Question about Toshiba Satellite L355D-S7901 Series Laptop Auto Car Adapter (C1990UM3100605738)
My toshiba l355d black screen all fans and lights are working
I have already tried taking the battery and power cord off and holding down the power button for 60 seconds and nothing still
  • Toshiba Master
  • 27,725 Answers
There are several reasons that your Toshiba laptop screen may not come on, even if the laptop appears to be running, and several options you may try to get your screen back up and running without an expensive service call.
Common causes for a blank screen include a backlight that is turned off, a display toggled to an external monitor and improper shutdown errors.
To avoid blank screen errors after your current error is fixed, make sure to follow all instructions in your user's guide to care for your Toshiba computer.
Shine a flashlight directly at your screen and look for an image.
If you see one, this means the backlight on your laptop is off but the screen is still working. This backlight normally turns off only when your screen is closed.
Look for a small metal or plastic pin near one of the screen hinges.
The screen pushes this pin in when it is closed, so if the pin is stuck in the screen closed position, the backlight will remain off.
Tap the pin several times to release it.
You may need to use a small object, such as a pencil tip or straightened paper clip, to reach it on some models.
Monitor Toggle
Press and hold down the "Fn" key if you do not see an image when you use the flashlight.
Tap the "F5" key several times while the "Fn" key is pressed.
This will cycle your screen through the various options that toggle the display to an external monitor.
Attach an external monitor, restart the computer and try this method again if no image appears on the laptop screen.
Click "Start," "Control panel," "Hardware and sound," then "Device manager" using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Select the "Monitor" option to expand your selection and select your LCD monitor from the device list.
Click the "Driver" tab and select "Update" to update the driver, as this error is likely caused by a software driver error.
Force Restart
Press and hold the power button until the computer shuts down completely.
Check the indicator lights at the edge of your laptop to see if the computer is truly off or if it has simply gone into hibernation mode.
If it is off, all lights will be off except the battery-related lights if you have a charger plugged in. In hibernation mode, the power light will blink slowly.
Press the power button to restart the computer again after leaving it off for 15 to 20 seconds. This may fix the problem.
If the blank screen returns or you get a flash of images and then a blank screen, move on to the next step.
Force Power Down
Unplug your laptop from the power source.
Remove the battery by pressing outward on the battery latch and pulling the battery unit completely out of the computer.
Press the power button several times to completely discharge the computer.
Replace the battery and plug the computer back in after about 30 seconds.
Press the power button to turn on the computer.
If you get an error screen upon startup, choose to restart Windows normally.
This error is caused by improper shutdown procedures.
Hope this helps
Posted on Nov 05, 2012
How to turn on my Toshiba satellite L305D-S5974, YESTERDAY IT WENT DEAD AND NOW I GOT THE CHARGER BUT ALL I SEE IS AN ORANGE LIGHT BLINKING BUT IT STILL STAY OFF NO FAN,NO SCREEN AT ALL, HELP PLZ
Remove the power cord and remove the battery. Press and hold the power button for 30 seconds... no less... Put the battery back in and plug in the power cord. Try to start it.
If it doesn't work, try again without the battery, just the power cord.
If that doesn't work neither, remove the power cord, and leave it without the battery or power for a couple hours. 3 minimum.
Put everything back and try to start it up again.
Good luck.
Apr 25, 2016 | Toshiba Computers & Internet
Why Toshiba Satellite A665 Laptop won't start?
Have you tried pressing space bar (maybe its in hibernation mode) ?
or try holding power button for a few seconds (10) then turn it back on.
as a last resort you could try take the battery out, disconnect it from the power adapter, hold down the power button for 30 seconds and then place the battery back in and the power adapter and try powering it on?
Aug 26, 2014 | Toshiba Satellite A665-S6088 16 Notebook...
Toshiba satellite L355D screen is black
Try to remove the memory and clean..
place it back.
if not refix all the connections. or try change the monitor maybe monitor is dead.
Dec 21, 2012 | Toshiba Satellite L355D-S7815 Notebook
Toshiba l355d - s7815 won't boot and screen doesn't light up
From your description you have a motherboard issue, the only way to rectify this, it must be replaced.
Mar 26, 2012 | Computers & Internet
My satellite l355d-s7825 will not power up at all. It show a green light when I plug in the power cord but never starts up. It looks like it is going to and then immediately shuts back down. The screen...
remove the battery then put it again and check, if the problem persists, also remove the RAM then put it again and check , if still there is a problem then the fault is in the power ic of the laptop mother board better consult to some technician
Jul 28, 2011 | Toshiba Satellite L355D-S7825 Notebook
My toshiba m35x-s161laptop has issues
may be the procesor unit(cpu) is too bot because a dust.....
Mar 06, 2010 | Toshiba Satellite M35X-S161 Notebook
Toshiba satellite A135S4437..wont work
If you are recieving power from just the Power cord without the battery. This could be a bad battery. If you are recieiving power but no video it would also be bad RAM. Try taking out the ram one piece at a time and testing one at a time. That should give you a better idea.
Oct 15, 2009 | Computers & Internet
I have a toshiba satellite laptop the screen is black
Shutting the computer down could be done by holding the Power Switch down for 10 seconds, rather than unplug/no battery "solution". A blank screen is more often than not caused by the failure of the screen's backlight. Plugging an external monitor in the ext monitor port would verify the computer still works, and I am sure it does.
Oct 10, 2009 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite A205 laptop will not boot - black screen
Here's a link to a good article that will help you to troubleshoot the startup error. You might also check Toshiba support online and see what the error light code indicates.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 06, 2009 | Computers & Internet
Toshiba Satellite L355D-S7901 Series Laptop Auto Car Adapter (C1990UM3100605738) Logo
1,045 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
