Question about Craftsman 3/8" Corded Drill
How do I grease the bearings for an old craftsman electric drill model 315-25862
I bought this old drill at an heirloom auction. When I turn it on, it made a very rough growling sound, with it being worse when I reversed the direction. How do I approach dis-assemble and grease the bearing? How would I know the bearings are beyond repair? What kind of grease is acceptable for the bearings. What else should I grease?
3 Suggested Answers
philschneide
  • 448 Answers
SOURCE: I need to find out the age of a Craftsman 3/8
It must be fairly old because virtually everything for it in regard to parts have been changed or discontinued. Go to http://www.searspartsdirect.com/partsdirect/index.action and put in the model number. Maybe you can find something out about its age, but I don't see anything.
Sorry I couldn't be of more help.
Posted on Oct 09, 2009
agent91
  • 2100 Answers
SOURCE: I have an old corded 3/8
Yes, the bushings are dry, and it is screaming for oil. But, it doesn't like oil, it likes grease better, but it is hard to get in there to grease it. (sometimes), you might get it apart and both ends exposed. Then get the bushing off the end, you won't be able to get it off the front, either squish some grease in there or get the oil can out and try it. Good luck.
Posted on Apr 25, 2010
Grease fittings
I remove spindles,drilled and tap housings for fitting. In middle of housing. Remove inner seals on bearings. Light oil on idlers.
May 22, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
Bought Craftsman electric brad nailer and cannot find instructions on how to use it, can it get them somehow
You should be able to get the instruction manual from www.searspartsdirect.com just enter in the model # of your kit.
Apr 05, 2011 | Craftsman Nailer Kit, Palm Air Driver
Must install a replacement switch on a portable electric drill. Must have an electrical schematic diagram
If you haven't taken the old switch out yet I would take a photo of the wiring and or make a crib sheet, it you have give me the complete model number and I will try and find one for you.
Nov 16, 2010 | Craftsman Drills
Have 54 inch Craftsman mower deck that I am rebuilding - how do I remove the spindle from the Mandrel housing? Appears to be stuck but will spin.
I've been down this road before and I'd suggest if you really need them out, use a press. I do believe they are pressed in and trying to beat them out without damaging something isn't going to be easy.
I didn't have access to a press and couldn't get mine free. The mandrels on mine were all good except it sounded like they needed grease and considering it had been sitting outside for a few years when I revived the old mower I'm sure it would have been a matter of time before I burnt a bearing. So, and I'm not saying this is the best way, but I drilled a 1/16" hole throw the bearing housing once I got the blades off the bottom of the shaft and the pulleys off the top. I discovered the top bearings have a removable shield that protects the bearings and I was able to pack grease here and put the cover back on. I drilled through the bottom of the mandrel shaft and it took about 1/4" to reach the bearings. I then took a basketball needle and cut the needle off to about a 1/4" deep to insert into the hole I just drilled. It worked, I was about to pump grease in until it came out around the bearing rails and then gave it a spin and added more. I cleaned up around the hole then added silicone to seal the hole. I think it will get me another few years this way and I know the bearings are covered in fresh grease now. We'll see.
May 13, 2010 | Garden
I have an old corded 3/8" corded Craftsman reversible variable speed electric drill (1051). It squeals when I use it. Wondering if it needs to be oiled.
Apr 25, 2010 | Craftsman 3/8" Corded Drill
I have an old craftsman belt sander that needs oil because the engine has started smoking. I bought the right oil, but can't figure out where to put it in. Help?
Many belt sanders have sealed bearings that are packed with grease at the factory. They require no further lubrication. Sleeve bearings should be lubricated with 30 weight oil or an equivalent after each 10 hours of use.
Only about 2 to 3 drops of oil should be applied to each sleeve bearing. Avoid using too much oil. It can get on the work piece or on the belt and the belt will slip.
Apr 13, 2010 | Craftsman 0.5 amp 3D Sander
Manual for 1950 Craftsman Drill Press
Not sure if you ever found the manual for this model number. I just picked one up at a garage sale last weekend and it actualy had the manual with it. Doesn't really go into any overhaul of the machine, but does have a exploded view of the parts.b329678.jpg
Feb 14, 2010 | Craftsman Drills
I need to find out the age of a Craftsman 3/8 electric drill model 315.11480 serial #p8098. Thanks Bill
Oct 09, 2009 | Craftsman Drills
Craftsman 3/8" Corded Drill Logo
64 people viewed this question
Top Craftsman Drills Experts
Gareth Cockram
Gareth Cockram
John Trevino
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
