Question about Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television
Can I hook my laptop to my WS-65315 TV
I am trying to connect my laptop computer to my TV
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
I do not see any way unless you can outfit a connection to one of the rear inputs---this set was never designed for this type of use so aspect if connected would likely not be useable.
Posted on Nov 04, 2012
  • 1153 Answers
SOURCE: ws-65315 won't turn on
Need to know more, 1-2 is no error code, you say will not turn on, do it has led light on or do you hear sound in set like high voltage? Any lights blinking? Or just completely dead, like fuse blown?
Posted on Mar 24, 2008
  • 927 Answers
SOURCE: tv mitsubishi ws-65315 doesnt turn on,only green light
Good Day, cutito35; 1. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds. 2. (Power LED may be on after plug in) check for no less than 4.4 volts DC at pin 3 of PC9A21 on the Power PCB, if low or missing replace PC9A21 part # 268P058020. 2.This model is also equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Shutdown at power with self diagnosis error 2-2. Check for open fuses F9A04 and F9A05 part # 283P144080 on the +24 and -24 volt lines. If the fuses are open the convergence output circuit would be suspect. 2. Shutdown at power with self diagnosis error 2-1. At power on check for 12-volts DC at connector KH pin 8, if missing check IC9C51 part # 270P990010 and L9C52 part # 441D009020 on the Signal PCB. Good Luck, big IRISH.
Posted on Sep 01, 2008
techman007
  • 1112 Answers
SOURCE: I would like to know if I can connect a HDMI cable
NO> If your TV supports and have HDMI connections and your HD receiver has an HDMI output then you should have no problem displaying Video. Just make sure you change the input signal of your television to HDMI input. After looking at the spec's of this model these are the following inputs you have. your best picture quaity would be to use componet cables instead, which can show full screen 1080i format, your television does not show at 1080p whis is what HDMI is known for.
Connectors
Rear Input Connectors S-Video x 2 - Component x 3 - Composite x 2 - DVI x 1 - RF x 2 - 1 x RS-232C - Audio (RCA) x 6
Front Input Connectors S-Video x 1 - Composite x 1 - Audio (RCA) x 1
Rear Output Connectors Composite x 1 - Audio (RCA) x 1 - RF x 1
Another good option is use to use a DVI to HMDI connector and hook it up this way. But note: you will have to use audio cables for the DVI input.
Posted on Sep 28, 2009
  • 11800 Answers
SOURCE: I have a tv model # WS-65315. I would like to know
No, your tv is strictly a Standard Definition one. Even it can receive a HD signal, it is downscaled internally to SD so the image would look exactly like from a low quality dvd player (that's because the internal converter is a cheap one) For best image quality use the converter from the BluRay and the Component connectors.
Posted on Nov 29, 2009
SD Tech
  • 14553 Answers
SOURCE: I have a mitsubishi ws-65315.
this model has a self check, when green light comes on and then goes off. Push and hold both the Menu and Input buttons on the front of the set for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Posted on Feb 22, 2011
Mitsubishi tv ws 65315 red screen
if the reds and blues look 3d etc it is a convergence problem. see attached photos of a typical convergence problem.
Apr 28, 2012 | Mitsubishi WS-65315 65" Rear Projection...
User manual for mitsubishi TV model ws65315
here it is :
http://www.mitsubishi-tv.com/pdf/ownersguides/WS-55315.pdf
SD TECH
Oct 31, 2011 | Mitsubishi WS-65315 65" Rear Projection...
I am having a problem trying to hook up a ps3 slim with a hdmi to dvi cable to the mitsubishi ws-65315. no picture
try to go to the ps3 settings then go to video output settings , then go to hdmi and it should go black for a min. i didnt think it was working for mine then i unpluged it and there was a big diffrence but it should work
Apr 20, 2010 | Mitsubishi WS-65315 65" Rear Projection...
I have a Mitsubishi hd 1080 tv and am trying to use it as a monitor for my computer. I have it hooked up but can't get it to show on tv. Any suggestions?
Looking at same problem. No answer yet. Must be device driver (at least for me). I can see the pre-Windows boot up sequence, but frags at Windows. Looking for device driver.
Jan 10, 2010 | Mitsubishi WS-65315 65" Rear Projection...
I have a tv model # WS-65315. I would like to know if I can hook up a Blueray player and still get HDMI quality?
Nov 29, 2009 | Mitsubishi WS-65315 65" Rear Projection...
I would like to know if I can connect a HDMI cable from My tv model WS-65315 to a Direct TV HD receiver?
Connectors
Sep 28, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Tv screen is scratched
I think This Company can help you to get new screen for your Mitsubishi TV.
Sep 30, 2008 | Mitsubishi WS-65315 65" Rear Projection...
Green light doesnot turn off on Mitsubish WS-65315
Just go to menu... then ..setup... then... timer ..and turn it off...... the blinking light goes away
Aug 29, 2008 | Mitsubishi WS-65315 65" Rear Projection...
Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television Logo
149 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
