Question about Dryers
Dryer not heating
My electric dryer is not heating. Someone said it might be a fuse but I do not know where to locate the fuses on the dryer.
  • 3 Answers
Most likely it is gonna be your heating element; but once I had a dryer do this and it turned out to be a tripped breaker.
Posted on Jan 04, 2009
How do I know when the thermal fuse for my whirlpool deut electric dryer is bad?
Take it out. check it with a multimeter set on ohms. Get a hair dryer turn it on hotest setting. with meter leads on each end of the thermal fuse have someone hold the hair dryer blowing hot air on fuse. It should show continuity through it when cold. After heat is applied it should show 0 or infinity. If its working properly move on to over temp switch.
Sep 02, 2014 | Whirlpool GEW9250 Electric Dryer
Where is fuse located?
There may be an electrical diagram attached to the rear of he dryer. You can trace the circuit to the fuse location
May 09, 2013 | Maytag Atlantis MDE6400AY Electric Dryer
Hotpoint Aquarius TCM570 - This unit is just over 12mths old!!! The heat function has ceased to work, it still spins etc but there is no heat. I've read on a previous posting relating to the same tumble...
Always disconnect power while working on unit....to easy, disconnect the two wires from the fuse, take black electrical tape and tape them together, test dryer if it works then disconnect taped wires and buy fuse install new fuse. Here is a website that should help, Tim:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Nov 27, 2010 | Hotpoint Dryers
The dryer is not heating up. The instructions on the dryer say to check the fuses..but dont know where fuses are located.
Most likely a faulty heating element. You can check here also:
repair2000.com/dryer.html
www.repairclinic.com/RepairHelp/RepairHelp.aspx
www.partselect.com/repair.aspx?appliance=dryer...repair
home.howstuffworks.com/how-to-repair-a-dryer.htm
www.doityourself.com/scat/householdelectric
Nov 08, 2009 | Kenmore 62602 Electric Dryer
Crosley dryer fuses where r they
The thermal limit is located on the right hand side of the heater chamber. The dryer will not run if it is open. SOME REPAIR PHOTOS
Sep 06, 2009 | Crosley CDE6000 Electric Dryer
Kenmore elite , no heat
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 27, 2009 | Kenmore Elite HE4 Electric Dryer
Dyrer runs no heat cannot locate fuses
2. Heating element
3. Thermal fuse
Jul 20, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Won't heat
2. Heating element
3. Thermal fuse
Jun 20, 2009 | Whirlpool GEW9200L Electric Dryer
Not heating
you have a dead short somewhere or someone monkeyed around the dryer to repair it
Jun 18, 2009 | Amana DLE330RAW Electric Dryer
My electric clothes dryer is not heating. Someone said it could be a fuse burned out but I have yet to be able to locate the fuses on the dryer.
sounds more like the heat element to me. you should have a tec take a look at it it is usualy free to diagnos.
Jan 04, 2009 | Dryers
Dryers Logo
59 people viewed this question
Top Dryers Experts
Richard Roth
Richard Roth
