Question about Olympus Camedia C-350 Digital Camera
Problem with xd card
I can view the photos ok on my camera but when connecting it to my pc I get the message that the card is not formatted. Camera and pc work ok together with a different card so I am guessing there is a problem with this card. Tried cleaning it a little with no luck, and also tried putting the card into the reader on my printer, again got the message that there was a card error. Is there going to be any way of me rescuing these photos, or will I only be able to view them on my camera's teeny screen?
  • soonosaj Dec 08, 2007
    I have a olympus 725sw using a 1 gig xd card and it was doing the same as Mel74 described however it is now not even showing the images in the small view finder. Have lost the chord but will be getting another one to see if that solves the problem.
    New Friend:
  • 20 Answers
1. Do NOT click "Yes" to format this camera memory card in case that the formatting process makes things worse.
2. Do NOT attempt to write anything new on this camera memory card in case of any data loss.
3. Download an unformatted memory card data recovery freeware to your computer and try to retrieve all your wanted pictures back before the formatting process:
http://blog4mark.blogspot.com/2013/01/unformat-memory-card.html
In fact, this freeware has ever successfully saved all the inaccessible data of my friend off from his camera memory card. So, I believe it can also work successfully on your memory card, too.
Simply read more information of this freeware here:
http://www.freeware-fix.blogspot.com/2013/03/memory-card-recovery.html
4. Save and back up all your restored photos on a different memory card or hard drive in case of data recovery failure.
5. After the data recovery process, simply format this memory card to see whether it can work functionally as before.
In the future, you should learn a lesson to be more careful about your data and always back it up well.
Posted on Nov 25, 2013
    President:
  • 2,961 Answers
If you connect your camera to your pc via a usb lead which should have come with the camera windows should recognise it and you can view the pictures in picture viewer or go to my computer where your camera will show as a seperate removable drive, click on explore and there will probably be a folder called olympus open this and you should be able to see the photos
Posted on May 19, 2007
SOURCE:
Olympus xd card formatting problems.
If you like the camera and XD cards then I would use the USB cable to download the photos from the camera. When you plug the USB cale into the camera and then into the computer, the computer should recognize the camera and set it up as another disk drive. Copy or move the pictures from the card to your Photo location. Use the "Safely Remove Hardware" icon in the system tray to disconnect the camera and your done. The camera can format the XD card and the computer can read it through the camera.
May 28, 2009 | Olympus FE-340 Digital Camera
Picture error on Olympus C-765 Ultra Zoom
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the picture error message and the cards can be used again.
Jan 04, 2009 | Olympus Camedia C-765 Digital Camera
Clean or format card error on Olympus XD card
my camara showing error message that clean card or format card,
i have some important photo in memory card so i can,t format the memory card.
while i am connecting with USB cable it,s showing syntex error
help me to retive the thw data..
txs...............
Jun 05, 2008 | Olympus Camedia C-350 Digital Camera
Screen reading memory card not initialized
I bought a new memory card for my finepix A330 camera When I turned on the camera after putting in the new card, the screen read "card not initialized" and won't take photos.my son is going holidays 13/9/08 could you help me please Alex Richardson
Mar 07, 2008 | Fuji FinePix A330 Digital Camera
No Image
Please read these/the 2 posts that I posted prior for a similar XD mem card problem, as I firmly believe you are "formatting" your mem card improperly using your home computer instead of "formatting" the card on your camera.
Also the XD type card & size are very important also!!
What you will have to do is read and download the photos you have on that XD card using the same "card reader" you used before and then properly "re-format" that card in your "CAMERA ONLY". This should solve your XD card problems.
PRIOR POSTS:
Kristina,
Not knowing what model Olympus camera you have, or how old it is - your new memory card "format" problem is one of 3 possibilities.
