Question about Toshiba DVR620 DVD Recorder/VCR
Want to record a dvd dual layer on my Toshiba dvr620ku
  • Wesley Tom Nov 06, 2012
    To clarify, can the Toshiba dvr620KU record on dual layer dvd discs?
2 Suggested Answers
SOURCE: Toshiba DVR620KU error E 25 cannot put VHS onto DVDs
Probably copy protection.
You can remove it with a Grex or similar
device.
Posted on Jan 22, 2010
Recorded dvd from my toshiba dvr620ku won't play on other dvd players
it could be the video format from the recorded dvd's not compatible in the dvd player that you have been used.
Aug 03, 2012 | Televison & Video
For some reason I can no longer copy from my VHS tape to my DVD disk in my Toshiba DVR620KU DVD Video Recorder. I have tried some of the same tapes which had copied just fine in the past. I am using the...
How old is Toshiba DVR620KU recorder and how long it started this problem?
Does it playback previously recorded discs correctly?
Did you tried lens cleaning disc in recorder to clean optical lens?
These info will help me to suggest a solution.
Thanks.
Jul 22, 2011 | toshibadirect.com
Whats a dual layer disc mean then?
A dual layer disc is a DVD which is able to hold double the info.( http://en.wikipedia.org/wiki/DVD#Dual-layer_recording )
Dual-layer recording (sometimes also known as double-layer recording) allows DVD-R and DVD+R discs to store significantly more data-up to 8.54 gigabytes per disc, compared with 4.7 gigabytes for single-layer discs. Along with this, DVD-DLs have slower write speeds as compared to ordinary DVDs and when played on a DVD player a slight transition can sometimes be seen between the layers. DVD-R DL was developed for the DVD Forum by Pioneer Corporation; DVD+R DL was developed for the DVD+RW Alliance by Philips and Mitsubishi Kagaku Media (MKM).[23]
A dual-layer disc differs from its usual DVD counterpart by employing a second physical layer within the disc itself. The drive with dual-layer capability accesses the second layer by shining the laser through the first semitransparent layer. In some DVD players, the layer change can exhibit a noticeable pause, up to several seconds.[24] This caused some viewers to worry that their dual-layer discs were damaged or defective, with the end result that studios began listing a standard message explaining the dual-layer pausing effect on all dual-layer disc packaging.
DVD recordable discs supporting this technology are backward-compatible with some existing DVD players and DVD-ROM drives.[23] Many current DVD recorders support dual-layer technology, and the price is now comparable to that of single-layer drives, although the blank media remain more expensive. The recording speeds reached by dual-layer media are still well below those of single-layer media.
There are two modes for dual-layer orientation. With Parallel Track Path (PTP), used on DVD-ROM, both layers start at the inside diameter (ID) and end at the outside diameter (OD) with the lead-out. With Opposite Track Path (OTP), used on many Digital Video Discs, the lower layer starts at the ID and the upper layer starts at the OD, where the other layer ends; they share one lead-in and one lead-out.
Jun 16, 2011 | Nintendo Wii Console
Can this model of my Dvd reader : "LG GSA-H42N" burn dual layered dvds ?
Review: LG GSA-H42N
Reviewed by: MegaDETH
Provided by: LG - USA
Firmware: RL00 and RL02
Manufactured: December 2006
The LG GSA-H42N internal IDE drive. LG's newest DVD burner incorporates DVD-RAM recording, creating a true DVD Multi drive. Single layer 4.7GB DVD burning is supported at 18X max. Double Layer and Dual Layer Recording speed is 10X max. DVD Rewriteable speeds are 8X max for DVD+RW and 6X max for DVD-RW respectively. DVD-RAM recording is supported at 12X max. Very fast 48X max CD-R burning and 32X max CD-RW.
Hope this answers your question.
Have a great day!
Feb 15, 2011 | LG GSA-H42N 18xDVD+-R, 12xDVD-RAM,...
DVD recorded refuses to read dbl layer dvd it just burned
try burning the dvd's at a lower speed, most of the dbl layer drives have similar type of problems.
Jul 15, 2010 | Lite On LH-20A1H DVD RW Dual Layer Burner
device.
Jan 08, 2010 | Toshiba DVR620 DVD Recorder/VCR
How to burn dual layer dvd with windows dvd maker only 150 minutes pie showing
Everything is the same except you have to choose "DVD-R 9.0G" at the bottom of the DVD maker window. R4.5G is single layer and 9.0G is dual layer.
Let me know if you need more help,
Sai.
Apr 02, 2009 | ASUS P5GZ-MX Motherboard
Dvd recorder funai
I have fixed mine with the same problem , all it needed was the lens cleaned , i used a laser lens cleaning disc from maplin for 6.99 and voila good as new.
May 09, 2008 | Funai PY90DG DVD Recorder
Toshiba DVR620 DVD Recorder/VCR Logo
85 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
