BenQ W1100 projector has vertical lines on screen
SOURCE: Vertical lines on my Hitachi CP-S225 projector
just changed bulbs on my projector a Hitachi cp-s225 wt and i still see a lot of blue and there are lines o green running down the left side
Posted on Feb 14, 2008
Marrie
  • 563 Answers
SOURCE: Viewsonic Projector Blue Vertical Line
Hi guys
This is a common Mainboard problem on Projectors , unfortunately the Board will either need repairing or replacing.
No shortcutts on this one !
Posted on Mar 26, 2008
Marrie
  • 563 Answers
SOURCE: White vertical line on left side of screen
Hi there
This problem can only be fixed properly by replacing the Mainboard.
Posted on Apr 01, 2008
Marrie
  • 563 Answers
SOURCE: vertical line
Hi there
The only way of fixing this is replacing or repairing the Mainboard.
This is a common Mainboard failure on Projectors
Posted on Apr 02, 2008
omg, I just figured out why OUR projector was doing this! There was an adaptor plugged into it that we use to hook it up to cable to watch games/tv shows sometimes...once I unplugged that from the projector the lines dissapeared!
Posted on Oct 02, 2008
Why do i have vertical lines on benq projector?
Probably because the signal going into the projector is a different resolution to the panel. The projector has an auto sync feature. But that only helps so far. Try changing the laptop resolution to match the native resolution of the projector (the pixels) and not the maximum resolution.
Aug 27, 2014 | BenQ Office Equipment & Supplies
The screen image has a series of vertical lines that appear then disappear at irregular times
Normally this is loose connection of main board with the DMD assembly.
Need to remove main board and Refit.
Samir
Oct 13, 2010 | BenQ SP831 Projector
Hi. I have a problem with a white line on the screen
Hi
This will probably be a vertical white line you are seeing ?
Common BenQ Mainboard problem that can unfortunately only be solved by replacing it.
Nov 26, 2008 | BenQ (200NSH-LAMP) Projector Lamp for...
Thin vertical line appears on projector
I have found that vertical lines that suddenly appear from projectors are due to poorly connected cables. Sut off your projector and wait for the fan to go off. Then unplug the connectors from the computer to the projector and secure them again, making sure to go all the way. Hope this helps.
Nov 25, 2008 | Office Equipment & Supplies
Hi there
Jan 01, 2008 | BenQ PB6100 Multimedia Projector
Pip position
Hi there
The PIP ( picture in picture ) is only to determine where the Menu block itself will show on your screen.
Try the Vertical and Horisontal shift in the Menu Options.
Oct 23, 2007 | BenQ PB6100 Multimedia Projector
BenQ 8700
I had a similar problem with my Benq 8700+. The aspect ratio would show in the R low corner on changinbg resolutions, and would close down to a single line ("anamorphic" for example) which would remain on the screen. I checked the manual (useless) and went through all the set up screens (again useless). In despiration, I decided to try to unplug the projector and did so for 30 seconds to allow the charge to drain from the circuits powering the chips in the 8700+. Upon returning power and restarting, the screen resolution appears/disappears properly once again. Give thjis a try.
Sep 29, 2007 | BenQ PE8700 Multimedia Projector
A vertical white line on the projected screen
i'm having the same problem some one sugested changing the input tryed s-video and nothing i've taken mine apart and cleaned the color wheel thinking something was bloking light or the image the only thing i havent messed with is the lens area but i'm going to try it i'll let you know if it worked hopefuly someone can help us bcause now i'm stuck with a $300 bulb i hope i dont have to buy another 1
May 07, 2007 | BenQ MP610 Multimedia Projector
54 people viewed this question
jasbo
jasbo
