Question about Electrical Supplies
I have a Badger 5, model 5-81 and it has started leaking from inside the unit. The water is coming out around the reset button.
It got stuck a few weeks ago and I used an alan wrench to unstick it according to the instructions. Seemed to work great for a few weeks, now it started leaking.
  • Roger Lay Nov 06, 2012
    Thanks for the responses. I have decided to replace the disposer. Going with the Waste King L-2600 after reading Consumer Reports. Thanks!
  • Gene Haynes Nov 06, 2012
    Waste King appears to have customer-support on their website, so 5 year warranty is probably negotiated with their warranty carrier thru waste king customer support.http://www.waste-king.com/. Save receipt. Unknown if warranty is pro-rated. Only 1 fixya response was live. Other responses were 'recommended' solutions from past dates. Troubleshoot link in first answer shows disposal installation tips.
  • 5,245 Answers
Where is it leaking?
If bearing rusts out, the unit can start sticking, and water begins dripping down into the motor cavity.
Replace disposal.
Copy following link for troubleshoot walk thru with illustrations:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Nov 04, 2012
    New Friend:
I had same problems before. So I bought Ins?nkerator evolut?on excel and now I don't have any problem. The Insinkerator Evolution Excel is simply the best!!!! This year for Thanksgiving, a guest was helping in the kitchen and put a large amount of potato peels down the disposer. I was concerned because not only was the disposer jammed full of potato peels, but there were a bunch of peels in the sink waiting to be stuffed into the disposer. (This has happened with our old disposer and I got the privilege of trying to unclog a clogged sink - not a fun thing to do with a house full of company). I watched her turn on the disposer and to my amazement they were all disposed of without a jam. At this point the Evolution Excel was worth every penny I paid for it. My only complaint about this disposer is that is almost too quiet. When you turn it on, you can barely hear it run. I have to remind myself to insure it has been turned off because you get a quiet hum when it is running, not like the old disposer that was LOUD. This is great if you have a sleeping baby, etc where you don't want to wake up the neighbors when you run the disposer. Best Garbage Disposal Reviews 2016 Ultimate Guide
Posted on Jul 21, 2016
4 Suggested Answers
  • 250 Answers
SOURCE: where to get instructions to take insinkerator apart to clean ou
There is a problem with the motor starter. Electric motors that large have three sets of coils: the stator, rotor, and starter coil. The stator coil doesn't move but it induces a magnetic field around the rotor coil. The rotor coil is wound around the shaft that turns the grinding wheel and induces a magnetic field that interacts with the stator's field and causes rotation. The problem is, it takes a lot of energy to start a motor that big turning and it needs a little extra oomph. The starer coil can't simply run all the time. I'm not sure why but my guess is heat and overload issues. Anyway, there's a switch mounted on the motor's shaft that reacts with centrifugal motion. When you turn the disposer, the shaft is not moving and the switch is ON. That switch, when turned on, powers the starter coil that helps the motor get started moving. When the shaft gets up to speed, the centrifugal force throws that switch outwards, which turns off the power to the starter coil. The humming when you turn on the disposer tells us that at least one of the coils is running just fine. There's a chance that one of the coils is burned open or something, but moving parts fail first, so I would say take a look at that switch. It probably just has some gunk stuck on it, in which case check for signs of leakage, and just buy a new disposer if it has leaked. Otherwise that switch is probably the problem.
There's a chance you can do this without removing it from the sink, but probably not. Open the wiring door on the bottom and unhook the three wires. Open the strain releif and pull the cable out. Look to see if there's any way you remove the bottom of the disposer, but I doubt it. Look inside the wiring hole and pull out the cardboard inside. There you can see part of the motor. There's a chance you can see the problem from there and possibly that starter switch. You'll probabl have to get at it from the top though.
