Question about IBM ThinkPad T30 2366 Notebook
Memoryt slots problem
Soo i read a thread about the memory slots problem for ibm t30
how can we fix this without pressuring the ram into their slots?
  • Anonymous Feb 13, 2009
    i have 2 slots with 256 Mb each, totalling 512 Mb. unfortunately one slot doesn't work, so that it's only recognize one memory, 256 Mb. how to make both of the slots work as its initial performance?
  • groborac Feb 14, 2009
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
    mso-para-margin:0cm;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    Same same same!!!
    I bought the T30 with intention to keep it for longer period and found this is
    very expensive ****.
  • 4 Answers
This is a common problem, see this link for guidence. http://www.thinkwiki.org/wiki/Problem_with_failing_memory_slot
The only effective solutions are to replace the motherboard with one that has been modified by IBM to correct the issue or re-solder the cracked solder joints. If you choose to try the re-solder route yourself and have little or no experence with solders I recommend searching for additional links that explain more about the process. It does work if done right, but sometimes it takes more then one attempt when you're being careful not to get the motherboard too hot.
Posted on Feb 16, 2009
Thinkpad T30 2367-23S will not use 2GB Ram Card
noway max is max. buy yourself a 1gb and don't try to beat the system or lose it.
Mar 03, 2009 | IBM ThinkPad T30 2366 Notebook
T 30 IBM MEMORY PROBLEM
Hi!
Call 800-IBM-SERV and describe the problem. Say that you heard that there's an "engineering change" available to correct it, described in document MIGR-44772.
Repair should be free within the warranty period, and probably free even outside the warranty.
Have fun!
*Your vote is highly appreciated. Thanks in advance!
Jan 10, 2009 | IBM ThinkPad T30 2366 Notebook
IBM THINKPAD T30 memory slot problem
This problem can be fixed very easily. Find some one who knows how to solder and have them reflow slot #2. My T30 has run great for along time then all of a sudden I only had 1/2 my memory. I did what everyone should do in that situation I Googled it and it brought me here. I happen to be Service Tech for a cell phone company. I took my Laptop to work with me and reflowed the side mounts and every pin around the slot. It has worked flawless ever since.
Jan 04, 2009 | IBM ThinkPad T30 2366 Notebook
Ibm t30 post beep error 1 3 3 1
T30's do have a well reported problem with their memory slots. It is possible to fix it if you are brave and moderatly competent with a low-power (15-20W) soldering iron with a good bit (I recommend a flat oblique tip of about 2-3mm, not a pointed one).
Firstly, heat the soldering iron and clean all traces of solder from the bit. You can use a wet solder sponge, or even damp kitchen paper. It is VITAL to remove all solder.
Remove power and battery from the T30. Open the memory cover, and remove all memory.
Taking great care, press the bit of the hot iron with moderate pressure (about twice what you would use to press a key with one finger) on each pin in turn for about 1 second, on the contacts of the memory slot that is not working. Because you have no solder on the tip, it does not matter that you touch more than one contact at a time, but there are very small surface mount capacitors between the sockets. Be careful not to touch and unsolder these.
There is a warning here. Do no wipe the iron across the contacts. Always lift the iron before pressing it on the next pin(s). If you do wipe iron across the contacts, you WILL bend and short them. These are surface mount components, and the wire contacts are easily disturbed and shorted. If you do short the contacts, it will be difficult or impossible to fix.
Remember there are pins on both sides of the memory socket. Do not worry if some of the plastic of the socket melts, it is not a problem.
Continue until you have worked on all of the pins. Patience is a virtue here. Allow to cool, re-assemble and test.
I cannot promise that this will fix your T30, but I have extended the life of 2 out of 3 T30s I worked on in this way. Note extended, because the design flaw will cause the problem again sometime in the future. The board appears to flex, which puts strain on the solder joints.
May 24, 2008 | IBM ThinkPad T30 2366 Notebook
2nd slot issues
IBM's may need a bios update to read the 2nd slot do that first, and then check your setup for both slot availabilty. IBM always has, and always will make your life interesting.
got backup for your IBM Thinkpad?
Feb 16, 2008 | IBM ThinkPad T30 2366 Notebook
Ram Slot Not Recognised
This is a common problem with all thinkpads. The issue is caused by a blue case bumper pushing down on the reverse side of the memory slots and the memory door/cover. The memory cards will put uneven pressure on the solder joints causing cracks. There was a engineering fix offered to t30 owners under warentee. This fix was a motherboard swap out and a new memory cover with the proper distance needed. Since thinkpad is now owned by another company (lenovo) You may have issues getting the laptop fixed.
I had to purchase a new motherboard to fix mine. You can also send your machine in to a repair shop to have it reworked by hand but it usually costs about the same. (200$USD was how much I had to pay.)
Feb 02, 2008 | IBM ThinkPad T30 2366 Notebook
T-30 won't boot
Ten bucks says it's the memory. Do this: make sure there's only one piece of memory in the machine, and make sure it's in the slot closest to the back of the machine. At the same time you push the button to turn it on, be pressing the memory slot/memory as if you wanted it to be closer to the motherboard.
In other words, these are notorious for having bad slots (I use a T30) but if you only use the rear slot (most times it's the rear one, sometimes the front slot works, rarely both) and if you apply pressure to it so it makes good contact with the motherboard, it'll work for you.
The factory "quick fix" is to put foam tape on the cover in such a way ass to apply said pressure to the memory slots, thus keeping them connected without having to use your hand, or other appendage
Of course, knowing the beep codes is exactly the proper protocol for diagnosing the problem, and my colleague is correct in requesting it.
Good luck
Oct 13, 2007 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
127 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
