Question about Apple iPhone 4S
I dropped my Iphone 4s and my screen went black. I was listening to music when it happened and I can still hear it. What should I do.?
I dropped it straight down. like where the headphone jack and the sleep button is.
  • 580 Answers
Please New Software install in the Phone Problem will Solved
Posted on Nov 04, 2012
  • 133 Answers
SOURCE: iphone 3g screen wont come on i can hear the
You may need to try a restore. If you plug in the phone and itunes sees it try to do a restore. If it won't with the phone off hold the power and home button for 6 secs. then let go of the power button but not the home. Hold until itunes sees it and you can restore.
Posted on Aug 20, 2009
SOURCE: iPhone Black Screen, and nothing
Plug the iPhone into your MacBook, make sure the mac is plugged into a power source and open iTunes, if iTunes detects the iPhone, re-sync it from last back-up ... This should make the iPhone crash, reset and be back to normal. If not, hold down the sleep and home button, keep holding it after the apple logo appears, until it shows a USB plug into iTunes sign, the plug the iPhone into the mac and it should happen as before. Good luck cheers
  • 5 Answers
SOURCE: My screen went black but the vibrate still works.
Try to factory reset the iPhone with the latest version 3.0 on iTunes and see if that helps if not then it might be a hardware problem and not the software issue. Can people still call you??? if you know the phone is on that is?
Posted on Aug 01, 2009
  • 4 Answers
SOURCE: I can't listen music through my bluetooth headset with iPhone
My Jabra Halo works to play iPhone's iPod music as well as phone calls. So does Jabra Arrow, I'm told. The bluetooth must have A2DP.
Posted on Jan 10, 2010
SOURCE: iPhone 3G & 3GS Power Button Not Working
To the original poster- where are you buying your iPhone parts? My power button is toast. I'd like to replace the whole button.
Posted on Mar 30, 2010
My iphone 4s went completely blank black screen and it is not dead or powered off. i can hear it if it rings and it vibrates aswell. what can harm this to happen? is it old age?it is 5 years old.
water will have an affect on it if it has not been dried out properly the screen controller chip that is on the logic board will get damaged, =, they are not waterproof, you will need another logic board to repair this fault., can also damage the battery and the screen being in water for any amount of time.
Mar 10, 2015 | Apple iPhone 4S
I was texting on my phone when my phone screen went completely black. i thought i was maybe dead or i powered it off but i didnt.
Have you tried force shutting down your iPhone? To do this, hold down the Power Button and the Home Button at the same time for 5-10 secs, then power on your iPhone again, check if it works. Or try to reset your iPhone using iTunes (Backup your data first). If not, maybe the display of your phone is malfunctioning, send it to the nearest Apple Service Center for repair.
Mar 10, 2015 | Apple iPhone Smartphone
I dropped my iphone 4s-not from a great hight and the screen went black. how can I fix this please?
I would start by attaching it to your computer and seeing if the phone boots up.
If it doesn't there is not much you can do without taking the phone about. A used iPhone 4S can be had for under $100. You could also go with an iPhone 5/5s and get something a little newer without spending a lot either.
Jan 26, 2015 | Apple iPhone 4S
My wifi wont turn on my iphone 4S why
common problem with iphone 4s. Means your wifi chip is disconnected from circuit board or defective. Some small iphone shops fix it by resoldering, but under some conditions it may happen again. High/low temperatures, drops and so on. If phone is still under warranty - apple will replace it free.
Sep 18, 2014 | Apple Iphone 4s latest Model - 16gb -...
My iphone 4 screen went black but it still works
similar problem happened to mine. likely just getting the screen replaced will fix the issue.
Mar 22, 2014 | Apple iPhone4 4G iPhone 4
this is happens whit i4 i4s after you drop the phone . you have to solutions . one if you know a technician hes gonna put back the flex of LCD witch removed after the drop its very easy or gonna change LCD & digitizer .
if your phone is not 4 or 4s you have to change the lcd digityzer for sure .
Mar 02, 2014 | Apple iPhone 5c
Phone display
Did you drop it or get it wet? If the screen just went out then a simple replacement may fix the issue. iPhone 4S repair and replacement parts
Feb 17, 2014 | Apple Iphone 4s I Phone 4 S Factory...
I dropped my Iphone 4s on the floor. The screen went black, and wont turn on. When i connect it to the charger is does not do anything. When i connect it to my Itunes it wont regonize it. what do i do?
I suggest you take your broken Iphone to a cell phone repair shop.
Get a quote for the repair then you can decide whether to go ahead with the repair or get a new Iphone.
Jan 28, 2013 | Apple iPhone 4S
Dropped my iphone 3G, screen went black with some vertical lines. itunes still recognizes the device, i can still play music (using a speaker/charging cradle remote control)I can still hear SMS alert and...
It just happened to my this afternoon. My iphone dropped out of my pants pocket to the ground. The front lcd of the iphone hit the ground and it when blank/black. My iphone happened just like what you've described. I got my fixed. I opened it up and found the connector of the lcd was loose. I securely reconnected it and voila!!!! It works again like a charm! Goodluck to you all who has the same problem.
Dec 17, 2009 | Apple iPhone 3G
Apple iPhone 4S Logo
348 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
