Question about Mitsubishi WS-55511 55" Rear Projection Television
Mitsubishi WS-55511 55 in. Rear Projection Television No red colo
Everything on the set works fine excpt the red color went away. Is this a bad projector or something else/
  • gwfrank2000 Jan 04, 2009
    if any red exists it is very minimal
I am having the same issue with the RED, appearing more Like brown. I just replaced the convergence unit and a couple of transistors. The picture is sharp, blues blue, yellows yellow....but red is brown. Also after visual inspection of lenses, all guns APPEAR to be functioning properly, but I'm not so sure the red is working as strongly a a it may suppose to be? Any suggestions to fixing this would be appreciated.
Posted on Aug 07, 2012
  • 233 Answers
Do you see any red at all when you co to the convergence screen? if not, then the red CRT has died and needs to be replaced.
Posted on Jan 04, 2009
My Mitsubishi ws-55809 works fine although the screen turn pink but the picture is still visible. After a while it goes back to perfect color. Then it repeats this back and forth. Sometimes it will fl
Problem is likely on the small circuit board that plugs onto the bottom of the red picture tube---be careful as dangerous voltages in and around that board---each of the three picture tubes has a small board that plugs on the end of the tube.
Oct 21, 2012 | Mitsubishi WS-55809 55" Rear Projection...
My mitsubishi ws-55809 works fine but the screen turns pink and after a while it goes back to perfect color. Does this back and forth
Someone with moderate experience would have to examine the red crt printed circuit board--I have seen some of these that develop a cracked ground path on that board but usually it is pink except on the sides depending which ground path is bad.
The red crt tube on your tv is going, or you need more optical fluid for the lens. Crt tubes typically run for $150-$300, and a fluid refill should be less than $100. If the tv isn't very clear or bright, even when working right, then consider just getting a new tv. These are costly to repair and will eventually begin to have more problems.
Contact me for more info.
Thanks for asking!
Feb 26, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-65907 65 in. Rear Projection Television; No Sound from internal speakers. I don't believe external speaker will work either but I have no way to test. TV was move from one home to another....
first you need the original remote to do this, with the set on use the remote to enter the following (menu) 8,2,7,0 this will bring up the options menu the first thing in this list is "Inital" and should already be highlighted then simply press enter on the remote, this should reset the tv
Dec 22, 2009 | Mitsubishi WS-65907 65" Rear Projection...
Check your color wheel sounds like that is going bad. 90% of the time the color wheel is the culprit in this cause. You will need to remove the back panel to get the to color wheel. You will see 7 different plastic adjustments. You can also order this part online at mitsubishis website
Apr 10, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Blue and red overlap shadowing
convergence ic's are your culprit. they are responsible for aligning the 3 colors your tv projects onto your screen..
Mar 15, 2009 | Mitsubishi WS-65807 65" Rear Projection...
You can try to enter the menu and go to advanced setting and adjust the convergence. Push audio to go to advanced convergence and do the multipoint convergence to re-align the colors. If this doesn't solve, you may need to do a hardware repair.. all projections of this type will need a convergence IC repair sometime during their lifetime.
Dec 07, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511
Good Day;
Sounds like you have bad Convergence Output IC > 267P155010 > STK393-110, replace and it will correct the problem TV uses only ONE, make sure all resistors look good in the circuit around IC.
Good Luck, big IRISH.
Sep 19, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55809 Color
Does the neck of the tube glow? If not you may have a bad solder connection on the Red CRT PC board or a bad transistor on the red PC board
May 20, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Screen turning pink
If the pink overlay goes away gradually, you could have weak picture tubes (CRT's) If the color jumps in after warming up, it could be a bad solder connection. If you haven't had a good picture to watch for a long time, I would be tempted to put the money towards a new HDTV set as those older Mitsubishi Rear Projection TV's had a Lot of bad solder connections in the past, and by fixing one problem another could crop up in the near future.
Apr 12, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
109 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
