2.5 mm. Note that the lock must be unlocked to remove or install the outside handle.
Sep 06, 2014 | Kwikset Brooklane Venetian Bronze Entry...
How do I reassemble kwikset lock set LIP 5 SMT?
Contact:
Consumer Services
19701 Da Vinci
Lake Forest, CA 92610
1-800-327-LOCK
It's difficult to know without seeing it in person or with good pictures.
Aug 03, 2014 | Kwikset Locks & Locksmithing
Re-assemble a kwikset front door lever and knob type latch
Sep 03, 2012 | Kwikset 909 909-L03 Lifetime Polished...
We have the thumb press elongated handle on the outside of the front door entry. I was ready to enter the front door when I pressed the thumb handle and the whole set fell apart. Need instructions to put...
For the Lido Keyed Entry, go to this page:
http://www.kwikset.com/Products/Details/Door-Levers/740LL-26D-SMT.aspx
and click on "Installation Guide", found under the red text " Technical Documents"
If I've steered you to the wrong lockset, the product main page foe Kwikset can be found here:
http://www.kwikset.com/Products/Categories/Handlesets.aspx
Feb 13, 2011 | Kwikset 4 Lido Lh Passage Levers Satin...
Kwikset 730LL-RH handle fall out, How to fix it?
I'm including a link to the installation/assembly instructions for the Lido LL730 3:
http://s7d5.scene7.com/is/content/BDHHI/44594-01
I'd recommend that you contact Kwikset Customer Support if you are unable to repair it:
Kwikset Corporation
Consumer Service
19701 DaVinci
Kwikset Customer Service
Call: 1-800-327-LOCK (5625)
Here's the link for their customer service page:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Feb 11, 2011 | Kwikset 4 Lido Lh Passage Levers Satin...
Change batteries on kwikset pushbotton lock.
If it's the lock I think it is, all you need to do is to remove the two screws on the inside of the door that holds the lock to the door. Pull straight out on the whole assembly. You should see the exposed battery once you have removed the outer case and handle.
Hope This Helps,
RSMITH972278
Nov 10, 2009 | Kwikset Professional Door Lock...
Jul 29, 2009 | Kwikset Sheridan Handle Set
Cannot remove disk that covers screws to tighten my lock
The screws are located on the non locking side of the handle. To get the cover off most pop off by placing a small screwdriver behind the edge and gently prying. Paint/varnish will make this harder so you my have to take a razor and cut around it.
Please rate.
Jun 03, 2009 | Kwikset Professional Door Lock...
Changing doors would like to know how to take off kwikset door
remove the two screws on each side of the door knob from the inside of the door use medium size phillips head screw driver
pull the door handle off
remove the handle from exterior door side
remove two phillips screws from the side door that hold the door bolt pull the door bolt assembly out
reinstall on new door
insert bolt assembly
insert knob for exterior side(a lign it up
insert knob from interior side and align screws and tighten ligtly
check door for easy turning of knob and actuating latch
good luck
remove that assembly
take screw driver and remove the two scres that remove the plate on the side of the door and
Dec 29, 2008 | Kwikset Professional Door Lock...
Kwikset 909  909-L03 Lifetime Polished Brass Smart Code SmartCode Signature Logo
425 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
