Question about Sony Betacam SP Small Videocassette 30 Minutes Digital Betacam SP Tape
Sony Betacam SP Error02-694 - Sony Betacam SP Small Videocassette 30 Minutes Digital Betacam SP Tape
3 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: Betacam Sp Error Code
It seems mechanical problem and you need to apart unit.
I would advice you to get Maintenance Manual of BVW-75 before to open unit and get help from mechanical exploded section.
Below is picture of Maintenance Manual and part of mechanical exploded view...
It is high end broadcast model and needs care in maintenance.
Good Luck.
Posted on Nov 26, 2008
  • 221 Answers
SOURCE: Beatcam SP error message
BVW-75 error 09 is "threading motor time out". Look for something obstructing the travel of the threading ring inside the deck (the ring which pulls the tape around the video head).
Posted on May 21, 2009
Sony bvw300 humidity error
Use an hair dryer and warm within the set. If it clears wipe off any dew that has set in . Wipe also the head clear with a good swab. if the fault is recurring then clean the dew switch sensor or replace.
This is found inside the loading compartment , a small square block. about 1.5mm. Helpful. Good day
Jun 10, 2010 | Sony Betacam SP Small Videocassette 30...
Error02-694 Sony Betacam Deck UVW-1800
UVW-1800 error 02-694 indicates a problem with one or both reel motors. check the cables going to both motors; have seen failures related to these cables.
Jul 21, 2009 | Sony Betacam SP Small Videocassette 30...
Sony Beta sp deck 1800 wont take larger tape down
Most likely problem when a Beta SP deck won't take the large tapes is a bad cable in the cassette housing. Replacement isn't too difficult, and the cable only costs about $20.00.
Jul 14, 2009 | Sony Betacam SP Small Videocassette 30...
May 02, 2009 | Sony Betacam SP Small Videocassette 30...
The machine is a SONY VIDEO CASSETTE RECORDER UVR 1400 AR
uvw-1400 error 02-803 is "tape tension error when threading". possible bad threading motor or threading mechanism.
Feb 11, 2009 | Sony Betacam SP Small Videocassette 30...
Digital betacam tape stuck in Sony UVW-1800 deck
Digital tapes should still eject normally (they are the same size and shape) which indicates that it has jammed somewhere inside.
If you want to fix it yourself you will have to remove the cover and check the tape.
If the cassette hasn't spooled up and all the tape is inside the cassette you should be able to unscrew the carriage (the cradle that takes the tape in and down) and remove it that way.
If the tape has spooled around the heads there is a cog (can't remember the exact position of it) arranged vertically near the side of the machine that you can manually wind the spooling arms back into the cassette.
Good luck
Dec 29, 2008 | Sony Betacam SP Small Videocassette 30...
Good Luck.
Nov 26, 2008 | Sony Betacam SP Small Videocassette 30...
I have a Sony UVW 1800 Beta SP deck. This morning, after completing a dub, I rewound the tape. The machine made a sound, the tape stopped and became stuck in the machine. I received an error code 02-803. I...
check your tape deck unit throughly check for any physical damage of REWIND/FORWARD Gears.and FLY Wheel.
and dis locateion of some lever positions.
defnitly you get solved
Nov 13, 2008 | Sony Betacam SP Small Videocassette 30...
Sony uvw 1600 betacam sp does not power up
Check the power supply area for the fuses for one. Second, the power supplies in these units are switch mode supplies that require a jump start from a small cap. It is possible that the "starter cap" is defective. There are other reasons for this type of behavior as well. Keep us posted on what you find.
Dan
May 30, 2008 | Sony Televison & Video
Electronics - Others Logo
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
