Question about LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive
1 tb maxtor basic desktop storage green light blinking
I cant make it work it was working just fine and stoped dont know why . is there anythink i can reset it or make it run again , nothink happen when i coonnect to pc at usb port
  • frostylawson Jan 05, 2009
    My Lacie 1TB drive won't boot up anymore.  I backed up a lot of my data on other drives, but I still would like to be able to access this drive and fix it.  Can anyone out there advise me on this?  I have the firewire drive version.
  • sammy-boy93 Feb 07, 2009
    my green light is bliniking too, what can i do?
Chinthakaj
  • 416 Answers
SOURCE: maxtor basics desktop storage 1000gb wont start up but has power
Best is to take it to the shop you bought it from. they will replace it. ask them to transfer the data to the new one. the chances are they might do it.
Posted on Jan 15, 2009
SOURCE: open external drive maxtor basic 500GB
it may be like the one i have which is a maxtor basics 1.5tb drive. There is only one screw behind the sticker. The rest is clips. This is the guide i used when opening the case.
http://www.computer-aid.com.au/blog/2009/02/17/how-to-take-apart-a-maxtor-basics-external-35-usb-drive/
Posted on Mar 29, 2009
  • 413 Answers
SOURCE: can't reconize maxtor basic
Here is the support website for the Maxtor....>
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=DiscWizard&vgnextoid=d9fd4a3cdde5c010VgnVCM100000dd04090aRCRD
You will find drivers and things here....
Posted on Jul 01, 2009
bob_computer
  • 3153 Answers
SOURCE: Lacie Hard Drive won't connect via USB anymore
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
DO NOT PLACE IN A FREEZER !
THIS IS VERY OLD ADVICE FOR VERY OLD TYPES OF HARD DRIVES THAT ARE NO LONGER EVEN MADE. A FREEZER CAN CAUSE MORE DAMAGE.
Posted on Sep 26, 2009
VinayT
  • 1884 Answers
SOURCE: Restore factory settings on maxtor basics external storage 1000gb
What do you mean by factory settings. From the factory, the drive came just formatted with no data on it. If you want that then format the drive in WIndows. My Computer->Select the drive that is Maxtor, right click it and in the box that opens format is one of the options. Select and follow instructions.
Posted on Nov 16, 2009
Maxtor exter hdd 500 gb green light flashes but cant be detected
maxtor one touch 3 -500 does not detect on my macbook pro worked fine on my G5
Sep 11, 2009 | Maxtor MaxAttach NAS 3000 40 GB Network...
Can't retreive any info from my maxator green
Good day sir/maam, I had the same problem with my generic external drive, keeps blinking but cant be recognized by the PC. chances are the Maxtor is done, you can salvage the Hard disk inside. Visit your dealer if its under warantee demand for a replacement they may also have service people to take a look at the drive. hope this helps
Aug 03, 2009 | Maxtor Basics Personal Storage 3200 Hard...
Maxtor 750GB External Drive Blinking White Light
If you hear a click-click sound it means that your drive's mechanics ia failing. BAD NEWS !!
Jul 06, 2009 | Maxtor Shared Storage II N01R010 1 TB USB...
Cant acees files on maxtor basics
try to use it via usb to SATA converter then u will see if it really work or not , if not try to use the same usb to SATA converter on another computer if doesn't work then ur harddisk controller is broken and u need to give it to its company to recover ur data
Jun 06, 2009 | Maxtor Hard Drive
Maxtor basics desktop storage 1000gb wont start up but has power
im sorry, but it sounds like a hardware problem. theirs not many options.
you may either void your warranty by opening it up and hoping you can use the hard drive in another case (hope its not the hard drive)
or you can return it under the warranty. That is a bummer.
The terrabyte hard drives havent been completley worked out yet. i have heard of a bunch of problems with them failing because of how they are made. The scary part is i dont think they fixed all the problems with the 1tb drives and now they are moving onto 2 tb's!?!?!?
Jan 03, 2009 | Maxtor Hard Drive
External Hard Drive problem - Why God!? Why!!?
sure..the power is not the key issue..what you might consider, is calling a local computer fix it shop, and ask how much to recover that data..then, you may be well advised to consider an online back utility, such as you can find here.
Oct 13, 2008 | Maxtor Personal Storage 3200 (M1227310)...
You need to open the enclosure and either put the drive in another enclosure or connect it directly to your computer.
Or you can pay to send it to data recovery people and they will get all the data off.
May 27, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Blinking green light
Same problem. Blinking green light. Device not recognized. Have my whole life on this drive! HELP!
Apr 03, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive Logo
867 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
