Question about Kingston Dt101g2/8gbz Flash Memory
Usb drive I/o Device Error - Kingston Dt101g2/8gbz Flash Memory
  • David Fisher Nov 05, 2012
    Please provide more information.
    New Friend:
You have probably seen the following scenario in multiple thriller and spy movies; A spy connects an USB stick to a computer to copy data from the computer to the device. Movies do not necessarily reflect reality but there is some truth to this scenario after all. It is indeed possible to connect an USB device to a computer running Windows to copy data from that computer to the removable storage device.
It is sometimes in the best interest of companies, organizations and individuals to protect the data on their computer from being copied this way.
Microsoft has added options to the Windows operating system (more precisely to Windows XP and newer operating systems) to write protect all USB devices that are connected to it. This indicates that it may not always be possible to protect the computer this way, for instance if data needs to be written to USB devices regularly.
Write Protection adds another layer of defense to the computer. The system is not fool proof on its own, as it is still possible to copy data, for instance by uploading it to the Internet or a network connection.
Write Protecting USB Devices
You can enable or disable write protection of all USB devices that are connected to the Windows operating system. Both settings are configured in the Windows Registry. Here is how this is done.
Open the Windows Registry editor with the shortcut Windows-r, enter regedit into the form and press the return key on the keyboard.
Navigate to the following Registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Please note that you may need to create the key StorageDevicePolicies if it does not exist. Select the key afterwards and right-click into the right window. Select New > Dword (32-bit) Value from the context menu and name the entry WriteProtect.
Double-click the new entry afterwards and change the value from 0 to 1. A value of 1 disables writing to all connected USB devices. If you want to enable writing again you need to change the value of the key to 0.
Posted on May 13, 2013
How to Repair USB Flash Drives Broken, Unrecognized, Not Detected?
hi Jhon.
this is all i could find out.
Navigate Control Panel -> System -> Device Manager -> Disk drivers. 3. Find and select your USB device, right click and first choose "Uninstall" and then choose "Scan for hardware changes" to refresh the drivers. After all the operations, you will find USB not recognized issue is fixed and the flash drive is detected.24 Jun 2016
Repair & Recover USB Flash Drive not Recognized or Detected ...
https://www.easeus.com/resource/usb-flash-drive-not-recognized.html
How can I fix USB device not recognized?Method 4: Reinstall USB controllers.Select Start, then type device manager in the Search box, and then select Device Manager.Expand Universal Serial Bus controllers. Press and hold (or right-click) a device and select Uninstall. ...Once complete, restart your computer. Your USB controllers will automatically install.Error: "USB Device not recognized" when you try to access a USB ...https://support.microsoft.com/.../error-usb-device-not-recognized-when-you-try-to-acces...Search for: How can I fix USB device not recognized?
how to repair usb flash drive not recognized Google Search
Nov 30, 2017 | Electronics - Others
What is USB error 43
This is device manager error. It means One of the drivers controlling the device notified the operating system that the device failed in some manner.
You can visit this link for the solution of your problem.
http://social.technet.microsoft.com/Forums/en/w7itprohardware/thread/6f40e3e8-7283-47e4-a13f-ca6c4f3fae02
Feb 26, 2013 | PQI 512MB Intelligent Stick USB 2.0 Flash...
Problem is occured during installation of USB Mass Storage Device An error occured during the installation of the device Data error(cyclic redundancy check)
Try uninstalling the USB root hubs in the device manager and then restart. They will reinstall upon the restart.
It may also could be a bad power adapter.
Dec 06, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I replaced the USB adapter chord and know there's not enough power to run the drive. I think I need a DC adapter, 5V, 1A, that fits the drive.
If you get an error message "Insufficient power to operate USB device" when you plug in a USB device into the computer's USB port then this device is drawing power that the USB port can supply.
In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Dec 06, 2009 | SimpleTech SimpleDrive Portable USB 2.0...
the device is not recognized, this error comes out from USB connector, try another USB connector if the problems continue, or transfer it to another USB ports...
Jul 08, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
My flash drive will not operate when plug into my lap top.
Hello kjh87....
1) If you are using a USB cable with your device, check the cable to make sure it matches the speed of the device. Use USB 2.0 cables with USB 2.0 devices and USB 1.1 cables with USB 1.1 devices. Swap cables and check the device, if this does not work, proceed to Step 2.
2) Next, open Device Manager and look under the heading for USB Serial Bus Controllers. If there is a device with a yellow exclamation mark next to it such as USB Mass Storage Device. Double-click on the entry and check the Device Status. If the status shows something like
"This device cannot start. (Code 10)"
proceed to Step 3.
3) The easiest way to solve a USB error code 10 in Windows XP
is to follow the steps below to remove and reinstall all USB controllers.
A. Click on Start
B. Right Click on My Computer, click on Properties
C.Click on the Hardware tab
D. Click the Device Manager button.
E. Expand Universal Serial Bus controllers section.
F. Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time.
G. Restart the computer, and allow the computer to reinstall the USB controllers.
H. Plug in the removable USB storage device, and then test to make sure that the issue is resolved.
For more information on Troubleshooting USB device problems, visit the Microsoft Support Article on this subject.
I hope this helps...
May 28, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Write protection error in usb drive
Any USB Device?
Put in device
Rt Click My Computer,Manage, Devices
Hilight the device
Hit DEL key
Ans YES
Pull/Unplug that device
repeat for all others
when all have been deleted and are no longer in the machine, reboot it
Reinstall last Service Pack
Reboot
Fixed!
Jan 17, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
USB 2.0
Hi sharad,
Generally the Code 10 suggests that the USB device is faulty (or the USB port/controller on the computer). There is also a possibility that you need a correct driver for the device.
Have you tried plugging the device into a different USB port? On many computers that have USB ports on the front, those ports are legacy (version 1.1) USB ports and you should try the ones in the back first.
Ben
Mar 01, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Kingston Dt101g2/8gbz Flash Memory Logo
368 people viewed this question
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
