Question about Garden
I need a manual for a 3332 shop vac/wet/dry/leaf blower
I need to have a manual on how to assemble for leaf blowing and sucking up wet and dry.
  • 202 Answers
SOURCE: I have a LeafEater Leaf Blower/Vac 165 mph. I lost
Are you sure the brand is LeafEater?
I would suggest using a good brand of synthetic 2 cycle oil at a ratio of 40:1 and you would be fine.
If you happen to have one of the green units by WeedEater, check their website for a manual. You will need to know the model, tho.
http://www.poulanpro.com/node5782.aspx
Posted on Oct 31, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Poulon-Pro leaf blower manual
If you know your model number (i.e EVB160 etc) you can use this link:
http://www.poulanpro.com/node4043.aspx
enter your model number and download it.
If you do not know your model number
click on products same link, then click on blowers (not snow throwers) find your model then go back to the users manual download.
Thanks for using fixya.
Posted on Feb 14, 2010
  • 885 Answers
SOURCE: I have a Homelite "Vac Attack" leaf blower model
The fuel line is replaceable by itself, you don't need a new tank. Just make sure you get the same size line or it will leak where it goes into the tank. Any local small engine repair shop should have the line. There are two lines that go into the tank, the pickup line has the filter on it. It not only filters the gas but keeps the end of the line down in the fuel.
Posted on Nov 02, 2010
SOURCE: Craftsman 200mph leaf blower/vac the two
i need a diagram of a craftman model 358797319 leeaf blower.
Posted on Nov 20, 2010
  • 85 Answers
SOURCE: sucked up a stick in
the fan may have stripped on the shaft but not enough to stop the fan see it fan spins on shaft without the shaft moving
Posted on Jan 27, 2011
My very old 6 us gallon wet-dry shop vac now blows instead of sucks.
connect the hose on the other end where it say vacuum not blow.
Sep 19, 2016 | Shop Vac Vacuums
Sucking and blowing
Shop-Vac® Brand. The Original Wet/Dry Vac™
https://www.shopvac.com/
Shop-Vac® is proud to be an American-based company. ... When we say the Shop-Vac® is powerful, we're talking debris cleaning, leaf-blowing, heavy-duty, wet or ... Many of our vacs are backed with a 3 to 5 year warranty, but we've seen ... I had just gotten back from work, so my arm was hurting, and I really didn't want to ...
My ShopVac Blows - WOOD Community
community.woodmagazine.com > Forums > Tools and Tool Buying
Nov 23, 2009 - My ShopVac suddenly started blowing dust out the exhaust ports. I don't mean a little dust, it blows almost as much dust as it sucks in!!!! ... ... I'd look it over very carefully looking for tears or splits. Might be a good idea just .... A few months ago I purchased a Dust Deputy and hooked it up to my shop vacuum.
10 Shop-Vac Vacuum Hacks For Around The House - Thrillist
https://www.thrillist.com/.../10-shop-vac-vacuum-hacks-for-around-the-...
Sep 14, 2015 - Simply flip the switch from suck to blow and blow leaves to your heart's... you really need to get your act together if you're using a Shop-Vac for ...
Shop Vacs...and dust control? - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Cleaning Tips
Jan 09, 2016 | Shop Vac Vacuums
My shop vac is not sucking anything only blowing air out of the open hole where the hose should go if I wanted to blow something. I want it to vacuum not blow out. The filter sleeve and dry cloth are...
I just had the same problem, the vac wouldn't suck in. Turned out to be because the filter was WET. It works great when I take the filter off before sucking up water or liquids! Not sure if this applies in your case, but definitely something to keep in mind. : )
Jan 17, 2011 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
Ridgid shop vac is not sucking
Check the intake hose for a blockage. Attach the hose to the exhaust outlet and turn the vacuum on. If no extracted air is blowing out of it the hose is totally clogged up
Apr 10, 2010 | Ridgid 25648 Wet/Dry Vacuum
Kenmore Elite HE4 does not dry the cloths all the way.
if dryer is filled with lint or vent line is blocked the clothes will not dry correctly,shop vac is great for this it sucks and blows,vac out what you can see and then blow out the lint from back and on motor,clean out the lint duct,where ever you pull out your lint filter either on top or inside dryer you have to clean out the duct.now go outside and check the flapper,if it isn't blowing open or hardly opening i use a leaf blower and take off the vent line from the back of dryer and blow it out,good luck
Nov 02, 2009 | Kenmore Elite HE4 Electric Dryer
How do i change from leaf blower tovac? vac will only blow i need to cahange it to vac mode
fell on top of vacum for the place where the air is being sucked in that is the vacum port put hose on this port
Oct 22, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
My shop vac is blowing air out and not sucking. How do I get it to suction?
make sure top is sealed up properly also check to see if hose is not plugged in hose or inside vaccum
Aug 28, 2009 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
Dry/Wet vac is blowing instead of vaccuum
Check to see if the plastic ball is stuck . There should be a ball under the motor , make sure it moves freely. Make sure your vacum lines are not plugged . Best of luck Ed.
Jun 18, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Shop vac
is the filter in place and in good condition. To find the filter just unhook the top and lift it off.
Nov 01, 2008 | Shop Vac (464-38-10) Canister Wet/Dry...
Garden Logo
103 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
