Where is the igniter on a 441 monitor heater
It will not ignite . Took it apart , cleaned it , checked fuel pump and carborator. All seems ok . The heater (round thing on bottom of pot Gets very hot ( I think to pre heat or vaporize fuel ) that is working . The thing on the side of the pot ( that looks like a grill igniter), does not spark. Is that the problem or is that thing maybe not an igniter ?
3 Suggested Answers
  • 126 Answers
SOURCE: My Monitor 441 will not ignite?
Lane,
When you try to light the heater do you ever hear a thumping noise? If so, you have a fuel delivery problem. If you never heat the thumping noise you have a fuel pump or air safety switch problem. If it's been snowy you could have a covered flue pipe. This will cause the fuel pump not to come on. If your Monitor is your only source of heat I would be looking for a local repair guy that knows the Monitor heater.
Tom Hawkins
hawkins111@gci.net
Posted on Mar 03, 2009
hardrocko
  • 1476 Answers
SOURCE: Heater was fine one min then no fuel the next!
This heater is made by Reddy Heater. There are certain problems they develope after running for some time and are very critical of the pump pressure. If it is wrong the unit will light sometimes and not others. I have a tip at this address http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains in detail how to repair your unit and where to get the parts. Let me know if you need anymore help.
hardrocko
Thanks for using FixYa
Posted on Feb 24, 2010
My 441 monitor heater will ignite and then it burns for a little while then goes out and starts flashing.
sounds like your heater may be starving for fuel. check all your rubber hoses for cracks first and then continue troubleshooting from there.
Nov 27, 2010 | Reddy Kerosene Heater with Thermostat:...
Toyo lazer 55 wont ignit took apart cleaned every thing and replaced all gaskets and unit wont start
Check the igniter and make sure it is good. You can check the igniter with an ohmmeter and check the circuit board where the igniter connects for voltage with a voltmeter. A Laser 55 is an old unit and parts are hard to find. Also check the flame rod and make sure the fuel pump kicks on after the preheat time. When you turn it on the blower should start and the igniter should start to preheat the burner. After 3 minutes the fuel pump should kick on. If it is making a loud ticking or thumping sound it isn't getting fuel to the pump. If you do need parts I have an old Laser 55 with some good parts. You can contact me at nitensheaterservice@earthlink.net. Use caution when making checks on the circuit board. If you ground something it is likely to ruin your circuit board and those are not longer available. Turn the power off before removing the flame rod. They have power on them and also can ruin the circuit board if you let them touch anything metal on the heater. Let me know what you find.
Oct 24, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
My Monitor 441 won't ignite. I hear ticking (pump running) and verified that the keorsene is going through the solenoid. There is no ignition and then it times out. Can you help?
When you say fuel is going through the solenoid, do you mean you removed the fuel line from the burner and fuel comes out the line when you try to start? If so, you have proved the fuel system from the tank, fuel sump and fuel pump is good. Now, does the igniter get hot? Feel around the lower area where two white wires go into the burner, it should get warm. Remove the window and clean it. You will have to replace the gaskets, as they may break. Stick a paper clip down the fuel nozzle about 3 inches to clear any carbon. Remove the flame sensor and clean it. Same thing with the gasket. Put all back together and try it again. If you see flame and the stove quits you have a problem with the burner.
If there is no flame, you have an iginter problem. This will be very clear when you remove the igniter.
When was the last time the stove was serviced? If it was more than two years ago you need a service.
Good luck,
Tom
Oct 09, 2010 | Heating & Cooling
E 13 message on my monitor 2400. What do I do?
E13 means the heater failed to ignite. This could be because of the igniter, the circuit board, a fuel or fuel pump problem, the flame rod being dirty or grounded, The air pressure switch or an overheat occurred. First check the igniter. You can measure the resistance of the igniter with an ohmmeter, it should be somewhere around 16.8 ohms. If you hear a loud ticking or thumping sound before you get the code then you have a fuel flow problem. This can be because of the filter at your barrel or the strainer in the fuel sump or an air bubble in the fuel line. A dirty flame rod can be cleaned with some steelwool or fine grit sandpaper. Unplug the heater before cleaning the flame rod. If the fuel pump ran before you got the error code then the air pressure switch is ok because the fuel pump will not run if the airpressure switch contacts are not closed.
Oct 09, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
My monitor heater 441 comes on but after 3 mins.or so the burner lights come on full then starts blinking still no flames no heat.
Not a lot of details to go on. Does the pump make a loud ticking sound? That would mean it isn't getting any fuel to it and you would need to check your filter and the strainer in the fuel sump. You may need to check your igniter also. If it isn't working the heater will not light and kerosene will be building up in the burner everytime you try to light it. If you have a clamp on ammeter you can clamp around 1 of the igniter wires and should get 2 - 4 amps when you turn the heater on. If this doesn't help you can email me a nitensheaterservice@earthlink.net.
Mar 31, 2010 | Heating & Cooling
Lane,
Tom Hawkins
hawkins111@gci.net
Mar 03, 2009 | Heating & Cooling
I have a monitor 441 and it will not ignite! I cleaned the strainer, and the igniter is getting warm. But, no flame? help anyone??
Lane,
Do you hear a thumping noise on the lower right side of the unit just before it starts flashing the light bars? If so you have a fuel supply problem. If there is no thumping noise I would check the flue pipe on the outside to be sure it is clear. Lastly I would remove the copper fuel pipe from the burner and try to start the stove. If fuel comes out the pipe the pump is good. If fuel comes out I would stick a paper clip down the fuel nozzle about 3 inches, it could be blocked with carbon. If no fuel comes out the pipe, you will need to get a manual or a tech to help you out. The choices would now be fuel pump or main board, both of which are pricey so you don't want to make a mistake.
That being said, when was the last time you had the burner serviced? Mat, ring and all the gaskets involved? A Monitor 441 needs to be looked at about every 3 years to be sure you get through the heating season.
Good luck,
Tom Hawkins
hawkins111@gci.net
Operating manual for MPI monitor heater
You can obtain an electronic copy of the 441 owner's manual from http://www.monitorproducts.com/customer-support/manuals
Scroll towards the bottom of the page to find the 441 or 442 manuals.
Jan 09, 2008 | Heating & Cooling
Heating & Cooling Logo
187 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
