Question about Refrigerators
Maytag MSD2356AE freezer drain clogged - Refrigerators
  • Timothy Puskas Nov 03, 2012
    I tried to clean out the freezer drain. I used a 3 strand copper wire. The wire only goes into the drain 2-3 inches and no an inch more. I assume the drain is frozen. The whole unit has been off for 3 days due to a power outage in NJ.
    Problem Solver:
  • 16 Answers
Just simply clean out the drain
Posted on Nov 03, 2012
Water leak in bottom of freezer and then freezers
Most likely, your defrost drain is clogged. Search youtube for videos on how to clear out a clogged drain on a refrigerator.
Aug 13, 2015 | Maytag Refrigerators
MAYTAG SIDE BY SIDE MSD2356AE. FREEZER NORMAL TEMP. FRIG. 60 DEGREES.
make sure that there is nothing blocking the flow of air coming in. the fridge is cooled by the air in the freezer. also you might think about replacing the relay on the compressor. it may be going out.
Aug 11, 2008 | Maytag Refrigerators
Technical bulletin
You have a clogged drain in the freezer section. Without clearing this drain out completely, this issue will return. When the unit defrosts, the water needs a place to exit the freezer section, in the freezer behind the false wall is a drain hole at the bottom. This drain is clogged and needs to be cleared all the way through before it will work correctly. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 22, 2014 | Maytag Refrigerators
I have condensate leakes into the bottom of my freezer and ices up the bottom of the freezer
YOUR DEFROST DRAIN IS CLOG UP YOU WILL NEED TO PULL THE BACK COVER OFF IN THE FREEZER SIDE AND CLEAN THE DRAIN YOU WILL SEE IT AT THE BOTTOM BEHIND THE FREEZER COVER
Oct 31, 2012 | Maytag Refrigerators
Water leaking from freezer side of side by side refrigerator..model MSB2354AR
Sounds like a clogged drain, If ice is on bottom of freezer floor then it is def. a clogged drain. Remove rear panel and clear drain of ice and possible obstruction.
Feb 08, 2010 | Maytag Refrigerators
My Maytag side by side fridge freezer is leaking at the bottom and ice is collecting at the bottom of the freezer. I cannot find any model number but think it's about 6 years old
The drain is clogged behind the wall in the freezer you can do one of three things take the back wall inside the freezer off and thaw the drain in the bottom and clear it out,Pay someone else to do this,or you can mover your food for a day unplug the unit open the freezer door and leave it off for 24 hours allowing the ice to clear from the drain,seems to happen about every five or six years with Maytags..
Aug 12, 2009 | Maytag Freezers
Maytag msd2356ae refrigerator warm freezer cold
starter switch on the compressor
Dec 31, 2008 | Refrigerators
Maytag Frostfree Freezer ice at bottom
hi thanks for the question .The drain tube is clogged up. Pull fridge away from wall, remove back panel, clean all coils. let thaw 24 hrs. find drain tube by drain tray clean tube to freezer thanks the appliance doc
Sep 28, 2008 | Freezers
Water leakage in and below freezer on Maytag MFD2560HES
you have a clogged defrost drain, or your ice maker (if so equipped is leaking. clogged drain can be remedied removeig drawer , andmelting ice build up behind rear panel of refrig, you see an aluminum trough that the water drips down,using a hair dryer melt all thatice out of the way to clear the drain tube(i use a steam machine i purchased from infomercial works extremly well
Feb 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
81 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
