Question about Thermador Pro Harmony PRG304EH (Gas) Stainless Steel Kitchen Range
Thermador range 2006 blinks preheat 4 times then shuts off the oven
2 Suggested Answers
SOURCE: Thermador Pro Harmony Range--> Blue Lights Blinking
thermador rang, blue light blinking. Oven is not working,
Posted on Feb 05, 2010
Thermador P304CS error code 4 preheat blinks then 3 heat blinks
I wanted to post this up in case someone has trouble finding an answer and what worked for me. I found somewhere else that the 43 code (4 preheat;3heat) blinks was specific to the cooling fan or the temp sensor. I had started to remove the temp sensor off the back wall of the oven but was unsure where the wire ran to. There is a specific Ohm value it should have around 1080 I think (not 100% postive).
What I found during that search is what solved the oven problem for me. On the top of the range, if you pull off the grill grates and remove the center stainless cover you can access under the burners. You can do this without removing any wires or hardware. In the back of this area is a small cover held in by 4 screws. Remove that. Underneath it is the cooling fan switch. It is a mechanical switch that when the fan kicks on it pushes a metal sail that then causes a connection in the switch letting it know the fan is operating. This switch had a little bit of corrosion on one terminal but it is also prone to getting dirty. Clean it off and try to restart the oven. The sail should move forward and the switch makes connection. For me once it was cleaned and any corrosion cleaned off, my oven worked just fine. This is a pretty easy check with the 43 code since it does not involve a lot of invasive work. Hope this helps someone.
Mar 07, 2010 | Thermador Kitchen Ranges
Oven and broiler will not stay on.lights blink
I performed this exact same repair of a Thermador Model P366CS/03 on Thanksgiving Day 2017.
It seems a bit of grease had dripped down onto the microswitch with the sail on it. The grease was enough to prevent the switch from actuating. The thing is held down with two 4-40 screws and loose nuts. Be careful not to drop the screws into the range.
Now the problem I had was getting into the top of the stove. If the burner venturies are the least bit corroded, it's very difficult to get into the top level to gain access to the switch.
Nov 03, 2009 | Thermador PG486GEBS Stainless Steel...
Oct 03, 2009 | Thermador Pro Harmony PRG304EH (Gas)...
Oven won't shut off and preheat light flashes
"The thermal sensor shouldn't have gone out that fast". It could if it was defective.
Sep 17, 2017 | Frigidaire FEF366EC 30" Freestanding...
Oven shuts off
Sounds like the spark module has been shorted out and quite possibly the main control board. Apptech.
Oct 19, 2008 | Thermador RDF30 Dual Fuel (Electric and...
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Flashing lights
There is a code sheet that tells you what the problems depending on the sequence of blinking lights, but only the authorized dealers have this information. I do have a copy if you want to email me and I will forward it to you. detlvng@bellsouth.net
Apr 13, 2008 | Thermador PDR366ZS Dual Fuel (Electric and...
Thermador PDR30 4ZS/05 duel fuel
It's the motherboard. You must have had a power surge. I just replaced mine. Motherboard + shipping 200.00. its not easy to replace but not so difficult.
Mar 11, 2007 | Thermador PDR304ZS Dual Fuel (Electric and...
Thermador Pro Harmony PRG304EH (Gas) Stainless Steel Kitchen Range Logo
90 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