To take it apart, turn off the breaker and wall switch. Unscrew the nut or plate from the drain line and remove the drain line. now look up around the sink opening and look for a ring with three protrusions that are curled in little sideways tubes. Put your dejamming wrench in the hole or tap with a hammer to the left to disengage the disposer from the sink. By ready for it to fall, it's heavy. Now loosen the screws around the top of the disposer right above where the name label is. If there is a plastic vanity around your disposer, which there is not for this one, pop it open with the tabs on the side and take it off. This thing is hard to get back on right though. Lift off the top of the disposer and you should be looking at the gridning wheel. Now loosen the bolt that holds the griding wheel to the motor. You'll probably have to insert that wrench into dejamming hole so the whole shaft doesn't turn. I'm not sure what'll be below that griding wheel but you'll probably find a way to open up the bottom and slide out the whole motor. Be careful you don't damage any seals, you're dealing with water and electricity here. After you fix the problem just do the reverse to put it back together. Knowing me I would test it to see if it ran after I thought I fixed the problem but before I put it all the way together, but only after checking to make sure nothing would shock me, come loose from a part of the machine if it did come on, and I would make sure it was secured and away from me when I applied power because this is a big motor and it's gonna **** hard when it starts. Now would also be a good time to take apart the assembly that holds the disposer to the sink and replace the dried cracked plumber's putty with fresh putty, or, better yet, silicone adhesive that lasts forever. You can also spiff up your disposer by replacing the rubber splash gasket that you can get at a hardware store for a few dollars.
Posted on Sep 17, 2009
  • 3 Answers
SOURCE: I have a badger 5, model 5-81 and it does not
be sure you have 110v if its a 110volt unit sometimes when dropped they tend to lock up run some water and see what happens no results return product
Posted on Apr 12, 2010
heatman101
  • 43501 Answers
SOURCE: I just noticed that my insinkerator Badger 5-75
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
Posted on Sep 29, 2010
Is there a way to unstick the piston?
Use cutting oil (ATF Fluid works well) and let it soak overnight, if that doesn't free it you need to remove and rebuild the engine. You can (after waiting for the oil to work) try a wooden dowel that will fit in the spark plug hole and then hit the dowel to try and free the sticking piston, use finis, tap with only moderate force repeated times.
Dec 08, 2016 | Garden
Light with wrench appeared about a week ago added oil seemed to go away. now I have a yellow oily feeling fluid leakin from the car
The wrench light Has NOTHING to do with oil level.
Get this checked out as soon as possible.
Jul 03, 2015 | 2005 Saturn VUE
Leaking something awful; plastic base appears to be cracked. I just bought two weeks at at Home Depot. Can I return. (Can't find my receipt.)
Usually they will accept it without a receipt. No cash back though. Store credit or go get another one.
May 08, 2015 | Cars & Trucks
Sunroof stuck and cannot manually turn with allan wrench
it is jammed up and will need to be taken apart to fix it.
Sep 23, 2012 | 2003 Mini Cooper
Hoover HD73M dishwasher keeps tripping the circuit breaker
Have condensation in the electrical connector .It is grounding .Call an electrician to repair ground and short circuit.
May 10, 2012 | Hoover 24 in. HD73M Free-standing...
My acer laptop is about 6 months old and was working great till few weeks ago , i had to format few days ago because it was lagging overheating missing files discont me on line every 2 mintues , wouldnt...
If your internet is not working properly then reset your router and configure again.
Scan your computer with updated antivirus.
Also check RAM memory is works fine.
If it over heat then put extran fan so it control heat.
let me know if you need further assistance.
Thanks.
Oct 30, 2009 | Toshiba Portege 7100 Notebook
Vechile is overheating I believe the thermostat is stuck close
Hi, there isnt really a way to unstick it. The thermostat has a wax pellet that expands when it is operating causing the spring inside to open the thermostat letting the coolant flow properly. All you can really do just replace the thermostat, its a simple job as well
May 16, 2009 | 2005 Dodge Durango
91 Accord stalls at idle and or won't start
Did you open the relay assy? If not, resolder the relays. Very common problem.
Apr 30, 2009 | 1991 Honda Accord
Electrical Supplies Logo
972 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
