Question about Buffalo Technology 250GB USB SATA 2.0 HD 250 GB Hard Drive
File size limit for Buffalo HD 250 GB Hard Drive backup
I have a 5.9 GB *.pst archive that I would like to copy to the external hard drive. It appears this file is too large (there is plenty of available space on the hard drive itself).
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 137 Answers
The file is too large meaning that the size of that SINGLE file is too large. Your hard disk is probably formatted to a FAT32 file system, this results in a maximum of 4gb PER FILE maximum transfer. What you could do is archive it into a few parts using winrar and then moving it onto the disk, and when you need the file just extract the archive. Your problem isn't the total free space, it's the size of that file chunk.
Posted on Nov 04, 2012
5 Suggested Answers
micromaster
  • 3614 Answers
SOURCE: error copying file or folder
One of the most important yet overlooked elements of PC maintenance is data backup. If you do not perform regular backups, chances are your productivity will eventually suffer from data losses or a failed Windows installation.
All versions of Windows after 3.1 ship with a free backup utility called Microsoft Backup. It is not the best backup program available, but it may be sufficient for your needs. (Backup is better in later versions of Windows. Microsoft recommends Win98/Me users purchase a third-party utility.) If you want more control over your backups, consider purchasing a third-party program.
Backup is part of the System Tools utility. However, Setup does not install it by default in Win98/Me/XP Home. If you cannot locate Backup, visit the Microsoft support site and query for article No. 152561 (Win98), No. 264541 (WinMe), or No. 302894 (WinXP Home).
In Win98/Me, click Start, select Programs, Accessories, System Tools, and click Backup. To create and run a backup, click the Create A New Backup Job radio button and click OK. Follow the prompts to create a full or partial backup. If you want to create a backup set and run it later or run an existing backup set, open Backup and click the Open An Existing Backup Job radio button and click OK. You can now access the main Backup dialog box.
In Win2000/XP, navigate to the System Tools utility and select Backup. Click the Backup Wizard button. If you do not see a Backup Wizard button, click the Welcome tab. In WinXP, the wizard will start automatically if you are in wizard mode. Follow the prompts to create your backup set.
When you reach the last dialog box, Completing The Backup Wizard, you can click the Advanced button to create a backup schedule (this option is not available in Win98/Me). When you reach the When To Back Up dialog box, select the Later radio button and click the Set Schedule button. Perform data backups on a schedule that is appropriate to the importance of your files (once a week is a common timeframe). You should also perform a system backup at least once a month.
If you do not want to use the wizard, or you are working with an existing backup, open Backup and click the Backup tab to access the main Backup dialog box.
Posted on Feb 11, 2008
Crankstart
  • 696 Answers
SOURCE: My PC frozen when I connect Buffalo Technology 250 GB HD
This generally means you have a hardware failure in the drive or enclosure. The simplest way to test which is to have a hardware tech move the drive into a new enclosure and see if it works.
This will void your warranty if you do it, so, if the drive is under warranty and there are no files you consider valuable on the drive, call the manufacturer for warranty support.
If you value the data more than the drive is worth then take it to your local hardware vendor and ask them to test the hard drive in a new enclosure. Good odds it will work this way but if not you may need the help of a data recovery specialist.
In North America I use Armor-IT, if you are in a different region and the new enclosure fails to garner results, comment back with your region(Country, State, City) and I will supply you with the closest reputable facility.
Chris
Posted on Jul 08, 2009
bob_computer
  • 3153 Answers
SOURCE: remove all programs and encryptsion software from buffalo minista
I devised these simple steps that tend to remedy quite a few issues with most portable / external hard drives (though not always)
BUT the section that may be of interest to you is just after step 5.
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply
Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again.
If you checked and fixed anything there and still have issues carry on reading.
Go to your control panel and then administrative tools, select Computer Management.
Now select Disk Management and expand the window.
Your drive should be listed here, if not then you need to check your computer hardware has not got any issues before proceeding.
If your drive is listed and says healthy then right click on it an select Properties, click Tools and then Error Checking, Check now, tick the two boxes and then Start.
This will attempt to fix most minor / common errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed but did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. When it is done restart your computer and you should be good to go.
