Question about Dryers
My electric clothes dryer is not heating. Someone said it could be a fuse burned out but I have yet to be able to locate the fuses on the dryer.
  • 56 Answers
Sounds more like the heat element to me. you should have a tec take a look at it it is usualy free to diagnos.
Posted on Jan 05, 2009
Dryer will not heat up to dry clothes
If gas--
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
If electric--
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Sep 03, 2009 | Whirlpool Dryers
Kenmore elite , no heat
2. Heating element
3. Thermal fuse
Jul 27, 2009 | Kenmore Elite HE4 Electric Dryer
Our Kenmore model 96292810 clothes dryer has stopped heating. What is the likely problem?
1. No power to the dryer(If you have power, skip to the next possible issue)
2. Heating element
3. Thermal fuse
Jul 18, 2009 | Dryers
Dryer doesn't heat up
2. Heating element
3. Thermal fuse
Jul 09, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
Whirlpool GEW9868K Electric is not heating up not drying the clothes
2. Heating element
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting....
Jun 24, 2009 | Whirlpool GEW9868K Electric Dryer
Not heating
you have a dead short somewhere or someone monkeyed around the dryer to repair it
Jun 18, 2009 | Amana DLE330RAW Electric Dryer
It wont dry my clothes
Check the following for a gas dryer--
1. Gas valve coils
2. Thermal fuse
3. Igniter
Check the following for a electric dryer--
2. Heating element
3. Thermal fuse
Jun 01, 2009 | Kenmore Dryers
Dryer not heating, help
2. Heating element
3. Thermal fuse
May 30, 2009 | Frigidaire GLEQ2152ES Electric Dryer
No heat
Check the following---
2. Heating element
3. Thermal fuse
May 29, 2009 | Whirlpool Dryers
Kenmore cloths dryer will not heat up
3. Igniter
Oct 18, 2008 | Kenmore 659 Electric Dryer
Dryers Logo
Top Dryers Experts
