Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Replace fuel line 455 husqvarna - Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
  • Husqvarna Master
  • 2,239 Answers
The fuel hose is just and interference fit in the tank, grab it with a pair of long nose pliers through the open fuel cap and pull it down and out, trim the end of a new hose so as it will push into the top of the tank, useing a pair of long nose pliers grab the end again through the filler hole and pull down into the tank
Posted on Nov 25, 2012
  • 211 Answers
SOURCE: husqvarna chain saw, model 455 will not oil properly bar and chai
hi cindilou50
check the oil filter from the oil tank,the oil line ,the worm gear and the oiler under the clutch.Clean the ways where the oil goes with compresed air.(after you fill out the oil tank)Also check the oil hose.
best regards savumihai71
Posted on Dec 01, 2008
dontbother10
  • 2220 Answers
SOURCE: I have a husqvarna 455 rancher. It was working
Why would you pay for something and then not force them to make good? I have a large bridge for sale, CHEAP. Make you a heck of a deal.
Take it back!!!
Lou
Posted on Sep 17, 2009
dontbother10
  • 2220 Answers
SOURCE: Fuel Mixture Husqvarna 455 Rancher Chain Saw
Page 17 of your Operator's Manual says 50:1.
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Posted on Sep 25, 2009
dontbother10
  • 2220 Answers
SOURCE: What is Fuel Mixture Husqvarna 455 Rancher Chain
Duplicate post Close/delete
dontbother10
  • 2220 Answers
SOURCE: How do I replace chain on Husqvarna 455 rancher
Unlock the chain brake and remove the clutch cover. This should provide what you ask:
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If you get stuck or need model specific instruction, there is very detailed illustrated instruction in your manual under "Fitting the bar and chain". The tool-less adjusters add needless layers of complexity IMO.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 06, 2010
How do you replace fuel line on Husqvarna 455
You will need to pull the fuel line out of the fuel filler hole. Remove the fuel filter. Pull the line out of the tank. When re-installing the line cut the end at an angle to allow you to push it back through the hole (it is tight). Reconnect the filter. Then attach to carb.
Aug 21, 2014 | Husqvarna Garden
What is the gas / oil ratio mixture for husqvarna 455 rancher model ?
50:1 that's 2.6 ounces of 2-stroke oil (preferably with fuel stabilizer) to one gallon of gas. I recommend using 89 octane gasoline for all small engines. It has little or no ethanol in it, as opposed to the 10% typical in 87 or 86 octane fuel. This will prevent a lot of fuel issues, especially if you are not using the tool daily or at least weekly.
Aug 02, 2014 | Husqvarna "965030298 - 455 Rancher, 20""""...
How to change the fuel line on a Husqvarna 455 Rancher
feed a wire threw the tank cut the new hose down to 1/3 about 1/2'' long slide it over the wire and pull it back till it pops threw then pull it threw
Aug 09, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
455 rancher runs for about 5 min. than stalls and wont start until cold than problem repeats
Sounds like a fuel problem. Something might be expanding as the saw warms up and is cutting off the fuel or introducing an air leak. Carby may require a new kit and check the fuel line
Jan 17, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 455 rancher has no power at full throttle, but will start and idle normal.
Check for plugged fuel filter, air cleaner, and muffler. Check the fuel lines for decay or other damage. Check the chain for proper oiling and not so tight that you can't turn it by hand. Hope this helps!
Nov 25, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a husqvarna 455 rancher that won't run at full throttle unless the choke is on. It runs at half throttle fine.
Clean or replace the fuel filter. Check the fuel lines for decay or other damage. Check the muffler for plugging of the screen. Be sure to run with fresh fuel mix and to shake the container thoroughly each time just before filling the tank to prevent oil starvation. Hope this helps!
Nov 11, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 455 rancher . it has low compression and no fuel to plug . wont start but piston and rings are fine .Help
it could be the small gasket between the head and carb. they are also bad about the fuel line coming out of the tank gettin rubbed and making a small hole or pinched.
Oct 12, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Take it right back to repair shop and have them fix under their warranty.
It is possible the fuel hasn't got to the carbureator due to plugged fuel filter or fuel finder OR an air leak in the fuel hose.
Sep 15, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
My 455 rancher won't maintain power. I have
if its over a year old and you used other than 93 octane, you need to rebuild the c arb, i did an runs like new
Jul 31, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
275 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
