Question about Philips Televison & Video
Picture on tv wont stay on when the xbox is plugged in
  • 1,238 Answers
You have to adjust the resolution of your TV
Posted on Nov 04, 2012
Sanyo 50in HDTV turns on fine, no picture or sound
How is your xbox connected to the tv? If its connected with hdmi cable. Unhook it from xbox and plug it into the back of the cable box. If nothing happens then try switching the tv input with the tv remote. Should have several different inputs. Hdmi,video,component,etc...
Feb 25, 2013 | Sanyo Televison & Video
My xbox cuts on abut wont connect
I'm thinking bad AV cable or bad port on your TV. I assume the Xbox dash board won't come up, if so the "no signal" message is a TV error message not an Xbox error message.
Try a different port on the TV and/or a different TV; also try a different AV cable.
Good luck. Please rate, thanks.
Mar 05, 2010 | Microsoft Xbox 360 Console
Trying to plug in my xbox and can get sound but no picture
Is this the first time you've tried plugging in your Xbox?
Is it Xbox or Xbox 360?
Try plugging it into another TV yet?
I've had a similar problem where I've manually set the resolution of my television on my Xbox. I had it set up for 1080p and then plugged it into my little CRT. The picture was all scrambled and I couldn't do anything. I had to plug it into another TV to fix it. This is the original Xbox by the way.
Check the settings on the Xbox, and if that doesn't work, try swapping out the cables or put it on another TV.
Feb 05, 2010 | Hitachi 57F500 57" Rear Projection...
When i connect xbox 360 arcade[new] to my tv can't it to play
have you switched the switch to hdtv and NOT tv on the back of the big grey ariel plug going into your 360 ? then turn your tv to the aux or av channel as it wont be on a normal channel ??
Jan 26, 2010 | Microsoft Xbox 360 Console
My xbox 360 wont show a picture but it has sound
it might bea problem with your actual video cord that plugs into the tv.... umm my xbox has a lot of issues too but ive never had this. id suggest you let it say off for a while and try somebody elses cords that connect the xbox to the tv to see if its an issue with your xbox or if its with your cords. ill also suggest you call microsoft and they can troubleshoot...
please rate my solution :) thanks
May 31, 2009 | Microsoft Xbox 360 Console
Since your sound works, you know the xbox is booting properly.  Check two things: 1) try another television to make sure it's not the tv.  2) try another cable(from a friend?) to see if the cable is bad.
**Also, if the video settings were saved on an unsupported setting, it could cause the screen to not show video.  If you try these 2 things and you think someone might have saved bad settings, I recall a button combination you can use to reset certain things, and I try to help if it comes to that.
May 30, 2009 | Microsoft Xbox 360 Console
My xbox wont show on my tv,cant hear sound but no
It's possible that your Xbox is sending out a picture that's higher resolution than your TV can display. Try reducing the resolution of the Xbox video output.
May 12, 2009 | Microsoft Xbox 360 Elite Console - Black
X box stays on and telly blurryy but showing the picture?
It sounds like bad soldering, your tv doesn't freeze it's your xbox video/audio output that does. Did you use the towel trick, that is one possible way to have gotten it. You should send it to Microsoft for repair.
Mar 14, 2009 | Microsoft Xbox 360 Console
try using a different input on the tv or a different tv. make sure that you used a totally different av cable. if this all fails then you have an internal hardware failure
Jun 20, 2008 | Video Game Consoles & Games
Televison & Video Logo
18 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