1st - If you have an older Olympus camera more then 4-5 years old the newer M & H series type cards over 256mb will probably not work in your older camera, as by the camera's internal firmware chip design of the camera itself. Some cameras were upgradeable some weren't as to the internal firmware chip as well as available software drivers depending on which computer OS system you were using ie: (WIN98SE, WIN2000, etc). Has to do with the memory card read/write chip speed as well, and also has to do with the physical storage size of the card itself. Some digital cameras were MAXED OUT at 512mb cards, some as low as 256mb. A 2gb card simple won't work in that/your camera in that case.
If you read the camera's user manual it will possibly tell you this, or else go online to www.olympusamerica.com and use this link:
View which cameras are compatible
Select camera model series and scroll down the model # and research the max card size & type you can use (3 basic XD card speed types available - regular XD - M type - H type).
If you are using the wrong type & size card you will need to return that card (if you can) and get the right XD size & type for your camera.
2nd - You should always FORMAT (same as ERASE ALL and FORMAT modes on most Olympus cameras) the new card, or any XD card for that matter in your camera itself. NOT THE HOME COMPUTER!!! The 2 format procedures are not the same!!
If you are re-shooting (re-using) the same XD card over and over again and then downloading the JPEG pix directly to the computer using a USB interface cable there usually is no need to re-format the card again as long as the XD card stays the camera and is not downloaded into a home computer via a "card reader". If you do the latter "card reader" then I would advise doing a card re-format in the camera again just to be safe!!
And lastly - If your home computer recognizes the XD card via a good "card reader" (do not FORMAT the XD card here btw, as you are just checking the card out to see it is GOOD is all), but the camera will not then that is a good sign your camera is OK, but it's just the wrong type & size XD card.
Hope this helps solve your camera XD problem not knowing which model you have.
Best regards,
Frank
AND:
Follow up to previous post:
I didn't have the time to access the exact link below to check on your specific 2004 model year camera because I missed the Fuji camera model part, as I'm brand new to this site - so please forgive my previous oversight here.
I was right though in my initial posted assumption that you bought the wrong XD memory card based on your Fuji FinePix A330 Digital Camera - as to it's older model year - in that your camera is limited to a 512mb memory card.
Make sure you buy the 512mb standard card if you still can find them. Otherwise check with Fuji Corp to make sure the M type card (faster read/write chip) will work in your specific model. The M type cards work just fine in my Olympus C-740 even though it was told to me they wouldn't work at all, but each digital camera is slightly different as to it's internal firmware (BIOS) chip.
See the following camera info for your specific model at the link below under Storage Media:
Steves Digicams - Fujifilm FinePix A330 - User Review
I hope this now clears up any prior confusion from the previous post.
Best regards,
Frank
Feb 06, 2008 | Fuji FinePix A330 Digital Camera
Card not initialised
You can recover the missing pics off your card get, there are some image recovery programs available on the net and most camera shops will offer a card recovery service but dont format before you get pics recovered.
Not formatting a card is bad. They need to be formatted on a regular basis because deleting images from card does not remove them and the next image taken only overwrites the old ones.
Dec 07, 2007 | Fuji FinePix F11 Digital Camera
Olympus 770 not able to move photos from xd card to laptop error message every time
A couple of questions :
What happens when you use "Windows Explorer" to view the contents of the card .
It should appear as just another disk drive in the list .
Are you able to view the contents of the card when you plug the camera into the usb port ?
Dec 04, 2007 | Olympus Stylus 770 SW Digital Camera
Fuji FinePix 3800 Initialization glitch
Turn camera from "off" to "play" ( photo view..._
Pressing the “MENU/OK” button as you would to erases files. There is an option to format the xD-Picture Card. Formatting erases protected files, but allows you to then take photos.
Nov 15, 2007 | Fuji FinePix S7000 Digital Camera
XD card Problem
IF the images are lost (can't see them thru the camera), format the memory card (Photo mode button - Set - Format). These cards need to be reformatted frequently. I do it once a month, but I'd recommend it once every 500 pictures.
Sep 12, 2005 | Fuji FinePix S5000 Digital Camera
Olympus Camedia C-350 Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
