Question about Kenmore 23822 Top Load Washer
Squeaking noise Kenmore portable clothes washer
Squeaking noise while washing is going on. No noise at any other time. Repair man checked brake and said it was good. Any help would be wonderful as the noise is driving me crazy. Kenmore model number 1102970090,type 113-01, kenmore E12477. This is all the information that is on the lid.
  • dlui May 19, 2009
    I have the same washer (Kenmore E12477) and it makes a loud screaming noise during the
    spin cycle only. I checked the brake system and it is fine. The noise
    is from the clutch system and I'm trying to order some parts for it,
    but need to get hold of a manual/parts list first. Will let you know if
    this is the proper fix.
  • 20 Answers
He checked the brake? i wonder why.... sounds like u need some grease on the agitator shaft or possibly something else.
Posted on Feb 13, 2009
Hoover 2300L 6.okg boss. Squeaking when agitating back& forth, not when spinning. Is this a bearing problem? & is it replacable. If so, from where in south australia? Or wherever.?
Washing machines don't usually run silently, but in most cases, a squeaking noise that occurs while the washer is agitating the clothing is not normal and signifies a problem. If the noise only happens when the washing is agitating, the problem is likely connected to the motor or your water pressure. Depending on the specific cause, you may feel comfortable fixing it yourself. Otherwise, call a professional.
Other People Are Reading
The Agitator
  • Agitators are located in the center of the drum, or basket, of top-load washing machines. Front loading washing machines do not use agitators -- instead, gravity moves the clothes from the top of the drum to the bottom. Agitators usually consist of a tall cone fitted with arms at the base. The purpose of the agitator is to rotate the clothes and soapy water around the tub to clean the clothes. The agitator itself is not usually the cause of the squeaking noise. It is powered by the drive mechanism, which consists of a motor, clutch and gears.
Motor Problems
  • A repetitive squeaking noise during the agitation cycle may signify a problem with the motor. Specifically, the belt on the motor may be wearing out. Some motors use rubber couplers, which also wear out easily. The belt is necessary for the agitator to turn, but over time, it wears thin, just like the belts in your car's motor. An easy way to test for this problem -- if you're handy -- is to take the belt off the motor and then run it. If the squeaking noise stops, the problem is indeed your belt. Of course, this means your agitator won't move. Replacing the belt should fix the problem.
Water Pressure Issues
  • The tub, or drum, fills with water right before the agitator turns on, and water continues to circulate throughout the washing process. As the tub fills and water circulates, you may hear a squeaking or squealing noise if you have high water pressure. This sound is caused by the force of the water moving through the pipes. To adjust this, turn the knobs on the hot and cold valves on the pipes that go into your washing machine.
  • New washing machines may squeak at first as the parts "warm up," according to the GE Appliances website. The noise should disappear after five complete washing cycles have run on the machine. Unbalanced loads, overly heavy loads and loose items in the drum may also cause noise when the agitator comes on, but these things usually do not produce a squeaking sound.
Read more : My Washer Squeaks When Agitating eHow
Jun 14, 2015 | Hoover Washing Machines
Our Kenmore Elite 45992 is making a loud squeaking sound when it spins clothes. We've checked the belt and shocks and they are okay. Any ideas?
Had same problem mine was the yoke thatheld inner drum tobearing was broken. Lucky it was covered by Sears warrenty. Over $1,000 to repair without warrenty..
Sep 30, 2012 | Kenmore Elite Washing Machines
Squeaking when dryer is running
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
Dec 27, 2010 | Kenmore 98702 Stacked Washer/Dryer
Kenmore top-loading washing machine squeaks
Thanks for using FixYa. Please check if there are any sucked small clothes, safety pin, lint or debris in the water pump. If the pump is fine then the squeaking sound may be due to gear dogs in the agitator or bad gear case. The washer will spin and agitate at the same time. If the washer is still under warranty then do not try to open, repair or replace any part to void the warranty.
Please do rate the solution and revert for further assistance.
Sep 13, 2009 | Kenmore 22422 Top Load Washer
GE Washer Model WJRR4170E4WW squeaks while agitating
There are four suspension rods that the tub hangs on. When the washer is agitating the tub will rock back and forth and the rods will move back and froth as well. To fix this noise, lift up in each rod and put some lubricant in the cup that the rods fit into at the top of the washer.
Note that it is best if you use a lithium-based lubricant rather than silicone based lubricant.
For more on do-it-yourself appliance repair help visit
Sep 11, 2009 | GE WBSR3140DW Top Load Washer
GE Profile Harmony Washer has loud squeak when filling
Based on your description, it sounds like the water inlet valve is making noise, since you hear a squeaking noise during the filling of the washer. If it sounds like a constant squeak or squealing noise, i'd say it's caused by either the water inlet valve not being pulled all the way open, or because the water supply shut off valve at the house end isn't open all the way. Try opening the water supply shut off valves all the way open, (check to see that they are).
What is interesting is that the squeaking comes back during the draining of the water. Is this while the tub is spinning or only at the very end of the cycle? Again, it could be the water inlet valve, since the washer will "spray" some fresh water into the washer during the final spin cycle to help remove any soap residue, etc.
The part ins't cheap at around $123.00 for this valve, so unless it's really annoying you to no end, I'd wait for the valve to stop working before getting the repair done, unless you want to do the repair yourself, which isn't difficult, with some basic tools and time.
If you wait and let this go until it fails, you'll notice the water in the tub might not fill all the way for the level set, or the valve will start getting even more as it gets worse.
Here's a drawing that shows your washer and the part I'm talking about.
pd_0026_363_wh13x10017?$pddetailsth$ Part #WH13X10017 $123.49 @,%20BACKSPLASH%20&%20TOP%20PANEL&documentId=G0901083&backToLink=Return%20to%20Sub%20Components%20list
Hope you find this Very Helpful and best regards!
Aug 22, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Squeaking noise while washing is going on. No noise at any other time. Repair man checked brake and said it was good. Any help would be wonderful as the noise is driving me crazy. Kenmore model...
Have you or did the repair man check the belt to make sure it was still good and nothing was stretched? Also the motor to make sure that it was not causing this problem? And everything is oiled properly?
Feb 09, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
Admiral Washing Machine Makes Squeaking Noise
Nov 22, 2008 | Washing Machines
NAV6800AWW - noisy
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 04, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Agitator very noisy while washing
There is a small roller that tightens the drive belt for the drum inside this unit. If it is loose it makes a squeaking noise. Tightening this may solve your problem. You will have to take off the back panel to do this repair
Jan 28, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 23822 Top Load Washer Logo
597 people viewed this question
Sal De
 Brian Main
Brian Main
