Question about Icom IC-T7H VHF/UHF Handheld Dual Band 2-Way Radio
Icom t7h stuck in lock mode
Icom t7h lock mode will not turn off. button is off but radio shows lock
  • 580 Answers
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Posted on Nov 04, 2012
Receives,no Tx
Many possibilities:
1: The radio took a hit and broke the PCB or the connection to the RF out jack.
2: Some other PCB joint failure
3: The RF output IC is toast
4: The driver is toast
5: The tx oscillator is so far out of whack it cannot develop the frequency it is set to.
6: You have a bad cable or antenna connector
7: You have a bad battery, battery contact or power connection
8: You have a power supply or other problem
Sep 26, 2015 | Icom IC-T7H VHF/UHF Handheld Dual Band...
Icom icv8000
do you have a monitor button depressed, I forget which button, but on Icoms theres one to monitor the input freq
maybe its stuck
Dec 19, 2013 | Icom Radio Communications
Trying to unluck an ICOM IC-4008M radio
The manual can be downloaded.
http://www.icomamerica.com/en/support/kb/article.aspx?ArticleNumber=63AF543918
To toggle the "Key Lock", push and hold the POWER button for 2 seconds.
Oct 24, 2012 | ICOM Informatique IC-4008 (14 Channels)...
I bought a new logic unit (front face) of Icom F121 and it needs to be restored. How do you restore a logic unit for the Icom F121?
1- You have to to "Reserve" mode.2- Change Set Mode Access: Inhibit to Enable3- Common>>Secutity Change Set Mode Access : Inhibit to Enable4- Enter RX TX frequency and write to the radio.
or you can download version Rev 1.7 from here:
http://www.two-way-radio-tools.com/icom-softwares.html
http://www.two-way-radio-tools.com/icom-radio.html
Aug 27, 2010 | ICOM Informatique IC-F121 VHF 136-174MHz...
Screen locked can 16 (model HX270S)
Hi there, I think you might have the priority channel switched on. Look for a button labeled PRI or somthing like that, press it once or if that fails press for 3 seconds.
Apr 24, 2009 | ICOM Informatique Icom IC-F11S 5W 2ch VHF...
IC A23 Portable VHF radio Locked
ic a 23 quero scannear como fazer /???
please scam mode /???
Mar 04, 2009 | ICOM Informatique IC-A23 VHF NAV/COM Air...
Programming an Icom IC R5 scanner
This is a problem with any scanner which has no keypad..
First set the squelch (gets rid of the hissing noise and allows the radio to scan)
to do this....
On the side are 2 buttons, the bottom one is monitor.
press and hold then look at the display,
turn the top dial until "AUTO" appears,
The squelch should now keep the radio quiet.
Now the tuning step..
You need to set this because if your radio was on 450.000 and you wanted to listen to 450.012.5 you would miss it if your radio was making 000.025 "steps". IE you would need 12.5 steps. This is the most common step used by ambulance etc in the UK, you will need to check local band plans.
Stick with 12.5 and you should get most stuff on VHF / UHF.
For airband 12.5 will get most stuff, but some is now changing to 8.33.
For HF (below) 136 Mhz I'd use 5
To set the step....
On the front there are 4 big buttons.
press [V/M.S.MW.SKIP] to select VFO mode,
then press [BAND.LOCK] to select the band you want to listen to,
then press [TS.SET] to enter the step
turn the dial to select your step (stick with 12.5 for now)
press [TS.SET] to exit back to VFO mode
To scan...
First set the scan type...
Press and hold the one that says [MODE.SCAN] for 2 seconds and look at the display,
turn the top dial until the screen reads ALL,
press [MODE.SCAN] again and the radio should start to scan with the 12.5 steps you set earlier.
If you want to change scan direction, just turn the top dial.
If you want to stop the scan, just press [MODE.SCAN].
When you hear something interesting, make a note of the frequency on the display.
To set memories (store frequencies).....
to get close to the frequency you made a note of, press [BAND.LOCK]
Then set the actual frequency with the top dial,
press and hold [V/M.S.MW.SKIP] for 2 seconds to select memory write mode (1 short and 1 long beep)
turn the top dial to select which channel you would like to overwrite. Start with 01.
press [V/M.S.MW.SKIP] for 2 seconds. ( 3 beeps )
Thats it!
Any more problems just post on here and either me or someone else will help.
M3ODQ
Dec 22, 2008 | Icom IC-R5 Handheld Scanner
Icom r5
A quick "get you started" guide.....
to do this....
To set the step....
To scan...
Thats it!
M3ODQ
Jun 24, 2008 | Icom IC-R5 Handheld Scanner
Icom IC-T7H VHF/UHF Handheld Dual Band 2-Way Radio Logo
237 people viewed this question
Top Icom Radio Communications Experts
peter0911
Steve
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