If you still have problems with the drive you might want to look at other areas.
Posted on Aug 23, 2009
SOURCE: Can't access Buffalo HD-HB250U2-WR 250gb Ext. Hard
I think I have the answer, plug your cable in. If windows 7 shows the message unknown device don't remove the usb. instead turn the switch on the back of the external hard drive off for a few seconds then back on. Windows 7 should then for some unknown reason find the correct drivers and your buffalo hard drive will now work. This worked on mine.
Cliff
hotdesignerwear.com
Posted on Jul 26, 2010
Toshina External Hard Drive backup files in
Which program did you create the backup with? You'll need to install a copy of that software on your new computer. Then you will let the software find the backup and restore it. This will only work if you used a file backup. Many backup programs do not restore to systems with different hardware (different CPU, hard drive, OS, etc.).
However, I don't know which software uses *. PFT, pfi or pfp extensions. PBF is the format for one of the older Paragon Backup software versions. Acronis uses *.TIB . For a list of many of the software extensions used for backups, see https://www.file-extensions.org/filetype/extension/name/backup-files .
Canvio drives used to include NTI BackupNow EZ software. However, I believe that NTI backups use BJF or NTI extensions. The installer for that is here: http://support.toshiba.com/sscontent?contentId=3044104 . To check for other software for your external drive, try looking up your drive at http://support.toshiba.com/support/home . The available drivers and software should be listed. Alternatively, check if the backup software installer is still on the external drive.
I hope this helps.
Mar 03, 2017 | Toshiba Canvio Plus 320 GB 2.0 Portable...
My Buffalo hard drive was working fine but my computer had virus. I removed the virus and then copied a few files to the external hard drive. Later I realize that the virus wasn't completely remov
Consider a low cost data recovery service such as http://FreeDataRecovery.us
They do remote access data recovery over the internet and also offer do-it-yourself data recovery advice.
Oct 18, 2012 | Buffalo Technology HD-PX500U2/RD 500 GB...
Can not copy outlook messages
It looks like your external hard disk in FAT32 system and outlook messages file .PST is more then 4GB.
To know the file system of the Hard Disk right click on the drive select properties.
Check your file system first. FAT32 will not support more than file size of 4GB.
There are 2 options to copy.
1. Split the .PST in to 2 or more outlook data file
or
2. Convert the FAT32 System to NTFS.
To convert from FAT32 to NTFS. go to following link
http://support.microsoft.com/kb/307881
Mar 07, 2010 | Western Digital (WD3200JS) 320 GB Hard...
This might be problem with the cable. Try using another cable.
Sep 02, 2009 | Buffalo Technology (HD-HB250U2) 250 GB...
Chris
Jul 08, 2009 | Buffalo Technology (HD-HB250U2) 250 GB...
Drive Full After Backing-Up Just Under 4gb of Files
Are you trying to create one giant zip file or something similar? It sounds as if your Lacie 250gb hard drive has been formatted with a FAT32 filesystem and you are running into the maximum file size limit of 4gb minus 1 byte. Try just copying your files without using any compression utility or try reformatting your Lacie 250gb hard drive with the NTFS filesystem instead.
Feb 07, 2008 | LaCie (300728U) 250 GB Hard Drive
Backup hard drive to an external hard drive
"what the error actually says is, you have either run out of space, or the backup file (.bkf) is too large for this disk. note: if the disk is formatted with FAT32, the maximum possible size for the backup file is limited to 4 gigs."
That error means that the FAT32 file system only allows 4GB files or smaller to be transfered. The chance that the backup file (.bkf) is larger than 4GB suggests that this file is causing your problems. You could try manually copying around that file (selecting all files from that folder except the large one) and see if that works.
Usually you will get many errors copying a drive directly as system files will be inaccessible and whatnot. Your best bet is to limit your copying to "C:\Program Files\" and "C:\Documents and Settings\", assuming you have Windows.
Dec 13, 2007 | IO Magic Corporation GigaBank (I250HD35)...
Buffalo Technology 250GB USB SATA 2.0 HD 250 GB Hard Drive Logo
254 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Ali Reza
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
