Question about Air Tools & Compressors
HOW TO CHANGE THE BATTERY IN A RECHARGEABLE INFLATOR/SPOTLIGHT.
THE MODEL # IS VEC280POB. IT IS CALLED POWER ON BOARD
    Problem Solver:
  • 16 Answers
Go buy a new rechargeable battery to put in it
Posted on Nov 03, 2012
I NEED A POWER CORD CHARGER FOR THE 3,000,000 CANDLE POWER HALOGEN SPOTLIGHT. WHERE CAN I FIND ONE
If this is the usual sort of halogen spotlight, it is usually supplied with a mains charger adaptor and a lead to charge it from the car cigar lighter socket.
Both those items are also commonly supplied with a range of car-related rechargeable items, torches, jumpstarters and so forth.
I have several such items and I find the 12 volt lead and mains charging adaptor completely interchangeable between all of them. Rechargeable halogen spotlights generally have a very disappointing battery life of around 20 minutes unless a very expensive professional model is bought.
If it is not a rechargeable type that must be permanently connected to the car cigar lighter, the power cord is usually permanently fixed to the lamp but if it isn't, the cable will need to be substantial enough to carry several amps - something similar to that of perhaps a large coolbox.
Apr 11, 2017 | Camping, Backpacking & Hiking
I have a Phillips flat panel tv that won't come on
The clicking sound is the switched mode power supply trying to power up the TV. This problem is usually caused by parts called capacitors on the power supply board going bad. You can repair the board yourself by replacing the capacitors. On this model there are 4 main capacitors that will need to be replaced. If you feel that you can do the repair yourself then get back with me and I will help you get the right parts, if not you can take the unit to a repair center near you and they can replace the power board. tech@ccl-la.com
Jul 24, 2012 | Televison & Video
WHAT IS THE VOLTAGE OF MY VECTOR MODEL VEC117FS
6 volts rechargeable battery. Check with the manufacture for a recharger for the 110v and or a car charger for your light.
Mar 27, 2012 | Vector 1 Million Rechargeable Spotlight
I have a panasonic TC-P42C1 blinks 10 times no picture no sound What is common to go on this model (which board)?
Check the tv power supply board.That the board where the tv power A/c plug into it.Check the tv power supply board carefully for dying components parts that are called capacitors parts.Bad or dying capacitors parts on the tv power supply board are alway causes this problems to the tv.Bad or dying capacitors parts are very easily to spots,all these capacitors parts are alway bulges up onto it tops.Never have plats round tops as they suppose too.U have all the tools and know basic electronic also can do basic soldering work,u should changes all these dying capacitors parts in the tv power supply board with no problems at all.If u check all over the tv power supply board and it have no dying and leaking capacitors parts to the tv power supply board all.Then the tv Y-Sustain main logic Tuner board it is the causes and the problems.The tv Y-Sustain main logic Tuner signal board that is the board that take in the tv imcomming tv broadcasting signal cable plug into it.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board and or the tv Y-Sustain main logic Tuner signal board for the replacement.
Nov 06, 2011 | Panasonic TCP42C1 Plasma TV
Is not working at all
If it will not turn on whatsoever then i suggest opening the TV and finding the model number on the power board which will have several large canister looking objects called capacitors on it. Google search this model number and also search on ebay and order a replacement board. This is heavily likely to be the issue.
Oct 24, 2011 | iLO 3200 32 in. LCD Television
I need a recharge cord for handhold Flashlight chiacgo I'll thanks
This model has a built in charger so all you need is an extension cord. You will find the plug in underneath the black rubber flap that is located on the side.
Nov 12, 2010 | Vector 1 Million Power Series Spotlight &...
I'm looking for the power cord/charger for Vectren Spotlight/Inflator. We moved ....somehow the cord got separated and I think I tossed it when I couldn't find what it belonged to. The spotlight was in...
The Vector Spotlight/Inflator has a built in charging system. All that needs to be done to recharge the batteries is to plug an extension cord into it.
Nov 03, 2010 | Camping, Backpacking & Hiking
I have a mod # vec280pob the white plastic gear the works the air compressor has broken teeth on it do ya carry that cant find there web site...
Vector was bought by Black and Decker in 2006, you can get Info, order parts or find a Service Center at this link;
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Jun 26, 2010 | Vector 1 Million Power Series Spotlight &...
Power On Board 3 Million Rechargeable Spotlight
Vector is now owned by Black and Decker since 2006, you can order one at their website, you will need to enter the model #, here is the link http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Jun 13, 2010 | Vector 3 Million Candlepower Rechargeable...
Light wont light up
The rechargable battery is dead, it has just enough juice to light the LED but nothing else. You can order a replacement battery from www.dewaltservicenet.com All Vector Products, Service and Parts are sold by Black and Decker which purchased Vector in 2006. The products are rebranded under the Black and decker name now.
May 19, 2010 | Vector 1 Million Power Series Spotlight &...
Air Tools & Compressors Logo
305 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
