Question about Coleman Powermate Premium Plus 6250W Portable Generator
Spark plug gap for coleman 1750 - Coleman Powermate Premium Plus 6250W Portable Generator
2 Suggested Answers
  • 4 Answers
SOURCE: coleman powermate plus 1750, changed gasoline,
check the carborator see if the butterfly valves or closed, than see if the govener can move back and forth and than go farther and if you move the throttle will the govener butterfly valves move. if that is stuck move it or use some lubricant and there should be 2 linkages, 1 inbetween the throttle and the govener, and 1 inbetween the govener and the carborator.
Posted on Oct 25, 2009
No electric output on coleman 1750
start it up, plug and electric drill into it and spin the drills check by hand backwards. if that doesnt work it needs brushes. it has lost its magnetism. doing this trick may get it back for you. good luck be careful as the drill will start if you are successful
Jul 15, 2017 | Coleman Electrical Supplies
What is the Coleman Powermate 5000W Generator spark plug gap
Powermate 435001 w Subaru EX30 spark plug gap is between ..006 - .007 according to manual.
Sep 22, 2012 | Coleman Powermate Subaru 5000W Portable...
Powermate plus 1750 portable generator. Has fresh gas, will just runs a couple of seconds on starter fluid and just stops.
It could be a number of thinks. plugged fuel line, carburetor, but dont use to much starter fluid this can burn a hole in the top of your piston. check to see if its getting any spark.
Aug 14, 2011 | Coleman Powermate Premium Plus 6250W...
Ignition coil spark is weak. And where can i find
FIRST check the gap of the flywheel magnet to the magneto coil. Use a business card as a spacer and adjust the gap. If unit has points rather than electronic triggering, check those and timing and gap.
Mar 22, 2010 | Coleman Powermate Premium Plus 6250W...
New spark plug, carb cleaned, new gas.....won't start......could it be the coil?
First check the surface between the rotor and the coil and make sure there is no rust. If there is take some fine emery cloth remove the rust from both the rotor and coil. Use a noncondutive cleaner to remove any metal particals. If you remove the coil you can use a standard business card to reset the gap.
After completing this process if it still does not start check the plug and make sure you have a spark in the plug gap. You can test it by removing the plug and reattach the plug wire then lay the plug on the head and try starting the engine. The spark should be a bright blue. If you do not have any spark recheck the plug gap. If the spark is a red color your coil is weak and needs to be replaced.
Nov 24, 2009 | Coleman Powermate Powermate 5000W...
Coleman powermate plus 1750, changed gasoline, spark plug, oil. cannot get it to start/run
Oct 24, 2009 | Coleman Electrical Supplies
Coleman Powermate Premium Plus 6250W Portable Generator Logo
66 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
