Question about Solis Palazzo Espresso Machine
Solis palazzo when turned on all the lights are on or flashing and will not make coffee
All the lights are on when first turned on, flashes, and will not go throught the begining clean cycle.
LLoydstarr
SOURCE: Solis Palazzo Espresso Machine
The machine is still stuck in the descaling cycle. You must open the steam valve and let all the liquid drain from the tank. This takes approx. 45 min. because it comes out intermittenly. After this is complete all the front buttons will flash. Close the steam valve, rinse the tank, then fill it with fresh water. Open the valve again and let all the water drain from the tank again. This time it will only take a couple of minutes. After it has completed close the valve and the machine will return to normal operation.
Posted on Jul 05, 2007
Richie_asg1
  • 1036 Answers
SOURCE: Solis Palazzo - Coffee grinder seems blocked
Hi there!
This is most likely due to a build up of ground coffee at the edges, and the whole lot has become a solid lump.
Disconnect the machine and clean with a small stiff paintbrush.
This is caused by damp beans, or using dark roast beans, or keeping beans refrigerated. Often it is the coffee oil that causes it.
If there are beans in there and the unit is not rotating, please contact here again.
Thanks......Oh, and rate as Fixya! if it helps you.
Posted on Jun 19, 2008
  • 1089 Answers
SOURCE: Solis Palazzo Descaling (?) Problem? Please Help!
Hi
He has the first part correct, but when you rinse the machine with fresh water the machine needs to quit on its own and you will know this when the descale light is off, but you will have a flashing green light and a steady red light over the water drop. Refill the water tank, the close the steam knob and then open it again. This will clear the red light and then the machine will start heating. IMPORTANT on any automatic machine is when the water tank is off the machine don't do anything with the beans. A chip of bean in the water receptacle can be a big problem for the machine.
Posted on May 24, 2009
EsWorld
  • 1618 Answers
SOURCE: need to buy water tank of solis pallazzo coffee maker
The only importer of solis I know of is Barratza.com, they will have the parts needed.
Posted on May 30, 2009
  • 1089 Answers
SOURCE: does not warm up
HI
If you don't have any other lights on, it could be 1 of 2 things. Your boiler is bad or your power board is bad. Can you get steam or hot water?
Posted on Nov 22, 2009
Water temp and descaling lights flashing
you need to descale the machine as per instruction
Oct 15, 2012 | Solis Palazzo Espresso Machine
Solis Palazzo : turn on machine the brew group does not position it self to prepare coffee.powder coffee, coffee, and espresso lights blink. Brew group is not removable from machine. machine has had light...
Hi
This is for a Vienna but it should work for you Palazzo. It will help you get the brew group out and reset so you can reinsert it.
http://www.fixya.com/support/r2296970-brew_group_stuck_t_get_out
Aug 04, 2011 | Solis Palazzo Espresso Machine
I have a Solis Palazzo machine. My question is:
HI When was the last time you descaled? This can have a temp lowering effect if you don't descale on a regular basis. Program you water hardness so its set on 4. This will tell you when you have to descale. Descals is not the same as cleaning. Its a special acid that disolves the deposits inside the boiler.
Jul 24, 2010 | Solis Palazzo Espresso Machine
Brewer part for solis palazzo
Hi
What part do you need? I have some.
Jul 05, 2010 | Solis Palazzo Espresso Machine
Does not warm up
HI
Oct 25, 2009 | Solis Palazzo Espresso Machine
Water LED flash
Hi
Try pushing the water button on the right ( it should light though dim ) and then open the steam knob.
Apr 01, 2009 | Solis Palazzo Espresso Machine
Solis pallazzo rapid steam
Hi Alex,
Try to prime the machine.
May 20, 2008 | Solis Palazzo Espresso Machine
Standby
I turn mine on in the morning and off at nite.
Oct 20, 2007 | Solis Palazzo Espresso Machine
Solis Palazzo Espresso Machine Logo
42 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
Colin Stickland
Colin Stickland
AZBen
AZBen
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
