Question about Dirt Devil Featherlite Bagless Vacuum M085845Vacuum
Dead Dirt Devil Featherlite
No Power , completely dead
  • Dirt Devil Master
  • 18,424 Answers
1. Power cord not firmly plugged into
outlet.
1. Plug unit in firmly.
2. Blown fuse or tripped breaker. 2. Check fuse or breaker in home. Replace fuse/
reset breaker.
3. Needs service. 3. Take to service center or call 1-800-321-1134.
4. Thermal Protector activated.
4. Unplug cleaner. Allow to cool for 30 minutes
Posted on Nov 04, 2012
5 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Dirt Devil Featherlite Bagless Upright
Check the brush roll, are the bristles worn down? Check the belt also, if it is stretched, then it won't drive the brush roll like it should.
Posted on Jan 15, 2008
galati2k
  • 281 Answers
SOURCE: I have a dirt devil featherlite bagless vacuum;
there are 3 screws 2 on the left side behind the hose and 1 on the right back by the wheel.that will take the cover off.if you need to get into the bottom there is a screw on the bottom plate in the area where it looks like the belt travels.is the brush roller turning if not then your belt is probably broke.before you replace the belt clean off the motor shaft and get the old rubber off it otherwise the new belt won't last long.please leave feedback .be sure to clean your filter inside the dirt cup
Posted on May 05, 2009
VacuumRepair
  • 438 Answers
SOURCE: I have a dirt devil featherlite carpet shampooer.
Hi There,
We actually do carry the foam filter for your Dirt Devil Featherlite (also manufactured as the Easy Steamer) carpet cleaner.
According to the Dirt Devil parts diagram for the CE6000, your machine takes the following foam filter. Here's a direct link to the filter on our website:
Dirt Devil Featherlite, Easy Steamer Foam Filter Part# 1-700750-600
Here's a link for the parts diagram for your Dirt Devil Featherlite CE6000 carpet cleaner. This will give you all of the part numbers, and drawings for each part on your machine should need any further parts:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/dirt-devil-easy-steamer-featherlite-ce6000-parts-diagram.pdf
I hope this helped. If you have any further questions or concerns, please feel free to use the comment field here on the repair page to contact me, I'm always happy to answer any follow up questions.
If you found this repair helpful, please be so kind and rate the repair helpful and / or leave feedback for me. Thanks so much!
Chris Jones
GoVacuum.com
Posted on Apr 22, 2010
Testimonial: "That is it! Thank you so much. God is soooo good!!!"
VacuumRepair
  • 438 Answers
SOURCE: Got Dirt Devil Featherlite,keeps burning the belt
Hi There,
When a belt breaks immediately after installing it, this can ONLY mean one of two things. The first is that the belt was put back on incorrectly, and it may be pinched underneath of the beater bar. This would cause it to break immediately, but I seriously doubt after 4 belts that you put the belt on wrong all 4 times.
The second, and more probable cause is that your roller brush has gone bad. This could be why the belt broke in the first place. In order to test to make sure the brush is bad, unscrew the bottom plate, and remove the brush like you were changing the belt.
Hold the brush at the very end on both sides, using only your finger tips. While holding just the bearing caps, try spinning the bar with your thumbs. Does the brush spin freely in your hands? It should spin completely around 4-5 times on each spin. If the brush will not spin, or if you feel any resistance to it spinning, this is the reason why your belt continues to break.
If the brush can not spin, the motor shaft will continue to try and spin the belt, but since the brush doesn't spin, and the belt doesn't move, the motor shaft will just burn right through the back end of the belt.
If your machine is actually the model that's listed on this Fixya repair page, the Dirt Devil Featherlite model M085845, then your machine uses the following roller brush:
Dirt Devil Plastic Brush Roll for Model 085845 Part # 2-881020-000
The next time that change the belt, install the brush back into the machine, but this time pull up on the belt towards the brush to make sure that the belt spins freely, and spins the brush as well. If the belt doesn't spin the brush, there's some issue, and the belt will break as soon as you turn the machine on.
I hope this helped you. If you find out that you don't need a new brush, feel free to use the comment section here on the repair page and let me know, I'd be happy to walk you through some more advanced diagnosing. If you found this helpful, please be so kind and rate my repair and / or leave feedback for me.
Thanks so much,
Chris Jones
GoVacuum.com
Dyson dc07 cut out whilst hovering. Fuse OK switch seems ok but vac. completely dead
If it has a clog or restriction the motor will shut off if it gets too hot.
Jan 21, 2017 | Dyson Vacuums
My dyson dc30 is completely dead. What is a proper sequence to find out what is wrong
Is it plugged in?
Is there a power outage currently happening in your area?
is there power at the socket?
Is the plug fuse intact?
Is it switched on?
Is there any visible signs of damage on the cable?
Is there any visible signs of damage on the vacuum?
All above but still not working then bring it to a repair depot!!
Nov 10, 2016 | Dyson Vacuums
Dirt devil featherlite vaccum were does the extra hose go?
Hi, it's Jeremy from Crucial Vacuum.
Attached is a copy of the user's manual for the Dirt Devil Featherlite Bagless Vacuum M085845. You can find a diagram of your vacuum on page 11 depicting where each part is located. The 2 hoses for your vacuum are listed as numbers 22 and 23.
http://dirtdevil.com/file/898/
You can purchase direct your replacement Dirt Devil parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dirt-devil.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 04, 2014 | Dirt Devil Featherlite Bagless Vacuum...
No suction on floor part
From your problem description, you may have a blockage in the foot. Check the intake under the vac by the roller.
May 01, 2010 | Dirt Devil Featherlite Bagless Vacuum...
The Dirt Devil Featherlite vacuum cleaner throws up the dirt back out. Sometimes the vacuum cleaner doesn't pick up any dirt
You have a blocked vacuum hose take hose off and out side. Push the garden hose from one end to the other, this will push out the blockage
Dirt Devil Featherlite Bagless Vacuum M085845Vacuum Logo
430 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
