Question about FoodSaver V3840 Vertical SS from Tilia
FoodSaver V3840 tray full won't go off
Tray full light stays on
3 Suggested Answers
  • 9783 Answers
SOURCE: foodsaver vacuum sealer tray full light
Clean the two little contacts on the tray. Make absolutely sure there isn't anything across the two wires that run the length of the tray. It doesn't take much to trigger the light.
Posted on Jun 07, 2014
Tried the recommendation above, even have let it air dry for more than an hour, there is nothing moist around the three contacts. I, of course am in the middle of a huge project!
Posted on May 28, 2016
Trying to vacuum and seal the broccoli after blanching, cooling and letting it drain. It won't seal the bags. It vacuums the liquid til the tray fills, then shuts off. I start over. How to fix this?
I usually freeze the bag before sealing that way the food is not dry when wanting to use it. pour as much water off as you can tho hope it works for U also I freeze many pounds of fresh fish that way also
Jul 27, 2015 | FoodSaver V3230
MY FOOD SAVER HAS BEGUN NOT VACUUMING. IT SEALS BUT DOES NOT GET THE AIR OUT LIKE IT USE TO
Does it hum as though it's vacuuming? If not, it's probably broken - the vacuum pump is out. It's cheaper to get a new one than attempt to get the old one fixed. If it hums, then replace any hoses you find or the foam around the drip tray.
Dec 06, 2014 | FoodSaver V3230
Foodsaver V3840 Won't vacuum air out and wont go to seal. A label states the seals are not removable. Do you know how to fix?
you are not using a "good" bag. Make sure there are no holes and that the bottom and sides of the bag are properly sealed. It will run all day and not pull the air out if the seal is broken anywhere.
Sep 11, 2014 | FoodSaver V3840 Vacuum Packaging System
FoodSaver V3240: Lights flash,,,won't operate...what's wrong?
Pull out the long rubber piece on the top, clean any debris, replace firmly.
Aug 10, 2014 | FoodSaver V3240 Vertical Vacuum Sealer
Foodsaver vacuum sealer tray full light
Jun 03, 2014 | FoodSaver V3880 Vacuum Sealer - The Master...
V3835 tray full light won't go out after both trays have been emptied and cleaned.
Hair dryer. Remove both tray inserts and dry thoroughly, paying special attention to the sensor area in the center of the upper tray.
Sep 26, 2013 | FoodSaver V3835 Vacuum Food Sealer with...
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
The tray full light stays on even though the tray is empty.this prevent the foodsaver from operating.I have tried unplugging,recleaning the tray but nothing works
I had the save problem with my 3400 series.
The first time i was able to let it dry and it worked alright (48 hours).
The second time even this did not work.
If you remove the screws on the bottom of the unit. There are about 10 and pull it down, you will see the sealer assembly and a small circuit board in the middle.
Trace the wires from the drip tray, there are three of them, red white and brown, to the small white plastic JST connector on the small circuit board. Pull said connector gently to disconnect it.
The unit will function perfectly now, although it will no longer have a drip tray sensor of any sort it will function every time all the time.
All in all this took me about 10 minutes.
Thanks!
Sep 09, 2010 | Vacuums
Roomba does not fill upper tray.
brushes are not turning, you can see this if you remove dust bin and start the roomba, remove brushes clean thoroughly removing yellow end pieces as well to remove trapped hair, re inbstall brushes and turn manually about 20 turns and re try cleaning, try this a couple of times
Jul 06, 2010 | iRobot Roomba 530 Robotic Vacuum
Foodsaver
Here is the link to your foodsaver manual.
http://www.foodsaver.com/Support.aspx?id=spma&mgid=1
Sep 09, 2009 | Vacuums
FoodSaver V3840 Vertical SS from Tilia Logo
246 people viewed this question
Top FoodSaver Vacuums Experts
Lawrence Oravetz
J.D. Browning
J.D. Browning
ray gallant
Are you a FoodSaver Vacuum Expert? Answer questions, earn points and help others
