Question about HP LaserJet 4345mfp Printer
49.ff81 Printer does not boot up. Getting the following error "49.FF81 Service Error"
2 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: HP laserjet 4650; displaying error 49, FF81 Service Error
Unplug the power cord for 10 seconds
Posted on Feb 03, 2009
ERROR 49.FF81
From HP support forum possible defective hard drive.
http://h30434.www3.hp.com/t5/Printer-All-in-One-Install-Setup/M3035-MFP-49-FF81-Error-Code/td-p/1272713/page/2
you may be able to disconnect the drive to get the printer operational,
but you lose some functionality
49 errors are communication errors with other devices in printer.
Mar 20, 2014 | HP LaserJet M3027 MFP Printer
49 ff95 service error
49.XXXXX ERROR alternates with To continue turn Off then On 49.XXXXX ERROR alternates with To continue turn Off then On
Explanation
A critical firmware error has occurred.
Recommended action
  1. Turn the printer Off and then On.
  2. If the message persists, contact HP Support.
Nov 24, 2013 | HP LaserJet 5200 Printer
Hp colour laserjet 9500hdn has service error 49. FF81
I've seen this exact error a few times on the 4101s & turned out to be a bad EIO hard drive.If you replace the drive, you'll most likely have to download the newest firmware & load it to get every feature back.
You can try & initialize the drive first though:
- Turn off printer
- Press & hold [Start] button
- Turn printer on, wait for all 3 LEDs to stay solid then release button
- Press & release [Left] arrow button (should read "Initialize Disks" on display
- Press & release [Select], then wait for printer to warm up
Listen also to the drive & if you hear it clicking over & over then it's bad & will need replaced.
Apr 29, 2012 | HP Color LaserJet 9500HDN Printer
When the printer is booting it is stuck at **************************, when it do comes on it comes with error code Error 49.4c02 Product model: HP Laserjet 4100N
Thank you for contacting FixYa with your printer inquiry.
HP Laser Jet 4100 49.4C02 Error
49.xxxx PRINTER ERROR
Description 49 errors are generally communication errors or file related issues and can usually be resolved by following the steps below:
Action Turn the printer off, and then turn it on again.
If the 49 error returns turn the power off, unplug the power cable, disconnect all network cables, and remove the HP Jetdirect card (or any third-party devices), if installed.
Wait at least 30 seconds before plugging the printer back in directly to a wall outlet. Do not plug the printer into a power strip or a surge protector.
Turn the printer on. If the 49 error returns, turn the power off, and then unplug the printer. Remove the formatter board.
Check that the parallel I/O board is firmly installed on the formatter board.
Check for any non-HP memory DIMMs. If any extra memory is installed, remove it.
Reconnect the power cord, and turn the power on.
If the 49 error returns, perform a cold reset.
Watch the control panel.
When the memory starts counting, press and hold the green (Select) button.
Continue holding the green (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
Release the (Select) button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
Press (Down Arrow) button once. The control panel will display COLD RESET.
Press (Select). The printer will perform a cold reset and then continue its power-on sequence. If the error code continues to come back, it requires a firmware upgrade.
If the 49 error returns, contact an HP-authorized service or support provider.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jan 05, 2011 | HP LaserJet 4350 Printer
The error "49. FF05 SERVICE ERROR" is displayed on
If the error can be reproduced, use the following sections of this document:
  • Product-specific documents Product specific document are available on the HP support website at the following url http://welcome.hp.com/country/us/en/support.html . Select your product and use the search string Product specific 49 errors to locate your product specific 49 error troubleshooting document(s).
  • Clearing the error
  • Validating the firmware
  • Stack Trace Random error troubleshooting
  • Hardware troubleshooting (if applicable)
Power-cycle doesn't eliminate error If the error cannot be eliminated by a power-cycle, use the following sections of this document.
  • Hardware
Feature-specific error The error has been narrowed down to a specific feature.
  • Software, Sending, Faxing, and environmental troubleshooting
Oct 26, 2010 | HP LaserJet P3005d Printer
Error 49 Cycle Power FFF
49 errors are possibly one of the most difficult to diagnose.
49 Indicates that a firmware error occurred that caused the processor on the formatter to abort an operation.
This type of error can be caused by invalid print commands, corrupt data, or invalid operations. In some cases, electrical noise in the cable can corrupt data during transmission to the printer.
Other causes include poor quality parallel cables, poor connections, or home-grown applications.
On some occasions, the formatter is at fault, but this is usually
indicated by a 79 Service Error.
I see you state a 49FFF? any other letters or digits displayed?
Specifically 49 FFFF can be a problem if the ribbon cable from the DC controller to the interconnector board is not connected. The control panel display will also be dark.
Other 49 FFx errors can be:
NEC firmware chip error - replace the Firmware
Unsupported EDO Memory installed - Remove unsupported RAM
Fuser life test error during Boot cycle - Replace the Formatter
A Large print Job (>800 pages) or complex graphics can cause the device to quit printing. - Simplify the Print Job, lower DPI etc.,
Good luck
May 02, 2010 | HP Color LaserJet 4500 Printer
HP LaserJet M1522 with error 49
on hp.com you can update the firmware and that should take care of it. its a free download
Jan 07, 2010 | HP LaserJet M1522n MultiFunction Printer
Error message 49,ff81
it is temporary printing error, turn off the machine and wait 10 sec and turn it on again it should clear.
Oct 15, 2008 | Office Equipment & Supplies
HP LaserJet 4345mfp Printer Logo
Seeker5211
Seeker5211
