Question about Motorsports
The torque specifications for a 2003 chevy malibu 3100 head bolts
SOURCE: Engine Bolt Torques- 2005 Chevy Impala/3400 Engine
Head Bolts
Step one 37 ft lbs then tignten 120 degrees more
Rocker arms
Step one 11 ft lbs then tighten 90 degresss more
Upper intake
89 inch lbs
Lower intake
132 inch lbs
Posted on Dec 02, 2008
  • 98 Answers
SOURCE: cylinder head bolts specification
here
Posted on Dec 28, 2008
SOURCE: torque specks
hi 1999 chevy malibu head bolts 1-8 40 ft lbs bolts9-10 30 ft lbs tighten all bolts an additional 90 degrees
rod bearings 18 ft lbs plus additional 80 degrees
head
top row of bolts 9 3 1 5 7 bottom row 10 6 2 4 8 from left to right
Posted on Feb 12, 2009
  • 217 Answers
SOURCE: Need 2003 Chevy Malibu, 3.1 ltr v-6 head bolt torque specs
torque all at 44 ft. lbs. the first time then an additional 95 degrees on all the second time and thats it. you will need a degree wheel to do the torque the second time, thank you and let me know if i can help anymore help
Posted on Mar 25, 2010
Testimonial: "Thanks alot! Had already called our local parts house for the info."
  • 3640 Answers
SOURCE: i need the engine torque specs for 99 chevy malibu
99 chevy malibu v6 3.1 engine, head bolt torque is-- 98 through 2001 is step1- 37 foot lbs, step 2- rotate an additional 90 degrees (1/4 turn). the rocker arm bolts are 168-in. lbs.
Posted on Sep 07, 2010
Redoing head gaskets on 2003 Chevy Malibu. Can't
you can call Auto Zone or go to their web site and get the right specs,I've always use their web site www.Autozone.com.
Oct 31, 2012 | Cars & Trucks
Head bolt sequence and torque values on a 1999 Chevy 3.1L engine
if the 8th number om your VIN is a "J" then this is the correct prossess 3.1LTorque sequence --------- ' 6 2 3 7 ' ' 5 1 4 8 ' --------- Step 1: torque in sequence to 37 Ft/Lbs Step 2: turn an additional 90 degrees recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque.Always coat bolt threads with the proper sealant.
if the 8th number on your VIN is a "M" then this is the correct prossess 3.8LTorque sequence --------- ' 6 2 3 7 ' ' 5 1 4 8 ' --------- Step 1: torque in sequence to 37 Ft/Lbs Step 2: turn an additional 90 degrees recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque.Always coat bolt threads with the proper sealant.
Oct 12, 2011 | 1999 Chevrolet Malibu
Need torque specs for 2000 chevy malibu 3.1 cyl heads & intake
(step 1 ) the torque specs for the heads are---1998 through 2001 are 37 foot lbs. ( step 2) rotate an additional 90-degrees (1/4 turn). intake manifold bolts ( lower ) step 1-- 62 in-lbs, step 2--115 in-lbs. intake manifold bolts/studs ( upper ) 18 ft-lbs. this is for the 3.1 v-6, have a good day!
Aug 14, 2010 | 2000 Chevrolet Malibu
Mar 24, 2010 | 2003 Chevrolet Impala
I need the engine torque specs for 99 chevy malibu. like the head bolt torque sequence and rocker bolt torque sequence
Mar 12, 2010 | 1999 Chevrolet Malibu
I am looking for the cylinder head torque specification for the 3.3litre chrysler town and country 2003
Tighten the cylinder head bolts 1 - 8 in the sequence shown in Cylinder Head Bolts Location and Tightening Sequence Using the 4 step torque turn method, tighten according to the following values:
Step 1: Bolts 1 - 8 to 61 N·m (45 ft. lbs.)
Step 2: Bolts 1 - 8 to 88 N·m (65 ft. lbs.)
Step 3: Bolts 1 - 8 (again) to 88 N·m (65 ft. lbs.)
Step 4: Bolts 1 - 8 turn an additional 1/4 Turn. (Do not use a torque wrench for this step.)
NOTE: Bolt torque after 1/4 turn should be over 122 N·m (90 ft. lbs.) If not, replace the bolt.
Tighten head bolt number 9 Cylinder Head Bolts Location and Tightening Sequence to 33 N·m (25 ft. lbs.) after head bolts 1 - 8 have been tighten to specifications.
Jan 24, 2010 | 2003 Chrysler Town & Country
Hermonic balancer
As tight as you can get it without turning the engine. No loctite
Apr 25, 2009 | 2003 Chevrolet Malibu
Torque specks
head
Feb 12, 2009 | 1999 Chevrolet Malibu
Harmonic balancer
check the pulley if it wobbles alot replac it. or,
bolt may be comeing loose
put red locktight on the bolt adn torque it to 76 foot pounds
rank my solution &vote
Dec 13, 2008 | 1998 Chevrolet Malibu
1997 Malibu torque Specifications
exhaust to cylinder head nuts 11 ft lbs
exhaust to cylinder head studs 97 in lbs
flywheel 22 ft lbs
Please rate this a fixya if this answers your question. Thanks!!
Mike
Sep 12, 2008 | 1997 Chevrolet Malibu
Motorsports Logo
43 people viewed this question
Top Motorsports Experts
chuck ringwood
chuck ringwood
Jim Rus
Jim Rus
Steve P
Steve P
Are you a Motorsport Expert? Answer questions, earn points and help others
